Old 12-08-2012, 04:20 AM   #1081
spencehotbodies's Avatar
Hello
Has any body got a good set up for a thunder power 13.5? Just had the speedo back with the new board fitted.
Cheers inadvance
spencehotbodies is offline   Reply With Quote
Old 12-09-2012, 08:06 AM   #1082
Default New board vs old board
Looking for some suggestions....
I have 2 LRP sxx stock spec esc's one of them has the upgraded mod board (just bought it) here is my question I run oval 13.5 open esc and the other is a TC6.1 17.5 blinky. Currently my older esc is in my oval which is open esc and my upgraded esc in in the car that has to be blinky. Should I swap the esc's since oval can be boosted? Is this new board better as far as boost and torque feel options? And what are the benefits of this new board with the mod?
Thanks in advance for any suggestions
dragginyota is offline   Reply With Quote
Old 12-09-2012, 08:32 AM   #1083
My guess is no one has had a chance to experiment with the new board as the first batch are just coming back now.
12 weeks and counting here...........
I would say new board esc in boosted, if it was me. Just start gearing and/or boost low as to not blow it up first run.
Blinky isn't harsh on the older board so you wont have BEC issues that some have complained about.
all my esc's were run blinky and I never had a bec issue.
Jeff Cohen
www.rcgears.net, www.carcar.ca, www.trukz.ca
Thanks to my Sponsor: Shred-A-Can Metal Recyclers LTD
www.shredacan.com
chongo is offline   Reply With Quote
Old 12-13-2012, 05:18 AM   #1084
briankstan's Avatar
Mine was sent in last week, It looks like I'll be waiting awhile to get it back based on the other posts in this thread.
www.slmini-zstore.com
www.saltlakemini-z.com/forum
www.howfastareyou.com
briankstan is offline   Reply With Quote
Old 12-13-2012, 10:14 AM   #1085
Kellen Guthrie's Avatar
I've had the upgraded board in for maybe 2 months now and it's a lot better. I haven't really played with any boost on it but it's a lot smoother especially under braking.
LRP America
Kellen Guthrie is offline   Reply With Quote
Old 12-14-2012, 09:24 PM   #1086
Default new board with 10.5
In the Uk we have had the upgraded boards for about 3 months now LRP were very quick the Nosram red variety took 2 months. In the Uk our spec class is 1s boosted. Ive been running this on 0,8,8,0 with out any problems Rollout around 58mm on a large track This is with Thunder power and Reedy sonic motors.Can timming 40 degrees
RCvetran is offline   Reply With Quote
Old 12-15-2012, 01:21 AM   #1087
No9
No9's Avatar
I have 3 of the new boards for around 2 months now and 1 has had sensor failure on 1s blinky 10.5 ,not a good start.
I ran them first without a booster/rec battery and then with and there is a big difference in the cars performance and would recommend not running without a booster/rec battery.
Schumacher Mi5evo/Ko Ex1v2/LRP/R1 wurks
Supported by MRJ RACING.COM.AU
No9 is offline   Reply With Quote
Old 12-15-2012, 03:22 AM   #1088
Default booster or receiver pack
I ran mine for 2 months with a booster or receiver .Changed a week ago and there is a notice able difference in speed and servo speed. I noticed in the majority of my runs handling goes off in last 60 seconds, guess this is because servo gets slower near end of run.
Old 12-17-2012, 01:37 PM   #1089
gonzo416's Avatar
Trader Rating: 39 (98%+)
I have a throttle problem that hopefully someone can help me with. When I turn the radio on then the car , the throttle powers the motor briefly. This is not good as the car will take off if it's on the ground. If I turn the car off then back on it doesn't happen again. It happens when I turn both the radio and car off then on again. I'm using a Spektrum DX3R with the SR3520 receiver and Futaba S9551 servo. The speedo is brand new.
gonzo416 is offline   Reply With Quote
Old 12-17-2012, 02:13 PM   #1090
No9
No9's Avatar
I have had a similar issue and found it was my radio and not my esc that was the cause.
I had to constantly reset the calibration each time i used it.
Try that first and if it does not fix your issue try another radio.
Old 12-17-2012, 03:40 PM   #1091
gonzo416's Avatar
Do you mean a different brand radio? Cause I have a brand new DX3R Pro that I was going to put up for sale.
Old 12-17-2012, 03:58 PM   #1092
jekyll08's Avatar
Default sxx
well i have a mt-4 with a stock spec sxx and it works great but the real reason is that the wheel on it is awesome. so stop playing around and buy it couse you know want it.lol
Brian
jekyll08 is offline   Reply With Quote
Old 12-17-2012, 04:05 PM   #1093
gonzo416's Avatar
Brian
Yeah! Have to have 2. lol
Old 12-17-2012, 04:07 PM   #1094
jekyll08's Avatar
you're the best
Old 12-17-2012, 11:29 PM   #1095
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
I have a brand new LRP SXX TC FOR SALE LRP SXX TC BRAND NEW UPGRADE KIT SXX MOD+ STOCK
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
