Old 06-19-2013, 05:54 AM   #1156
Trader Rating: 49 (100%+)
They'd probably do it, but you'll just have to pay. May still be cheaper than a new ESC, e-mail and ask.
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 06-22-2013, 05:44 PM   #1157
Default newbie question
Hi.
What settings do I start with for 1/12th using 13.5t BL motor? I have a LRP SXX Competition v2. I run in a large indoor asphalt track.
Thanks.
bosschick is offline   Reply With Quote
Old 06-24-2013, 10:27 AM   #1158
Conrad's Avatar
Quick question for all the braniacs out their. Just picked up a SXX V2 (Actually a Nosram Pearl Evo V2) which was repaired by the distributor with the upgrade logic board being fitted. The esc sets up fine, stores all settings on 2S but when I connect it to a 1S Lipo the orange light comes on and the motor turns at a slow speed. This is after turning off the lipo protection when the 2S was still attached. As their is no mention of orange light only on the troubleshooting guide could someone point out the problem?
Tried setting it up on 1S only, it apparently establishes the endpoints but after the setup is complete their is nothing, enter the mode setup and switch off the voltage cut off and still nothing.
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 06-24-2013, 02:22 PM   #1159
nerdling's Avatar
you need a booster. the flow and sxx v2 with the new logic board are not directly compatible with 1s.
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 06-25-2013, 05:55 AM   #1160
Conrad's Avatar
Thanks for the clarification.
Old 07-27-2013, 08:00 PM   #1161
Default Blinky mode
So I bought a used LRP SXX version 2 and it seems to work fine we were running open ESC and it was great. but have changed over to run the class in Blinky mode and here is where I'm having issues.
When in Mode 2 "torque feel" it needs to be at 0 to be blinky and it skips right over the 0 setting? Goes from setting 10 to 1
I tried resetting the ESC binding it to my radio and it started blinking but it also reset the lipo mode to 2S and once I set the lipo mode back to 1S it quit blinking and won't go to 0 on mode 2
Any ideas?
dragginyota is offline   Reply With Quote
Old 07-27-2013, 08:21 PM   #1162
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Any ideas?
Torque is (1) not (0) I think ?
0-1-0-X
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-27-2013, 08:42 PM   #1163
Default LRP
The paper I have shows a 0 setting for torque feel.
http://www.teamassociated.com/pdf/di...e_lrp80915.pdf
Old 07-27-2013, 09:03 PM   #1164
Not sure then ?
Do you have more than 4 modes?
Possible the board has been updated ?
Old 07-27-2013, 09:06 PM   #1165
Default Blink
How can you get it to blink when torque feel is advanced? Or are you saying I can show tech that Boost is at 0 and they will consider that blinky?
Old 07-27-2013, 09:12 PM   #1166
No blinky, no go
Try factory reset, and recal radio
Old 07-28-2013, 09:36 AM   #1167
Default Firmware
Is there a firmware update or something I could download?
Old 07-28-2013, 01:38 PM   #1168
modes 2 and 3 need to be at zero (default) to get the blue light to blink
TcORC president
Yokomo bd7 sedan, bd7 usgt
Roche rapide p12
magnum is offline   Reply With Quote
Old 07-30-2013, 05:44 PM   #1169
B44USTA's Avatar
Trader Rating: 45 (100%+)
Send a message via Skype™ to B44USTA
Talking
Hey guys,
can someone tell me where i can get the firmware for the SXX esc please?
ive looked on LRP, unless i'm going blind i couldn't find it
-------------------------------!ALLL FOR FFFUN!------------------------------------------
B44USTA is offline   Reply With Quote
Old 07-30-2013, 07:19 PM   #1170
nerdling's Avatar
Can anyone recommend a good supplier of cooling fans for the V2?
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
