Old 01-26-2011, 07:58 PM   #1
unsane_chimera's Avatar
Default Sakura Zero S, Ackerman adjusting.
Hey guys, sorry if this has been covered before.
I have a Sakura Zero S, which I am currently using for drifting until I get a new motor for racing, and as such I need to get as close to 0 Ackerman angle as possible. Is there any way of adjusting it to as close to zero as possible or any mods out there?
I'm currently using about 5 degrees of toe-in and the steering arms are in the closest hole to the chassis on the c-hub arm. That reduces the Ackerman significantly but decreases steering lock angle hugely.
Thanks in advance guys.
In the past few hours I have learnt these very important things; firstly, read the instructions, secondly, READ THE INSTRUCTIONS!! And check the back of the piece of paper if there are more instructions, thirdly, double check what you have done, then check it again and READ THE INSTRUCTIONS!!!
unsane_chimera is offline   Reply With Quote
SEO by vBSEO 3.5.0
