Old 10-30-2011, 09:43 AM   #1516
Johnny Wishbone's Avatar
Originally Posted by S.A.W View Post
Hi,
anyone got a basic asphalt setup for low/medium grip ? tried my 411 for the first time today but used a set up from another driver at my local track but really struggled with rear end grip mostly on power. I haven't tried the kit or basic set up but ran Xray springs 2.8 front and 2.6 rear with 500 oil all round, also tried gear diff with 2 gears and 2000 then 1200 which was a bit better. Then tried 4 gears with 1000. Oh and ran 5mm wheelbase at the rear. Any suggestions ?
Thanks.
Best to post your setup sheet so we can look at what you have to start with.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-30-2011, 09:51 AM   #1517
I started with this http://www.petitrc.com/reglages/serp...ot20110703.pdf apart from I used 2.25mm chassis and standard top deck, 1 deg toe out on the front and 4 droop rear.
I then tried those other settings I posted earlier and I also tried 4 droop front.
I found the car very hard to drive and get the power down out of the corners without it spinning out. it feels good a high speed, stable and easy on the sweepers but infield was a nightmare.
S.A.W is offline   Reply With Quote
Old 10-30-2011, 10:46 AM   #1518
Looking at the 'Basic asphalt setup' it shows a 1mm shim on the rear bulkhead if you use that then the ball joint thread is too long and catches the blade on the driveshaft
Old 10-30-2011, 01:05 PM   #1519
You can either file the ball stud down a bit or raise the outer up instead, they are just about the same effect, angle of upper link compared to lower arm. Or leave the upper inner spacer and change the lower arm spacers to the .5 or out completely.
I think your going the right direction with the rc settings. I would be tempted to even moving the outer upper link to the outer hole, but thats a real personal feel deal. For your setup I would go back to a basic droop setting of 6 in the front and 5 in the back and then possibly take just a little rear droop out of the car or add a little droop to the front of the car, just to get a touch more weight transfer to the rear of the car. Either reduce the thickness of the rear bar or remove it completely. Also go to the xray 2.4 rear spring or go up to the 3.0 front spring, I would do the the 2.4 and possibly move it down one position in the shock tower.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-30-2011, 03:04 PM   #1520
hi there i had the same problems with the rear end going all over the place on med.traction carpet, but from of basic setup here is what i have done to calm down the rear end and lock it up more at on power i -extended the wheel base at rear with 1mm shim
-changed the rear toe in block to 3.5
-swaped out the springs to MR33 springs Purple front and red rear. Much better driving feeling with those.
-1.2 mm rear sway bar.
-450W shock oil and Xceed 2000 Gear diff oil two gear setup.
-Ride hight is 5mm front and 5,5 rear and droop 6 front and 5 rear.
the car is on rails now only thing i am doing to tune the grip with now is traction additive but going to play with the linkage setup from now on and out
*Sanwa M12*Hitec*
*TLR Eight 3.0*Fusion X3LFM*
Team_Elli is offline   Reply With Quote
Old 10-30-2011, 05:58 PM   #1521
If your running on a tight carpet track, try .3mm anti-dive as well.
Is there a link to the MR33 springs with chart?
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-30-2011, 06:41 PM   #1522
damage's Avatar
Anyone running the 2.25mm chassis on carpet?
http://tinyurl.com/Wiocr
Tamiya Hornet, Airtronics XL2P, Novak 4, 1200 SC Stage III batteries,
Navcom 10 peak, 12 volt lead acid power source
damage is offline   Reply With Quote
Old 10-31-2011, 06:09 AM   #1523
I'm going to try the 'base setup' and go from there. What is everyone using in their geardiff, 2 or 4 gears and what oil, 2000 ? for low/medium grip asphalt.
Does thicker oil in the geardiff make the rear slower to rotate ? may help with it spinning out ?
Thanks.
Old 10-31-2011, 06:40 AM   #1524
hacker's Avatar
Trader Rating: 140 (100%+)
Thanks.
it seems to be heavier oil(like a tight rear ball diff) will make the car to tend to push, and a lighter oil will make the car square off or rotate better.
I have not played with diff oils yet, but my next test day will be of 900cst, 2k, 3k, & more if needed.
I'm going to set my car up to understeer massively, and bring the car under control around corners with drag brake. Not the ideal solution to driving a TC, but seems this will be needed with this tail happy snaky rear end of the s411.....
hacker is offline   Reply With Quote
Old 10-31-2011, 07:28 AM   #1525
dameetz's Avatar
Hmmmm....I keep on reading about this car's very loose rear end, its getting me nervous now, I ll be receiving my car this week, hopefully I can finish building and test it by this weekend. Hopefully the loose rear thing will not be as bad coz I m coming from Yok BD5WR where the rear is grippy but I can't get enough steering from it (that's why I sold it). What tyres are eveyrone using here?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 10-31-2011, 08:10 AM   #1526
Hi,
Thanks.
You could always do the sensible thing and come back to Xray.
It did look a handful out there and you were way of the pace.
Xray-Goon is offline   Reply With Quote
Old 10-31-2011, 08:15 AM   #1527
hacker's Avatar
yeh like I have said previously, I don't know what drugs the guy at serpent was on releasing a car with a setup per kit.
The kit setup is completely un-driveable.
I know.....yeh yeh you set the car up to your track conditions, driving style.....but it's way off, it's not funny.
Old 10-31-2011, 10:17 AM   #1528
It's like with EVERY car you need to work with the setup to get it to your liking so whats the problem then if the kit set up is all wrong? i like a challange like this because i'm not a lazy b*** that likes everything given to me in my hands. You get to know the car better and you learn how it reacts to setup input and etc...
*Sanwa M12*Hitec*
Old 10-31-2011, 10:20 AM   #1529
I'll persevere a little longer otherwise I'll change back. It was great a speed but thorugh the slower sections it was awfull to drive especially out of the corner. But wasn't the best track condtions for testing a new car.
Old 10-31-2011, 10:25 AM   #1530
try to look at www.Tonisport.de for the info on MR33, for some info. by chart you mean Lb/inch messurement? i am runnig the ride springs wich is basicly the same just different package
how did you get 0.3mm anti-dive if may ask?
*Sanwa M12*Hitec*
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
