Old 03-13-2012, 06:58 PM   #856
NR
NR's Avatar
Trader Rating: 52 (100%+)
I have a question guys,
I have a Nosram Pearl Evolution 2, and will be running blink stock in 2wd off road.
Will this be exactly the same profile as running blink in a stock spec speedo?
Or do I need to get a stock spec to be competitive?
NR is offline   Reply With Quote
Old 03-13-2012, 07:27 PM   #857
AE-Reedy
There should be no difference between the two. Blinky mode operates the same in both SCs.
Sean Cochran is offline   Reply With Quote
Old 03-19-2012, 11:44 PM   #858
bigz's Avatar
This is a long shot but here goes. I know that nosram and lrp have almost the same components. But there is a software update in the nosram website about the pearl v2 series. Will there be any improvement as far as speed is concerned if i will update the software for me stock spec esc? Have any of you guys tried this new software with your lrp stock esc's?
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 03-21-2012, 11:18 AM   #859
bvoltz's Avatar
Trader Rating: 44 (100%+)
What is the difference between:
- LRP SXX Stock Spec "Version 2" Competition Brushless Speed Control w/MK III Firmware
and
- LRP SXX TC-Spec "Version 2" Competition Brushless ESC
Thanks in advance....
bvoltz is offline   Reply With Quote
Old 03-21-2012, 12:51 PM   #860
geeunit1014's Avatar
and
The Stock Spec has more aggressive throttle and boost profiles, aimed at stock racing. The TC Spec has smoother throttle profiles, and milder boost profiles, that are better for mod racing.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 03-21-2012, 01:38 PM   #861
bvoltz's Avatar
With 17.5 running in Blinky mode.... Does it really matter to have the Stock Spec? Just asking....
Old 03-21-2012, 02:19 PM   #862
I would rather have the Stock Spec for the drag brake. The drag brake values are different on the 2 esc's. I had to run 10 on my TC Spec in 17.5 blinky, and I run 7 on my Stock Spec. So you have a wider range of drag brake values with the Stock Spec.
Mike Gee
Old 03-21-2012, 03:38 PM   #863
bvoltz's Avatar
Many thanks... I would perfer to have one Speedo that covers it all, but I think that is out of the question with today's setups....
Old 03-22-2012, 03:20 AM   #864
onekiwi's Avatar
How do you factory reset the speedo?
LRP sxx V2
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 03-22-2012, 07:33 AM   #865
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
LRP sxx V2
Transmitter on
hold Set button
switch on esc
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-25-2012, 09:45 AM   #866
Can someone tell me what the difference is between the usb bridge I bought with my esc and the New LRP USB Bridge Spec.2? It looks the same as what i have just not sure what the deal is.
cwalsh is offline   Reply With Quote
Old 03-25-2012, 10:12 AM   #867
The_Punisher's Avatar
Default v4.4
Is there a new manual for the 4.4 firmware like the other firmwares that lrp came out with? The reason I ask this I bought a new stockspec V2 in february, and it will not connect with my USB bridge! (I have tried multiple sensor cables and have double checked those cables on my tc spec v2 and it connects everytime) I have talked to LRP in california and they led me to assume I already have the 4.4 firmware installed. So my question in does the 4.4 firmware only have 10 settings in mode 3 instead of 12 as shown in the original manual?
The_Punisher is offline   Reply With Quote
Old 03-25-2012, 11:39 AM   #868
Sounds that you have got a SXX SS V1. The V2 speedo always has 12 profiles in mode 3.
You could do the following, to prove that it's a V1. Set Mode 2 to anything from 1 to 10 (i believe the V1 doesn't have a 0 setting at Mode 2) and Mode 3 to 0. If the speedo does the Zero Boost blue led flashing in neutral then it's a V1. With the V2 speedo Mode 2 and 3 have to be set to 0 to get the Zero Boost LED flashing.
bonda is offline   Reply With Quote
Old 03-25-2012, 01:46 PM   #869
Is there a LRP speedo that's not legal for blindly?
RugRunner is offline   Reply With Quote
Old 03-26-2012, 02:27 PM   #870
The esc was purchased new from tower hobbies, and also has version 2 right on the heatsink. So does 4.4 firmware have a seperate manual? and yes the blue led blinks in neutral when mode 3 is set to 0 regardless of where mode 2 is set.
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
