Old 10-11-2011, 11:37 PM   #691
BoneCrusher's Avatar
Question,
Have a SXX stockspec V2 running a 10.5 in 12th. Been having glitching problems. I am still using a 75mhz FM though. Decided to plug a 6.6 volt Life receiver pack in and everything seems to work fine. This most likely means my servo is somehow drawing too much. I can continue using this setup but would a capacitor plugged into my reciever instead of using the Life reciever pack work?
Thanks,
Ivan
ARC R10, 12R5.1, Tamiya Mini, MTS FFv2 Pro, Exotek F1
carcar.ca
BoneCrusher is offline   Reply With Quote
Old 10-12-2011, 01:30 AM   #692
Mitch-e4fs's Avatar
Originally Posted by BoneCrusher View Post
Question,
Thanks,
Ivan
Hey mate i'm just setting my v2 stock speck up for 1/12 scale. What are your settings for 10.5?
This is my first LRP and i bought it second hand so no manual.
Mitch-e4fs is offline   Reply With Quote
Old 10-12-2011, 06:52 AM   #693
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Here's a copy of the manual from the LRP page.
http://www.rctech.net/forum/attachme...e-100519fv.pdf
Roll out will vary depending on type of motor and track size.
I should think 45-50mm would be close for a 90' x 45' indoor surface.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-16-2011, 02:59 AM   #694
roger999's Avatar
hi, just wanted to know, can somebody tell me about LRP SXX TC Spec 80950. I can buy it in good price, but dont really know about it. Now using Hobbywing 120a and just want to have 2 speedos. Motor 10.5. Thanks
r o g e r g r a f i x . c o m
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 10-16-2011, 07:40 AM   #695
LMRacing's Avatar
Trader Rating: 27 (100%+)
Question,
Thanks,
Ivan
If your using a Savox Servo this is a common problem and they recomend that you use a power cap with there 1256,1257, and 1258 servos. They tend to pull a little more juice than a standard servo and will cause some rx's to glitch by pulling the voltage too low in the rx. Either build your own powercap or I recomend the Racers Edge GlitchBuster as there by far the cheapest on the market that I have found and there all about the same
LMRacing is offline   Reply With Quote
Old 10-16-2011, 09:00 AM   #696
Tommy mac's Avatar
Send a message via Yahoo to Tommy mac
Originally Posted by AGLE View Post
The Version 2 TC speedo does have a built in booster, so it should be fine with 1 cell, but just make sure you have the voltage cut off set right. You want to have the first setting, set to either 0 (no cut off) or 1 (3 volts cut off). If this is set any other number, then the speedo will shut down as the 1 cell will not be giving it enough voltage to stop the speed thinking it has reached it's minium voltage
Thanks, Looks as if the bec is blown can't get it to do anything when I switch it back to 2c either.
Tommy mac is offline   Reply With Quote
Old 10-16-2011, 06:11 PM   #697
bought a stock spec and it worked fine, bought the bridge to check and see if was 4.2 or 4.4 it was 4.4. now the mode and set buttons do nothing! any ideas? all I did was check the version
TcORC president
Yokomo bd7 sedan, bd7 usgt
Roche rapide p12
magnum is offline   Reply With Quote
Old 10-16-2011, 06:14 PM   #698
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
did you press the disconnect button before you removed it from the speed control
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 10-16-2011, 06:45 PM   #699
Trader Rating: 213 (100%+)
If you think the BEC is done, hook it up with a receiver pack and it should work. That'll bypass the internal BEC. This happened to mine. Ended up sending it back for repairs.
Andy Koback is offline   Reply With Quote
Old 10-16-2011, 07:00 PM   #700
yes
TcORC president
Roche rapide p12
Old 10-17-2011, 08:07 AM   #701
I want to get into 1/12 and a friend have a new SXX the fisrt version for sale and want to know do I need a booster for 1c?
gofasteddy is offline   Reply With Quote
Old 10-17-2011, 08:52 AM   #702
The SXX Stock Spec is the only LRP v1 with built in 1s v-booster.
All the v2 have this.
Old 10-18-2011, 03:59 PM   #703
Hi,
Would anyone have rollout and Esc settings for X11 10.5 on blinky in 12th?
I know an X12 would be better but funds don't allow at the moment.
Tom
TEMsport is offline   Reply With Quote
Old 10-19-2011, 08:28 AM   #704
mtbboy's Avatar
Default Rookie question
Hey Guys,
Just got the usb bridge.
I have the sxx v2 (not tc spec).
I have hit a minor road block,
In step 2 of the update process the program wants me to enter the "file name" which is blank.
Uhhh What am I to enter here?
Thanks.
Dave.
mtbboy is offline   Reply With Quote
Old 10-19-2011, 10:07 AM   #705
Infinite 12th's Avatar
Since this speedo is used on mod and .5 classes what is a good starting point for 13.5/17.5
Would they be different?
How do the lrp guys with this stock/spec speedo feel they do in comparison in 13.5/17.5 classes against the Tekin guys?
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
