Old 10-19-2011, 12:35 PM   #706
Originally Posted by RedBullFiXX View Post
The SXX Stock Spec is the only LRP v1 with built in 1s v-booster.
All the v2 have this.
Thank you RedBull, the esc is the TC v1 I guess that is not the right one for 1/12?
gofasteddy is offline   Reply With Quote
Old 10-19-2011, 12:39 PM   #707
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
It will work, but you will need a 1s booster, or receiver pack.
A few of the Team AE drivers were using the v2 TC esc at the iic race.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-20-2011, 03:07 PM   #708
UrabusDenis's Avatar
Hello guys !
Will LRP/Nosram introduce a new ESC and motor for 2012 ? More specifically , can I buy my ESC and 10,5T motor now and be sure I will have top specifications for 2012 ?
UrabusDenis is offline   Reply With Quote
Old 10-22-2011, 10:22 AM   #709
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
Hello.
I need a little help. I will be changing my wires from my SXX V2 speed control to black. Should I stick with the 12GA or 13GA? The motors I will run is a 13.5 and 17.5
Thanks.
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 10-22-2011, 10:33 PM   #710
eevul's Avatar
Hi guys. I just picked up one of these ESC and I am looking for a base setup for a CRC WGT. Track size is similar size to the IIC. I am new to the WGT and really new to this LRP ESC. I will be running 33-36 pinion and 88 spur. What is a good starting point for this ESC?
eevul is offline   Reply With Quote
Old 10-23-2011, 07:54 AM   #711
Buckaroo's Avatar
OK, I'm a little confused. Which ESC would work best for boosted 12th, a base SXX, Stock Spec, or TC? Which would work best for blinky TC?
Obviously, a V2 and the latest firmware!
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 10-23-2011, 08:10 AM   #712
Originally Posted by entitymugenmtx View Post
Hello.
Thanks.
16g for spec motors is plenty.
Depends on the motor brand, are you running boost or blinky ?
With a MurfDogg on 90x45 carpet, we run 86roll on blinky mode.
The SXX Stock Spec is the only LRP for boosting spec motors.
The TC and Comp are for mod or blinky
Not sure which firmware is the best for boosted pan car yet.
Maybe Sean from AE can chime in with some info here.
Old 10-23-2011, 08:51 AM   #713
eevul's Avatar
Sorry, I forgot to state that I am running the Vector K4 Brushless Motor - 13.5T in boosted classes. I'm not sure if this combo will be the right choice.
Old 10-23-2011, 09:57 AM   #714
Buckaroo's Avatar
For X12 motors (17.5, 13.5), start with the 4 dot timing insert? All others start at the 0 mark?
Tom Keith
Old 10-23-2011, 10:06 AM   #715
Teambcw's Avatar
Trader Rating: 28 (100%+)
does anyone have a bad version 2 tc or stock spec I can buy or have? I have been trying to repair the bad ones.... haven't had any luck yet ...haha but it is sure fun trying, please send me a pm. Thank you!!!
Teambcw is offline   Reply With Quote
Old 10-24-2011, 11:42 AM   #716
Francis M.'s Avatar
Trouble shooting...
My SXX stock spec v2 has been cutting of on me as in No power to the motor but still has power to turn the steering and fans running on the speedo.
I will not get any power from the Motor until I turn the speedo off and turn it on again....
I've switched motors and sensor wires and still the same problem.
Francis M. is offline   Reply With Quote
Old 10-24-2011, 03:17 PM   #717
Joven M's Avatar
Originally Posted by Francis M. View Post
Trouble shooting...
Hey Francis. I had the same problem with the Kinetic ESC. I had to turn on the car first then the radio. I didn't know the LRP has that same problem. Give that a try. If that's the case, I would try another receiver. Worst comes to worse, Pop the esc in someone else's car to see if you have a problem with the radio system. Hope that helps.
ARC USA / Maclan-Racing / ActivRC
Joven M is offline   Reply With Quote
Old 10-24-2011, 03:43 PM   #718
Francis M.'s Avatar
Thanks for the Tip Joven, I'm ready to try anything right about now!
Old 10-24-2011, 06:37 PM   #719
my ecs seems to be lacking in the line of brakes. is this the way they are , or did I miss something in setting it up
TcORC president
Yokomo bd7 sedan, bd7 usgt
Roche rapide p12
magnum is offline   Reply With Quote
Old 10-24-2011, 07:34 PM   #720
Infinite 12th's Avatar
What class are you racing and what mode 4 setting for brake did you use?
0-0-0-?
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
