Old 10-29-2012, 07:38 AM   #1036
briankstan's Avatar
Here is my predicament. I have the Stock Spec V2, it has a blown BEC, I am using it in my pan car with 1 Cell and the BEC let go.
Anyways I have been using a LiFE battery to power the receiver and servo without problem. I have full function with the ESC doing this.
Is there any long term problem with running it this way?
I would hate to have to send it in and not be able to get a replacement or have it repaired for a long time, I'd miss races and that won't work. I've been very happy with it but was really stressed out when the BEC blew right before our state championship. If I have to buy a different ESC, it won't be an LRP.
If they don't have an ETA on the updated boards they need to extend the deadline of when the ESC's need to be returned to them for replacement.
www.slmini-zstore.com
www.saltlakemini-z.com/forum
www.howfastareyou.com
briankstan is offline   Reply With Quote
Old 10-29-2012, 10:48 AM   #1037
AE-Reedy
No there is no long term problem with using the rx pack.
If you send it in and get it upgraded you will have to use the rx pack as the new board does not have a 1s bec booster any longer.
Sean Cochran is offline   Reply With Quote
Old 10-29-2012, 10:51 AM   #1038
AE-Reedy
Originally Posted by zerocool77 View Post
There no wrong too much power, the pblm is, you cant handle it, and too hot. Its always 138celcius.
It is hard to say with out knowing all your specifics but I believe that you are way over geared. You probably should be using timing 6 but need to adjust gearing accordingly.
Old 10-29-2012, 11:00 AM   #1039
briankstan's Avatar
Good info to know. the class has switched to a 2S setup this year, so I'll be going with a 2S shorty pack. I'd like to have it working properly, but don't have the time to send it in with an unknown return day, unless I get another ESC to use until then, I'll have to think about that.
Old 10-29-2012, 11:14 AM   #1040
As of 10 minutes ago, AE still hasn't received any boards from LRP.
We're all still at unknown ETA for the SXX upgrade and return of our ESC's.
7 weeks and counting for me.
Jeff Cohen
www.rcgears.net, www.carcar.ca
Thanks to my Sponsor: Shred-A-Can Metal Recyclers LTD
www.shredacan.com
chongo is offline   Reply With Quote
Old 10-29-2012, 10:52 PM   #1041
piper48
Guest
Posts: n/a
That pretty much answers my question. I sent a V2 Comp last year and it took
4 months till I got it back.
Old 10-30-2012, 12:04 AM   #1042
Jochim_18's Avatar
Yap we just have to wait... SUCKS!!!!
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 10-30-2012, 12:05 AM   #1043
Jochim_18's Avatar
Waiting for over 4 weeks now wow!!!
Old 10-30-2012, 12:37 AM   #1044
wtcc's Avatar
A friend used one of the new boards last weekend and it killed his motor, because it caused higher motor-temperatures He was racing unboosted 17.5t with a fdr of 4.6!
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 10-30-2012, 12:06 PM   #1045
But how much physical timing was dialed into the motor on the end bell?
Jeff Cohen
www.shredacan.com
Old 10-30-2012, 01:35 PM   #1046
wtcc's Avatar
-10* In the LRP-HPI-Challenge only the lowest timing insert is allowed! His car was fine, too. It was after the change of the board that the motor died! He wanted to try it, hoping to have a feeling advantage...
AE / Reedy / RSD
Old 10-30-2012, 01:38 PM   #1047
Jochim_18's Avatar
That's why check the temp during practice to figure out gearing lol
Old 10-30-2012, 01:39 PM   #1048
Jochim_18's Avatar
I see it as a good thing I rather kill a motor than the speedo lol...
Old 10-30-2012, 02:29 PM   #1049
wtcc's Avatar
The gearing was 4.6! Read before posting... In this configuration the motor never has more than 70*C.
AE / Reedy / RSD
Old 10-30-2012, 04:37 PM   #1050
Gearing changes by track.
At our clubl track I was running 96/45, 4.27fdr, temps 150F
This weekend at out of town WCICS race, I had to gear up 96/47, 4.08fdr, 162F and put in lots more physical timing.
The race this weekend the track was bigger, with high speed chicanes and less braking than our club track.
I'll be glad to get my SXX's back!
Anyone with the new board, how are the brakes?
I notice when I run lower FDR's the brakes get very light and soft in blinky 17.5 TC.
I can't run a smaller spur than 64p 96 so once into 45+ pinions the brakes get less and less.
I've swapped out everything to see if it's electronic, but it seems to be a low FDR issue in my old TC5R.
Jeff Cohen
www.shredacan.com
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
