Old 08-21-2012, 07:23 AM   #976
MikeXray's Avatar
Trader Rating: 72 (100%+)
Originally Posted by Jochim_18 View Post
So I'm assuming my BEC is blown on my stock spec V2 when plug in to my receiver it won't power up but when i unplug it was fine..Can I just bypass it and just hook and a receiver pack to power up my servo... I was thinking if I can getaway with the receiver pack might as well just use on my 1/12 scale any thought?
Yes it works, just make sure to leave the switch OFF.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-21-2012, 09:26 AM   #977
Default Thunder Power 13.5 and Lrp Stock Speck V2
Hello
Do anyone have a good and fast Setup for TP 13.5 with this esc
in a boosted class?
Viking73 is offline   Reply With Quote
Old 08-21-2012, 11:34 AM   #978
RussF's Avatar
Trader Rating: 21 (100%+)
Not exactly sure if you are saying that you cant power up your receiver or the ESC when they are connected together.
But the way to connect everything is the steering servo and ESC connect to the reciever on channels 1 and 2 but you plug in a battery pack (6v) to the battery input on the receiver. A small l.i.f.e. pack would be great for 12th scale.
You may want to send your ESC in for repair or buy the upgraded BEC board and install it yourself if its available yet.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 08-23-2012, 09:23 PM   #979
Tim Stamper's Avatar
I was running a small LiFe pack on mine for a couple of weeks until I replaced that with a small BEC. Using my old 12th scale mentality, I just left the switch off and let the external power sources control the action.
I am having issues finding the "upgrade" board to get things fixed and as long as the small BEC works, I will keep it in there.
This is in my B4.1 Worlds buggy running a 8.5T ballistic at 1-4-1-1. Don't know if the settings make a difference but it is solid.
Tim
This space for rent
Last edited by Tim Stamper; 08-24-2012 at 03:46 AM. Reason: Added a pic of the BEC
Tim Stamper is offline   Reply With Quote
Old 08-23-2012, 11:55 PM   #980
Jochim_18's Avatar
I just called associated they said they have the new board and I can send mine in free of charge..
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 08-25-2012, 08:57 AM   #981
onekiwi's Avatar
SXX TC Spec in a durango 410 6.5T
What is the yellow light and constant beep telling me?
I thought it was thermal but that has to have the blue led blinking fast as well right? The esc was only 50C
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 08-26-2012, 08:29 PM   #982
bhambrent's Avatar
Anyone know when this will be out?
Upgrade-kit turns all LRP SXX into Modiefied + Stock speed controls!
Art. no.: 80999
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 08-27-2012, 12:24 AM   #983
Jochim_18's Avatar
Well bud you probably fried it mine did the same thing..
Old 08-27-2012, 08:08 AM   #984
onekiwi's Avatar
Now I think it was the BEC that gave up. I did have a broken nosram TC spec that I took the board like in post #982 above, stuck that in and I got power etc.
It wouldn't turn the motor over very well as its a different esc software/hardware etc but it worked.
Now Im thinking that hopefully the new board that LRP are releasing can solve the problem. Might even help you Jochim_18
But Im thinking that its going to cost at least $100 for that so really it may not be worth trying
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 08-27-2012, 08:50 AM   #985
Trader Rating: 20 (100%+)
Art. no.: 80999
It's out in Europe but it hasn't made it's way to any stores state side yet that I can find.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 08-27-2012, 11:22 AM   #986
onekiwi's Avatar
Anyone else with those thoughts as well? its about $87 + shipping so an expensive try
Thoughts?? ANyone know if it will solve the issue?
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 08-27-2012, 01:13 PM   #987
Default installed the new board
Hi,
I already have installed the new board, but the motor is getting to hot, I am using the same FDR I was using on the SXX Stock Spec (with boost) 6.0 on a big track, after 4min the esc cuts-off (motor temp)
here is my setup on the new board:
Mode1 - 3
Mode2 - 2
Mode3 - 6
Mode4 - 0
Motor - Pure Evolution 13,5T
FDR - 6.0 (36-108)
then I have changed the FDR to 6.17 and it cuts-off at 5min
then changed to 7.2 FDR and cuts-off at 4min
anyone can give me an advise on the settings and FDR?
thanks
duartev is offline   Reply With Quote
Old 08-27-2012, 01:46 PM   #988
bhambrent's Avatar
I'v been looking but can not find a street date or price.
Old 08-27-2012, 01:51 PM   #989
onekiwi's Avatar
Ive found it for $87 just want to know if it will work
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 08-27-2012, 01:56 PM   #990
bhambrent's Avatar
As soon as it get to the States, I'll let you know.
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 09:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 09:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 11:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 05:15 AM
SEO by vBSEO 3.5.0
