Novak GTX
#260
The Evicerator
No, you do not need the Millenium Pro or other external device to program the GTX's 7th profile. It is all done via the one touch button and blinking LEDs. It's similar to the method used with the GT7's 7th profile, but further refined for easier interface.
#263
Originally posted by rc-zombies
I just ran mine over the weekend...talk about punch..tons of it running the stock profile #3. super smooth..and much better than the GT7.
John... I don't think you'll need the cap for the mini's... the GTX is so tiny... it wouldn't hurt.
Glad we concur. Too bad i didnt get to do a back to back test
Ray
#264
JF.
I won't say yes to that question regardless of the application. If an ESC says it needs a power cap for all applicaitons, it needs it for all applications. It may or may not work fine with out it, but bottom line is, it will always be faster with it on, and provide a longer ESC "Life".
#266
The Evicerator
Those orange clips are for holding the switch onto the 5 pin connector plug... Clip, plug, switch...got it? :P
#268
Originally posted by Charlie
JF.
JF.
John
#269
I'm running touring stock. What is the best profile setting for this class. I believe #3 is the default. Any feedback is appreciated.
thanks,
thanks,
#270
The Evicerator
Profile #3 should be a good start, but if you feel like you need more agressive bottom end response, you can try profile #2... if you still feel it needs more, try profile #1... basically the lower the #, the more agressive the drive profile.
