Need help about Motor Maintenance and Lathe? Brushes?
#16
Originally posted by TryHard
I just got myself a 3racing lathe with V-Blocks, and I probably made the biggest rookie mistake, in that I had the motor spinning the wrong way for the tip. Looked like i was ploughing a field instead of cutting a comm.... I junked a V2 armature trying to sort out the shoody cut, and I think the cutting bit is damaged. So that's a bit of advice for you....
Hope it helps
Ed
Hope it helps
Ed
#17
I am using some parma bearing oil anyone know if that's anygood?
micros_rock I have a PM for you.
How many cells should I use for a motor breakin? 4????
#18
4 is good. I PM'ed you back
