Old 03-06-2011, 05:47 PM   #91
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default software
Hi,
just wanted to shoot out a quick question...
what version of the software is installed on the current batch of speedos.
is there a quick and easy way to find out which version is installed?
read a way back but couldn't find anything.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 03-06-2011, 06:38 PM   #92
Johnny Wishbone's Avatar
Originally Posted by olhipster1 View Post
Hi,
It used to be determined by a certain amount of beeps when the speed control was powered up.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 03-06-2011, 07:15 PM   #93
nitro rat's Avatar
Trader Rating: 5 (86%+)
Hi Guys,
Just after some help. I was reading through my SXX V2 manual about the "boost" setting and the manual says i can visit the LRP website for factory boost recommendations. I cant find these boost recomendations on the LRP site anywhere. Im just chasing settings for my 10.5.
nitro rat is offline   Reply With Quote
Old 03-06-2011, 08:17 PM   #94
Originally Posted by nitro rat View Post
Hi Guys,
LRP found the linked file to be corrupted, so took it down. Keep watching the site and you will see it linked in the future. Also, please note that LRP has 3 speedos marked SXX. This thread is for the SXX Stock Spec V2. There is also a SXX Competition and a SXX TC Spec.
davidl is offline   Reply With Quote
Old 03-06-2011, 09:00 PM   #95
olhipster1's Avatar
Default please explain
can you please kindly explain? number of beeps =
much appreciated.
CAUSE and EFFECT
Old 03-06-2011, 10:59 PM   #96
JayBee's Avatar
Trader Rating: 31 (100%+)
Default Questions...
Just wanted to know some things about this speedo- before I pick this up, can I
(1) run this speedo in NON-BOOSTED 17.5 & 13.5 classes (1/12th)?
(2) run this speedo in BOOSTED 17.5 & 13.5 classes (1/12th)?
(3) run this speedo in the same 4 classes in a TC?
Thanks for the input guys
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 03-06-2011, 11:15 PM   #97
xray09ACT's Avatar
yes
ACE Hobby Australia | Monaro models
TEAM Associated TC6 | LRP | LRP
TEAM Associated TC6 | Nosram | Nosram
TEAM Associated 12R5.1 | LRP | LRP
xray09ACT is offline   Reply With Quote
Old 03-06-2011, 11:27 PM   #98
caltek1's Avatar
Trader Rating: 36 (100%+)
davidl,
If you have a SXX StockSpec V2 ESC, then the instructions have the team recommended "Boost" settings on them for on road TC, 1/12 and off road for 10.5, 13.5 and 17.5 BL motors. They also have recommended settings for Torque/feel, (which is mode 2).
There are also settings for X12 BL motors and X11 and other brand BL motors.
JayBee,
Mode 2 and Mode 3 have to be set at zero for blinky/zero timing mode.
Later,
Calvin.
caltek1 is offline   Reply With Quote
Old 03-07-2011, 12:49 AM   #99
nitro rat's Avatar
i dont get the whole boost thing
Old 03-07-2011, 01:16 AM   #100
caltek1's Avatar
nitro rat,
Find attached a copy of the ESC instructions. They should clarify the settings you can adjust.
Calvin.
File Type: pdf anl_29277_ra00303-sxx-stockspec-vers2-e-101217fv.pdf (320.1 KB, 294 views)
Old 03-07-2011, 03:03 AM   #101
Originally Posted by caltek1 View Post
davidl,
JayBee,
Later,
Calvin.
Yes
Old 03-07-2011, 08:22 AM   #102
They come with V 4.2 installed.
-Scott Spear
Team Associated, Reedy, LRP, Proline, Winning Edge Designs, Byrons Fuel, AVID Bearings, TFR Racing. ***Team Associated Region 10 Administrator***
Scott S. is offline   Reply With Quote
Old 03-07-2011, 11:01 AM   #103
Default software installed
As mentioned comes with V4.2 latest software is 4.4 makes a huge difference to settings.
v4.2 using X12 12.5 rotor and 4 dot insert. 0,4,5,0 in 1/12th pan car
v4.4 using x12 12.2 rotor and 3 dot insert 0,5,11,0 in 1/12th pan car
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 03-07-2011, 02:46 PM   #104
Wacker1's Avatar
Hi all,
I Purchased the New LRP SXX Ver2 StockSpec with the PC Software Update Cable Today, so should Receive it Tomorrow!
As you've all mentioned about the current Software on the Ver2, where is the very Latest '4.4' Software Available to Download onto it?
What Benefit/s does the Latest '4.4' Software give to the Ver2 StockSpec Speedo?....i.e More Power? Run Cooler etc?
Also, which Motor works best with this Speedo?i.e LRP's own X12 or a different Manufacturer like GM etc
Thanks.
Wacker1 is offline   Reply With Quote
Old 03-08-2011, 01:09 PM   #105
Where can i buy a LRP SXX Stock Spec V2, I can't find any on the East Coast, USA. I took 2 years off and want to get back into 1S 1/10th oval racing. Thanks, Daryl
DARYL is offline   Reply With Quote
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
