alternative to shoe goo for battery packs
Is there anything else you can stick the cells in a side-by-side pack together with aside from shoe goo? I just priced some and it is AU$24 a tube, thought there may be a cheaper alternative somewhere...
Re: alternative to shoe goo for battery packs
Why glue something you might want to unglue one day.
What the? That's like 17.00 USD.
I bought my tube of Shoe Goo for 5.00 USD.
Why do you think we order things from Tower hobbies. Things are SO expensive over here
Re: Re: alternative to shoe goo for battery packs
CA as in like, liqud nails or something? what about silicone?
We may have a hot glue gun somewhere
Originally posted by AzNDRAGster
Get a hot glue gun or some CA.
Registered User
Try CA and baking soda.
tell me more
Re: Re: Re: alternative to shoe goo for battery packs
Re: Re: Re: Re: alternative to shoe goo for battery packs
Superglue?
Originally posted by DOMOisCOOL
CA as in Tire Glue.
CA as in Tire Glue.
Thats what it basically is.
OK Cool
So flexibility or lack thereof isnt a problem?
OK Cool
OK Cool
I'd think a small tube of silicone caulk should work fine. It would have some flex as well.
CA can be bad
You actually want some flexibility in the joint, so I would actually avoid CA or just rely on the battery bar itself. If the battery is glued together like a rock, then there is no give when you hit a curb or barrier. If the joint or battery bar doesn't afford any give, the stress is taken out on the battery itself. Given that ni-mh batteries are fragile, this additional stress can't be good.
You don't need to run a lot of shoe-goo on a battery. Just a dab will work for each cell, so 1 tube should last for many packs.
