Old 10-31-2011, 12:17 PM   #1531
Johnny Wishbone's Avatar
Originally Posted by Team_Elli View Post
try to look at www.Tonisport.de for the info on MR33, for some info. by chart you mean Lb/inch messurement? i am runnig the ride springs wich is basicly the same just different package
how did you get 0.3mm anti-dive if may ask?
A .3mm spacer in addition to the 4mm spacer under the front/rear suspension block.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-31-2011, 12:43 PM   #1532
Originally Posted by damage View Post
Anyone running the 2.25mm chassis on carpet?
Sorry no, all my testing is on 2.5
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-31-2011, 12:55 PM   #1533
I think one thing that could throw lots of people off on this cars setup is that it has 5mm of rear wheelbase adjustment. Most think that if they need more rear traction they will just go to the full back setting which doesn't work in all scenarios. Don't lock your thoughts into that one setting and leave it. A longer rear biased wb setting can bring its own problems on such as swing or pendulum effect.
Also note that if your are altering the wb setting to full back you should consider spacing at least the shock bottoms out by 2mm to keep the same shock action or alignment to the shock tower or you'll get a different shock feel again.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-31-2011, 03:05 PM   #1534
stacky150's Avatar
Trader Rating: 13 (94%+)
Originally Posted by hacker View Post
yeh like I have said previously, I don't know what drugs the guy at serpent was on releasing a car with a setup per kit.
The kit setup is completely un-driveable.
I know.....yeh yeh you set the car up to your track conditions, driving style.....but it's way off, it's not funny.
The car is tail happy but it is still easy to drive imo. especially that ive been out of onroad for over a yr and half and to come back and only being 2tenths off the pace. softer rear oil both shocks and diff, 5-5.5mm front droop and maybe even a little pro squat and the car should be dialed.
stacky150 is offline   Reply With Quote
Old 10-31-2011, 03:16 PM   #1535
Hi Johnny,
Found spring charts for Ride spring set:
Basically RED about the same as HPI Silver.
Originally Posted by Johnny Wishbone View Post
If your running on a tight carpet track, try .3mm anti-dive as well.
Is there a link to the MR33 springs with chart?
DanDan is offline   Reply With Quote
Old 10-31-2011, 03:26 PM   #1536
Originally Posted by DanDan View Post
Hi Johnny,
Thanks for the info.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-31-2011, 03:27 PM   #1537
ronsand's Avatar
hi there i had the same problems with the rear end going all over the place on med.traction carpet, but from of basic setup here is what i have done to calm down the rear end and lock it up more at on power i -extended the wheel base at rear with 1mm shim
-changed the rear toe in block to 3.5
-swaped out the springs to MR33 springs Purple front and red rear. Much better driving feeling with those.
-1.2 mm rear sway bar.
-450W shock oil and Xceed 2000 Gear diff oil two gear setup.
-Ride hight is 5mm front and 5,5 rear and droop 6 front and 5 rear.
the car is on rails now only thing i am doing to tune the grip with now is traction additive but going to play with the linkage setup from now on and out
Nice to see that you like the S411, as you are sort of guilty for me getting the it When I first saw your car and had a look at it, I put high up on my wish list (even above the T3'12 that I was considering). I liked the "simplicity" of the steering rack/ Ackerman and the separate suspension blocks both front and rear, much like what I am used to on my buggies!
I actually managed to build and set up the car (built in about 7 hrs start to end) and was actually on my way over to the track to test it last Wednesday when I got the call, and had to turn around and rush of for work. It will be about a week more before I get the chance to give it a go on the track.
Where did you get the Hara or MR33 spring from (rcmarket, tonisport etc)?
You should not by any chance have a set-up sheet ready with your last findings, as it seems to be a good starting point for our track?
Mugen MBX7 - Tekno V4 MBX6 - DEX410v3 - DEX210 - DESC410 - Serpent S411 - Futaba 4PKs - Tekin RX8 + RS Pro - Werks B6
ronsand is offline   Reply With Quote
Old 10-31-2011, 03:35 PM   #1538
Originally Posted by S.A.W View Post
I'm going to try the 'base setup' and go from there. What is everyone using in their geardiff, 2 or 4 gears and what oil, 2000 ? for low/medium grip asphalt.
Does thicker oil in the geardiff make the rear slower to rotate ? may help with it spinning out ?
Thanks.
The 2 gear, 4 gear is a on going debate. I think that if your running the higher turn motors like 10.5 and up you can run 2 gear with no problem. If your running mod anything 4 gear is probably the way to go, just because your able to apply more load over more area of teeth.
Oil on the other hand is personal feel, but remember that the thicker it is the more the diff begins to react like a spool in the back. It seems to effect the roll off the corner more than the hook up or "slip" that you feel with a ball diff.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-31-2011, 03:38 PM   #1539
ronsand's Avatar
Default Spring rate calculator
I found this easy to use spring rate converter and sure the read MR33 springs are close to the HPI silver ones. The HPI pink is close to the MR33 purple.
http://www.hraefn.net/projects/spring_rates.php
It gives kilogram-force/millimeter (kgf/mm) to pound-force/inch (lb/in) and many more.
Old 10-31-2011, 03:41 PM   #1540
Default Steering rack fyi
I found that of you want to tighten up the steering rack, mine seemed to loosen up after several runs, that if you double up the washers on the link arms and put one under each of the post screws it takes most of the slop out of it. I used shim washers from old brushed motors as you need a smaller od so it doesn't drag on the outside of the washer.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-31-2011, 03:45 PM   #1541
Awesome thanks.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-31-2011, 03:51 PM   #1542
RC MARKET's Avatar
Ride 28013 Red use in Rear !
28012 Purple or 28013 Red in Front !!
RC MARKET is offline   Reply With Quote
Old 10-31-2011, 04:06 PM   #1543
Hi RCMarket,
Do you find any differences compare to HPI Silver? like does it being more progressive or linear feel when compress?
Old 10-31-2011, 04:48 PM   #1544
RC MARKET's Avatar
Hi RCMarket,
Red feel like Silver !
little different !
Old 10-31-2011, 08:22 PM   #1545
Jinjiro7's Avatar
So any feedback from guys that have tried the Delrin spool outdrive?
This part: 401428 Driveshaft adaptor delrin
How is the wear on the plastic?
Ryan
* Serpent S411 * M11x *
www.drcrc.ca
www.fastcats.ca
Jinjiro7 is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
