Old 03-26-2012, 11:59 PM   #871
No, it seems like LRP didn't upgrade the hardware but only the case. You definately have a V1 Speedo in your hands. Sould describe your problem and send it back to Tower Hobbies or the LRP distributor.
As stated before all V2 speedos (4.2 and 4.4) have 12 profiles on Mode 3 whereas the V1 only has 10.
bonda is offline   Reply With Quote
Old 03-28-2012, 02:56 AM   #872
Originally Posted by cwalsh View Post
Can someone tell me what the difference is between the usb bridge I bought with my esc and the New LRP USB Bridge Spec.2? It looks the same as what i have just not sure what the deal is.
Sean or anyone know about this? Saw it advertised on Red R/C.
cwalsh is offline   Reply With Quote
Old 03-28-2012, 10:48 AM   #873
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
i would like to know also
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 03-29-2012, 10:30 PM   #874
Trader Rating: 16 (100%+)
Default Received replacement SXX stock spec
Just received my replacement SXX STOCK SPEC V2. They told me I was on 120 on the waiting list. I was wondering if anyone else got their and does anyone know if they have the upgraded BEC?
Losi SCTE - Tekin RX8 Tekin pro 4
Losi 22 17.5
A929ryda is offline   Reply With Quote
Old 03-30-2012, 06:34 AM   #875
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Wow.... i just sent mine in for repairs i guess it will be like christmas an unexpected package....lol i hope their service has improved for $200 spent!
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 04-01-2012, 12:55 AM   #876
numnut862's Avatar
HI GUYS I WAS SEEING IF ANY ONE HAD A SETUP FOR AN SXX STOCK SPEC WITH AN LRP X12 21.5
I RUN ON A MEDIUM SIZED TRACK WITH A DECENT SIZE STRAIGHT ON ASPHALT
I TRIED SOME SETTINGS TODAY FDR 4.750 0,5,11,0 00 insert LACKED A BIT OF PUNCH temp 54 degrees
ANY IDEA'S PLEASE
numnut862 is offline   Reply With Quote
Old 04-03-2012, 09:15 AM   #877
Default 2wd off road?
can one of these last in a 2wd off road vehicle? a Losi 22?
Old 04-03-2012, 09:23 AM   #878
briankstan's Avatar
Pretty sure it was my BEC that failed on my SSX Stock Spec V2 the night before our State Championship race in my WGT 10.5 CRC, lucky for me I was able to get receiver LiFE battery and still compete. these are nice ESC's but this BEC issues is a real problem for such and expensive piece of electronics.
Not sure if it's even worth sending in, I'll just run it with the LiFE Battery from here on out. I've heard they have a plug and play board that will be available sometime as they know it's a real issue.
www.slmini-zstore.com
www.saltlakemini-z.com/forum
www.howfastareyou.com
briankstan is offline   Reply With Quote
Old 04-06-2012, 10:10 PM   #879
Nuno Gancho's Avatar
Hello do anyone may provide a setting and final gear for below speedo and motors
speedo settings LRP stock speck V2 with
Motors with final gear and timming
9.5 X12 LRP for small track
13.5 trinity for a small track
thanks.
Nuno Gancho is offline   Reply With Quote
Old 04-07-2012, 10:05 PM   #880
bvoltz's Avatar
Trader Rating: 44 (100%+)
thanks.
Depending on the motor, but a starting point for 13.5 4.25 temp after 2 mins and just gearing. (I would assume you will be down around 4.1 to 4.0)
9.5 - 7.2 but this is my best guess based on what you have provided... Again, check the temp on the motor....
bvoltz is offline   Reply With Quote
Old 04-09-2012, 04:31 PM   #881
Trader Rating: 114 (100%+)
Question...
I have a LRP SXX StockSpec v2. I want to run blinky mode.
do I have to have Mode 2 AND Mode 3 set to zero? or JUST Mode 3 set to Zero?
Would like an honest answer before I open the package on this thing.
Thanks.
Chris
Chris Furman is offline   Reply With Quote
Old 04-09-2012, 04:36 PM   #882
geeunit1014's Avatar
Both must be 0 for blinky mode
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 04-14-2012, 03:41 PM   #883
Trader Rating: 17 (100%+)
Send a message via ICQ to chief1476 Send a message via Yahoo to chief1476
Looking for a good starting point for 8.5 reedy. First time running this low of turn motor and not sure where to start on gearing or what to program on the esc. I will be running on asphalt track, the dimensions of the track is 160x80
YOKOMO/WHERE IS BAG 11?
chief1476 is offline   Reply With Quote
Old 04-16-2012, 07:40 AM   #884
Anyone? I love this speedo but the support for it is not very good.
Old 04-16-2012, 08:58 AM   #885
Are you running it on a stock spec? If so, id go 0 (blinky) throttle profile, and 2 boost
Mike Gee
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
