Old 10-24-2011, 08:55 PM   #721
mode 4 is set at 0 as I do not want any auto brake function, but I have very little brake when applied by pushing trigger forward
TcORC vice pres
Yokomo bd7 sedan, bd7 usgt
Roche rapide p12
magnum is offline   Reply With Quote
Old 10-25-2011, 10:51 PM   #722
Trader Rating: 125 (100%+)
Angry
Originally Posted by jpcopeland1 View Post
Had mine do the shut off. Sent it in and got a brand new one a week later. AEs support is top notch.
Well it happened again. Blinky mode, 17.5 stock timing and the speed control shuts off. Once was bearable, 2nd time in under 3 months is inexcusable. On top of that I wantched a friend of mine have 2 brand new TC Spec V2's die within 2 hours of each other. LRP has some serious issues with their V2 line of TC, Stock Spec speed controls. I am switching to Orion after I get this one back from repair, I will demand it be a new one, and will not spend the money to ship it to AE. They can pick up the tab this time.
LRH Raceway, Cal Raceway, TQ Raceway, Futaba, Schurr Speed, Orion.
jpcopeland1 is offline   Reply With Quote
Old 10-26-2011, 07:19 PM   #723
Trader Rating: 120 (100%+)
Ok, I am running a LRP x12 17.5 with 1S rotor, LRP SXX V2, and new 65c 1S Lipo (1/12th CRC car) and after 2 minutes it seems the lipo is starting to dump and the power is just not there. I have tried different lipos and it did not really help. Motor is coming off at 138 after 6 minutes and we are running in blinky mode. Do you have to gear this setup in a different temp range to get better run times? Any suggestions would be great.
22-4
MBX7R Eco, RC8B3E
MBX7R. RC8B3
JoeC is offline   Reply With Quote
Old 10-26-2011, 07:25 PM   #724
GCT69's Avatar
Gear up,:O
GCT69 is offline   Reply With Quote
Old 10-26-2011, 07:35 PM   #725
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
What is your roll.
What size track, and type of surface
Which timing insert ?
It is helpful to give more info when asking these questions.
Otherwise you will receive random answers.
In general you don't gear blinky 12th for temp, it's all about the best avg laps for 8 mins.
The best 8 min run time, will always be the best setup, regardless of the motor temp.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-28-2011, 11:56 AM   #726
cheehtae's Avatar
Trader Rating: 15 (100%+)
What's a good C rating battery to use for this speed control, it's for a 1s 17.5 blinky 12th scale. wil a 28c be just fine or do I have to go to a higher rating?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 10-29-2011, 10:28 AM   #727
hogmansp's Avatar
Trader Rating: 47 (100%+)
SXX v2. What is the preffered or correct way for installing a RX pack for 1/12th 1s setup as far as wiring it in. Wire direct to RX and pull the red wire out of the ESC lead or wire into switch like a tekin? Thanks
Losi 22 revtech
Kyosho SC-R Big Bores revtech
hogmansp is offline   Reply With Quote
Old 10-29-2011, 10:59 AM   #728
No need for RX pack, the sxxV2 works with 1s.
Serpent 733 EVO
966 EVO
S120LT
TEMsport is offline   Reply With Quote
Old 10-29-2011, 12:33 PM   #729
hogmansp's Avatar
Working with JoeC on his 1/12th and want to try an rx pack.
Losi 22 revtech
Old 10-29-2011, 12:48 PM   #730
Infinite 12th's Avatar
Here is the LRP manual info
Look for AutoCell System 2 & TwinBEC (Mode.1) for how they suggest to work with pack
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 10-31-2011, 02:29 PM   #731
Can anyone comment on the differences between the stock black capacitor and the silver "works team" capacitor(s)?
I have the Stock Spec w/ the latest firmware... will be using it in 17.5 blinky sedan.
JamesL_71 is offline   Reply With Quote
Old 11-01-2011, 04:23 PM   #732
Buckaroo's Avatar
I was wondering the same thing. Is there any advantage to running the optional capacitors?
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 11-01-2011, 06:02 PM   #733
AE-Reedy
Running the Works capacitor in a class that you run mostly full throttle will not make a noticeable difference. I do like that they are easier to mount in tight areas.
Sean Cochran is offline   Reply With Quote
Old 11-01-2011, 08:34 PM   #734
cheehtae's Avatar
what's the latest firmware for this?
Old 11-01-2011, 10:56 PM   #735
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
What's a good starting point for a LRP X12 17.5 boosted Ratio 1.9 with LRP SXX stock spec for my 1/10 on road
THANK YOU
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 09:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 09:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 11:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 05:15 AM
SEO by vBSEO 3.5.0
