Old 03-04-2012, 06:39 PM   #841
AE-Reedy
Originally Posted by JamieV View Post
Not sure if any one has had this problem but my stock spec keeps going into non-boosted run part way through a race. Can happen even after a couple of minutes in.
I checked the temps from the blue flashes and the speedo had 1 flash but the motor had 9. The motor was barely hot though (50 degrees)
I thought it only thermalled out to unboosted if you had 10 flashes. Very suprised I got 9 flashes though as my settings aren't outrageous?
My settings for a 13.5 GM were 3,6,10,0 and I tried 3,4,8,0 but it made no difference. FDR was 6.5
Any help much appreciated
It's possible the SC is getting bad info from the motor temp sensor. Try switching lipo cut off to zero flash and this will disable the over heat safety. If the stoppage is due to over heat then it should go away.
Sean Cochran is offline   Reply With Quote
Old 03-05-2012, 02:03 AM   #842
I did try 2 motors - happened on both (both GM). I think I will call LRP
Thanks for the tip
JamieV is offline   Reply With Quote
Old 03-05-2012, 07:58 AM   #843
D.Martijn's Avatar
Originally Posted by RedBullFiXX View Post
27T brushed motor will be a bit slower than a good 17.5 with the correct gearing.
If you use full boost, you will be closed to mod speed.
Unless you are running same fixed gear as 27T ?
so,
what numbers should I choose for the settings 2 and 3?
Do you have a starting point?
my gearing is 81spir and 24pinoin
should i chance it or?
thanks
D.Martijn is offline   Reply With Quote
Old 03-05-2012, 02:37 PM   #844
Thanks for the tip
Keep us posted on what they say..thx!!
mhavlena is offline   Reply With Quote
Old 03-05-2012, 03:16 PM   #845
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by D.Martijn View Post
so,
thanks
I dunno.
As I only have experience with 12th scale.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-05-2012, 08:33 PM   #846
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Default trouble with esc
hey guys i purchased one of these esc from some on here who had good feedback, i got it today hooked it up in my car and tried to mesh it with the controller...but nothing no led lights on the esc or receiver... i changed the battery both fully charged and working on my other vehicles.
Wires are solder solid, any trouble shooting ideas?
or do i need to send it in for repair? if so whats the normal cost?
Real pissed right now!
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 03-05-2012, 09:58 PM   #847
Default Some help for a newbie!
Hey guys is there anyone who could do a repair send in for me, i bought this off here and i don't ave the original receipt and don't want to out 150.... I'm a good guy just looking for a little help i will pay any fees and give you $25 for the trouble!
Thank you and please help a fellow RC'er!
Its a SSX Stock Spec V2 model number 80915
Old 03-06-2012, 11:05 AM   #848
Default Any help???????
Really want to race, anyone with a heart? i will cover all shipping fees....
Or if you don't mind emailing me a copy of a receipt i can use that.....im just strapped for cash on this one guys
blackstarracing@live.com
Thank you
Daryl
Old 03-06-2012, 03:36 PM   #849
Default Never mind!
Thank you
Daryl
Just bought a new....continue your thread!
Old 03-06-2012, 05:54 PM   #850
Trader Rating: 213 (100%+)
Make sure the plug is in proper position, and if you have a receiver pack, try using that plugged into the receiver and turn it on with that. It could be that the BEC failed and so it should still work using a receiver pack. Happened to me with a New one out of the box awhile back.
Andy Koback is offline   Reply With Quote
Old 03-06-2012, 07:12 PM   #851
hey guy i just notice my compaster was dented in should i put a new on or just leave it i didnt notice and issue while in use wat u guys think thx
reedy126 is offline   Reply With Quote
Old 03-09-2012, 06:18 AM   #852
FunkyDunky's Avatar
All,
I'm new to the LRP products and wondered if you could answer a couple of newbie questions?
Can the SXX Stock Spec V2 software be loaded onto an SXX TC Spec V2?
Is there a difference and is it worth doing? I mainly run 21.5 or 13.5 so every RPM counts
Cheers
FunkyDunky is offline   Reply With Quote
Old 03-09-2012, 01:32 PM   #853
Losiho's Avatar
Originally Posted by FunkyDunky View Post
All,
Cheers
I assume you mean can you load firmware updates for the stock spec via the LRP USB bridge device ? If so, the answer is no, the updater will recognise it is the wrong firmware for that ESC.
Losiho is offline   Reply With Quote
Old 03-09-2012, 03:19 PM   #854
Default wiring question
i know that the middle or B wire is important but is it also important on the SSX Stock that the A&C connection must go accordingly on a LRP x12 or can this two be interchangeable?
Old 03-12-2012, 11:25 AM   #855
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
Anyone have a good starting point for the SXX SS V2 and a D3 13.5 in a Xray X10 WGT. Gear ratio right now is 36/88, tires 55mm, and the battery is a Reedy 6500 65C 1S. Track is 36x70, Ive been try for months and the car is just plain slow, should i switch to a X12 13.5? Thanks
CR Performance Custom RC Parts (PM for details)
Colin Roussel
2013/2014 WCICS CTA Champ
Awesomatix | Roche | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
