Old 02-21-2012, 12:26 PM   #826
Losiho's Avatar
Originally Posted by mhavlena View Post
I'm currently using S/W v4.4 in my SXX stock spec V2. Can someone tell me whether this new S/W v2.0.4 is an update to v4.4?
or am I mixing up S/W with Firmware? Am I using the latest with v4.4?
mhavlena was referring to the new download software from LRP. Different to the ESC firmware.
V4.4 is still the latest firmware for the Stockspec ESC.
Losiho is offline   Reply With Quote
Old 02-21-2012, 01:06 PM   #827
AE-Reedy
2.0.4 is the interface SW that is used on the computer to communicate with the SC. v4.4 is the firmware that is loaded on the SC.
Sean Cochran is offline   Reply With Quote
Old 02-21-2012, 01:29 PM   #828
sprintcarracer's Avatar
Trader Rating: 25 (100%+)
Has anyone use the stock spec I 12th 17.5 blinky with a reciver pack.
sprintcarracer is offline   Reply With Quote
Old 02-24-2012, 08:42 AM   #829
RussF's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Marek Gadomski View Post
When it will be available to buy ?
A second question. Will you have to buy it? Or will it be the replacement? I sent my Stock Spec V2 back to Associated in December for a faulty BEC and am still waiting for a replacement. Hopefully the replacement I get will have the new logicboard installed since LRP recognizes a defect in thier V2 ESC's.
I qoute:
"This new logicboard was developed as the SXX Version2ís BEC, while extremely powerful, was unfortunately prone to malfunctions in certain applications and for sure not reliable enough."
RussF is offline   Reply With Quote
Old 02-28-2012, 10:55 AM   #830
The_Punisher's Avatar
I talked to LRP today and was told that I am on a waiting list to get my sxx comp v2 replaced, as they are waiting to get stock on the version with the new logicboard and better bec.
The_Punisher is offline   Reply With Quote
Old 02-28-2012, 11:34 AM   #831
RussF's Avatar
I got my Stock Spec back today Thanks AE. It appears to be brand new not refurbished. I asked if it included the new logic board and was told by the AE employee that he didnt think so becuase they hadnt got any updated boards yet.
Hopefully it doesnt have any of the same problems, as I am not planning on using it until I need to for either a backup or a new class.
Old 02-29-2012, 12:10 AM   #832
Trader Rating: 16 (100%+)
I was at the track and I installed my stock spec v2 ESC. I turned it on and it worked fine. I realized I had to bind my rx. I installed my bind plug, turned the esc switch on and nothing. The thing stopped working.
I have read a couple of pages back and know about the BEC issues but can installing a bind plug blow out the esc?
I will be sending it in once I find out the process.
Losi SCTE - Tekin RX8 Tekin pro 4
Losi 22 17.5
A929ryda is offline   Reply With Quote
Old 02-29-2012, 02:44 PM   #833
Trader Rating: 216 (100%+)
Try hooking up a receiver pack and turn it on. If it works, BEC failed. Happened to me with a Brand New one out of the box a while back.
Andy Koback is offline   Reply With Quote
Old 02-29-2012, 03:50 PM   #834
Thanks for the advice.
Losi 22 17.5
Old 03-03-2012, 05:46 AM   #835
D.Martijn's Avatar
Hi,
I wan't to run a lrp sxx stock spec V2 with a 17.5T brushless motor.
But I have to compete against 27T brushed, so I have to boost/time the motor
what number should I program?
Do you guys have any suggestions?
I'm kinda new to the brushless thing, I still ran brushed untill now :d
Thanks,
D.Martijn is offline   Reply With Quote
Old 03-03-2012, 08:03 AM   #836
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by D.Martijn View Post
Hi,
Thanks,
27T brushed motor will be a bit slower than a good 17.5 with the correct gearing.
If you use full boost, you will be closed to mod speed.
Unless you are running same fixed gear as 27T ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-04-2012, 09:52 AM   #837
syndr0me's Avatar
Trader Rating: 32 (100%+)
http://ets.redrc.net/2012/03/volker-...anaria-finals/
Nobody on the entire island had an LRP they could loan Ronald f'ing Volker?
Anyway, once the prototype is done destroying hopes and dreams, I hope it's fitted with a good case, solder posts, a better sensor wire location and a nicer capacitor solution. Otherwise it's great.
syndr0me is offline   Reply With Quote
Old 03-04-2012, 12:28 PM   #838
Default Speedo keeps thermalling ?
Not sure if any one has had this problem but my stock spec keeps going into non-boosted run part way through a race. Can happen even after a couple of minutes in.
I checked the temps from the blue flashes and the speedo had 1 flash but the motor had 9. The motor was barely hot though (50 degrees)
I thought it only thermalled out to unboosted if you had 10 flashes. Very suprised I got 9 flashes though as my settings aren't outrageous?
My settings for a 13.5 GM were 3,6,10,0 and I tried 3,4,8,0 but it made no difference. FDR was 6.5
Any help much appreciated
JamieV is offline   Reply With Quote
Old 03-04-2012, 03:25 PM   #839
haywood's Avatar
Trader Rating: 48 (100%+)
Can't believe that!
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 03-04-2012, 06:10 PM   #840
Mine kept thermalling (thus shutting down) the other day...motor temp never reach 120 deg C. Got fed up and switched it out for another brand ESC, problem went away....not sure whether the ESC is busted or not...
mhavlena is offline   Reply With Quote
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
