LRP SXX StockSpec V2 ESC
#916
do you know if you can load the lrp ssx v2 stock software into a tc spec speedo v2 with the usb lead?
#917
#920
Guest
7.5 boosted
Ok guys I'm getting my 5 yr old in the hobby so test and tune for my car is pretty much out the window. I'll be running boosted mild mod motor but not sure if I'm close. Here's what I got:
-Novak Ballistic 7.5 w/40 deg motor timing
-Mode#2 profile 6
-Mode#3 profile 6
-112 spur 29 pinion=7.72 FDR
-Outdoor asphalt 100'+ long 50'+ wide.
Note: I haven't ran this yet.
Any pointers would be great.
-Mode#2 profile 6
-Mode#3 profile 6
#921
-Mode#2 profile 6
-Mode#3 profile 6
-Mode#2 profile 6
-Mode#3 profile 6
#922
Heres my track
About 80m straight and after 8 minutes I have esc at 90°C and motor 80°C
Motor is a LRP x12 8.5T with 000 insert
Esc SXX V2 not the TC version
83/25
settings 1360
Can the motor/esc run ok with these temps?
I am/have mounted a fan now and am thinking about changing to the TC version
83/25
settings 1360
#923
Heres my track
83/25
settings 1360
83/25
settings 1360
#924
I have made up a fan holder, its the non TC model so doesn't have the cooling fins and place for the fan....
This esc
OR is there a set I can buy, cooling fins, heatsink paste/tape and add them or does the case of the TC spec hold down the cooling fins
Something like this anyone know of other types from other brands maybe
thermal glue on the bay... where do I get a good heatsink that fits then? The Ko one?
This esc
#925
hi all, im having a problem with this LRP Stockspec ver.2, Firmware V. 4.4
Serpent T.E 104/38 FDR: 5.47
Motor: X12 7.5T with 3 Dot
Temp: 124 Degrees (after run 5 min)
Mode 1: #3 (2s 6.8V)
Mode 2: #0
Mode 3: #1
Mode 4: #0
*running really fast, but having a problem with temp, anyone can help me?
Mode 2: #0
Mode 3: #1
Mode 4: #0
#927
#930
SXX upgrade
Does anyone have an idea on launch date? with Worlds coming up would think it would available by now?
Cheers
Cheers
