Old 02-12-2013, 04:58 PM   #1126
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Originally Posted by RedBullFiXX View Post
Just wanted to confirm
1s operation is flawless with the new upgrade board
Used a 10.5 blinky for 12th mod at our Roar region race
Drives super smooth, Steering was very responsive with Spektrum H5020G servo
Thanks again to AE for the quick turn-around, and FREE update
Rx pack or booster?
Kyle Predmore
Facebook - "AE Fanboy"
B6D|B64D
TC7|TC6TEK|12R5.2|10R5.1
Logi Maker is offline   Reply With Quote
Old 02-12-2013, 05:01 PM   #1127
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Logi Maker View Post
Rx pack or booster?
Neither
runs 1s native, just like old school LRP VII boards
Guess I forgot to mention that bit
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-13-2013, 09:49 AM   #1128
gwhiz's Avatar
Neither
I am confused, because:
From: http://www.lrp.cc/fileadmin/lrp_anle...1_80999-en.pdf
"Linear BEC: a powerful linear 6V/3A output has been integrated, which offers bulletproof + stable voltage to
the receiver + servo.
Important: be aware that the SXX Mod+Stock does not have an integrated booster and therefore for 1S applications
a separate receiver pack is required.
x
gwhiz is offline   Reply With Quote
Old 02-13-2013, 10:32 AM   #1129
Yes
This is why I posted my results
My guess is that the LRP customer support division do not want to "support" 1s native operation, for the many configurations racers will choose to use
But it does indeed work with the hardware in my rig, and others I have read about
Old 02-13-2013, 11:45 AM   #1130
Logi Maker's Avatar
Well i guess i should have sent my 1/12 one in and waited 4 months for that one too!
Kyle Predmore
B6D|B64D
Old 02-24-2013, 04:43 PM   #1131
UrabusDenis's Avatar
Help guys!
One of the two wires on my on/off switch (Nosram Pearl v1) has broken inside the switch so I can't reach it to resolder it. Can this be somehow opened and repaired or should I just cut it and solder the two wires together? I don't really need this switch but it would be nice to repair it
JQRacing - eu.jqracing.com
Blue Bird - www.blue-bird-model.com
RW mods - www.rw-mods.com
Boca Bearings - www.bocabearings.com
UrabusDenis is offline   Reply With Quote
Old 02-24-2013, 05:31 PM   #1132
Logi Maker's Avatar
If you can get it apart you can resolder it. The LRP has four screws that open the case.... shorten your rx wire while your at it...
My buddy did it on his blog site and has great pics
Www.rcpitwhores.com
Kyle Predmore
B6D|B64D
Old 03-04-2013, 03:45 AM   #1133
numnut862's Avatar
hi guys just seeing if anyone can help out I just brought my second sxx v2 stock spec. l plugged it in and it runs like at 1/4 speed l checked and changed sensor cable still did the same thing.then I unpluged the fan out off my receiver and now its getting full power and shudders a bit what else can i do if i upgrade it will that fix it????
Xray T4##,MILTSBODIES## kyosho SERCCC
Team Orion ##savox##XRAY 808 LRP
RABHOBBIES futaba SC 10 t3 HOBBYWING
VBC RACING leespeed mprccc FANTOM RACING
numnut862 is offline   Reply With Quote
Old 03-04-2013, 05:24 AM   #1134
HenryC's Avatar
I own 3 of these and have not seen this problem except once when I had not calibrated the ESC to my transmitter. Did you go through the calibration process?
HenryC is offline   Reply With Quote
Old 03-04-2013, 06:26 AM   #1135
vivo quevas's Avatar
Trader Rating: 18 (100%+)
I have a SXX version 2 and I have the weakest drag brakes with it set on 9 in mode 4. Is this normal?
Tamiya/Exotek EXO6 USGT, Tamiya TB03 GT3, Exotek FR1V2
Roche Rapid 1/12, XRay Speed Merchant WGT
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
"Take an early lead and extend it".(Fast Eddie Janis)
vivo quevas is offline   Reply With Quote
Old 03-04-2013, 08:07 AM   #1136
Just curious which ESC did you send in for the upgrade? And is it the logic board upgrade? Recently I sent my SXX TC SPEC V1 for the logic board upgrade so it can be used for blinky since everyone is using the v2 stock spec for blinky I figured let me see what and why they changed from tekin rs/rs pro
JOE SI is offline   Reply With Quote
Old 03-04-2013, 08:53 AM   #1137
Unless I am mistaken
The new Stock + Mod logic up-grade board is the same for all SXX esc
So aside from heatsink varients (Stock Spec, TC Spec) vs: Comp, they are identical in function
Old 03-04-2013, 09:57 AM   #1138
Right understood, I just wanted to know if the upgrade made that much of a difference from what was being used initially..
I couldn't run blinky with my tc spec v1 so it was a must for me..
With the upgrade itll be just like buying a v2 brand new?
I was told it was a mix between all the new lrp esc's (the new board)..
Whatever the case ill be able to use it for stock classes and that was my intentions
Old 03-04-2013, 10:10 AM   #1139
I've only run 1s blinky with it
Feels like an LRP
And that's not a bad thing
Old 03-04-2013, 12:25 PM   #1140
numnut862's Avatar
Yes I did that l might do it again to see if that works
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
