Old 07-23-2012, 11:58 PM   #961
gelshocker's Avatar
Originally Posted by narcotiks View Post
I ended up getting the SRG BL, I was after the SRG BLS but there was none in stock at the time I was ordering, they both have similar specs just the BLS is a bit faster.
Thanks, I'm looking to replace my Savox 1258TG with Sanwa SRG-CS or SRG-CT. I'm running the MT-4 and its rx, so trying to stay with same brand might help? Also looking to move to LRP or NOSTRAM, where they claim 6V BEC
I'm just not happy with running glitch buster or adding an external BEC. Cheers,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 07-24-2012, 12:34 AM   #962
eevul's Avatar
Originally Posted by onekiwi View Post
What radios are you all using? There may be something with the radios and not just the servo. I I've been using the sav÷x low profile servo and spektrum system for a long while now without problems.
Using a KO Radio and here. I just got a brand new ESC back from LRP and it was indeed a blown BEC. I'll have to see how long this one lasts. Great customer service so far.
eevul is offline   Reply With Quote
Old 07-24-2012, 08:06 AM   #963
onekiwi's Avatar
Doesn,t the new lrp flow esc look good!
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 07-28-2012, 06:58 PM   #964
wa7ash's Avatar
Trader Rating: 37 (100%+)
not much difference from the previous one.
Xray | Muchmore | Sanwa | Orion | G-Force | Scorpion | Fantom
wa7ash is offline   Reply With Quote
Old 08-06-2012, 02:52 PM   #965
AJSanDiego's Avatar
Looking for some help and couldn't find the specifics in previous posts. I am getting ready to use this ESC with a Thunder Power Z3R 17.5. what are some good starting points when looking at small asphalt tracks? My son currently runs a Hobywing Xerun 60A and a Tekin 17.5 with an FDR of 3.53 (39/69) and temps ~150f (no fan) after a 7 min run. Used to relying on a laptop so the configuration on the LRP is new to me. We run the blinky - non-boosted class. Thanks in advance!
AJSanDiego is offline   Reply With Quote
Old 08-06-2012, 03:05 PM   #966
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
I hate to say it guys but im leaving LRP.... im tired of the esc dying on me... this will be the second time and its frustrating that my $68 esc performs better then my $220 esc!!! It just stopped working on me in the middle of qualifier on a track made for short course and 10 scale.... i am truly disappointed in the product! Just being truthful!!
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 08-14-2012, 10:54 AM   #967
onekiwi's Avatar
How can I tell if the BEC is Kaputtski on the SXX TC?
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 08-14-2012, 10:56 AM   #968
defcone's Avatar
Trader Rating: 15 (100%+)
How can I tell if the BEC is Kaputtski?
Your receiver won't turn on, or it turns off when you're at full throttle.
defcone is offline   Reply With Quote
Old 08-14-2012, 11:16 AM   #969
RussF's Avatar
Trader Rating: 21 (100%+)
The ESC says "LRP" on the top. J/K
but seriously:
What defcone says is right. If it is failing, a way to test the BEC it is to plug a receiver pack into the battery port on the receiver and test again. If it works with the receiver pack and not without it then the BEC is bad.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 08-14-2012, 11:22 AM   #970
onekiwi's Avatar
but seriously:
What am I testing? That the servo works etc? Esc turns on?
Mines working and Im using it atm and it seems to me there is no problem, but I heard that it could be bust.
Im thinking not as its all working
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 08-14-2012, 11:25 AM   #971
RussF's Avatar
If it aint broke dont fix it.
If the ESC is working and you see no problems then I would say its fine.
If you do have problems with it shutting off at full power or not turning on the receiver then the BEC could be bad.
If you have the above symptoms then the test with the receiver pack would tell you if its the BEC that is the problem.
Old 08-14-2012, 11:29 AM   #972
onekiwi's Avatar
Nice thanks
No one really likes the LRP stuff where I race and they keep trashing it, I was getting a little worried. One of the guys blew a sale of one of mine cos he started saying that there a lot of problems with them.
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 08-14-2012, 12:17 PM   #973
defcone's Avatar
Nice thanks
Just saw where you're from, just give it to a sheep if it won't eat it then it's bad
Old 08-14-2012, 02:26 PM   #974
RussF's Avatar
Nice thanks
Aside from the initial failure and extra long replacement time to get a new one I have really liked my Stock Spec ESC as far as performance.
The LRP is my first brushless ESC for 1/10 car and I like the way it works. I was just bummed that it stopped the first time I ran it.
I bought a replacement to hold me over when mine initially failed. I think the guy I bought it from had already had it replaced by LRP.
So far both are working nicely (knock on wood). I would'nt listen to your buddies when clearly yours is working fine. Go out there and woop up on em on the race track!!
Old 08-21-2012, 01:16 AM   #975
Jochim_18's Avatar
So I'm assuming my BEC is blown on my stock spec V2 when plug in to my receiver it won't power up but when i unplug it was fine..Can I just bypass it and just hook and a receiver pack to power up my servo... I was thinking if I can getaway with the receiver pack might as well just use on my 1/12 scale any thought?
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
