Old 10-10-2011, 10:10 AM   #676
Trader Rating: 3 (80%+)
Default HELP
guys I need some help,I am totaly new to lrp ss and i am using in 1/12.My problam is that my speedo is flat on the bottom.My friends speedo(same 1) is much much faster before the boost hits than mine is.I have tried 2 brand new units to the same result.when testing between my friends and mine we used the exact same settings,rollout,wiring,sensor wiring etc. The only diff between mine and his is hes using ko radio and i use futaba,me a D3 motor(tried many diff endbell timing) and his a old orca/1stgen speedpasion no timing.his hauls but!!Ive check updates with bridge and its current 4.4. Ive re-calibrated many times, nothing. Please any help or suggestion would be great,thanks
traitor is offline   Reply With Quote
Old 10-10-2011, 11:22 AM   #677
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Can we assume you have and LRP SXXSS ? v1 or v2 ?
To find the proper rollout for your motor I would suggest the baseline as listed in the instructions included with your esc, and work from there.
No endbell timing to start with.
LRP in general need a lot of rpm to work in the range they are designed for.
Gearing up or down a few teeth from the baseline should point you in the right direction for your track.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-10-2011, 11:28 AM   #678
masterhit's Avatar
Trader Rating: 14 (100%+)
Did you check his firmware version? In my experience, and lawdy I done did put allot of time into the lrp, the older firmware was better for spec boosted in 12th.
The timing ramped in much quicker on 4.2 which is key for 12th.
Mike
masterhit is offline   Reply With Quote
Old 10-10-2011, 12:40 PM   #679
hey thanks alot i didnt think too check his out to see what he has.Yes mine is the stock spec version 2 running 17.5 boosted,would i be able too download 4.2 and install if it is better for stock classes?Thanks again
Old 10-10-2011, 01:07 PM   #680
masterhit's Avatar
I could not find it on the LRP website. I do have it on my computer. PM me an email address and I will send it.
isn't it fun trying to tune with blinking lights having no clue what they represent for degrees or ramp rate, let alone across the different revisions?
Mike Slaughter
Old 10-10-2011, 01:21 PM   #681
pm sent thanks
Old 10-10-2011, 08:25 PM   #682
Tommy mac's Avatar
Send a message via Yahoo to Tommy mac
Default Problem with Tc Ver 2
I have a tc that is shutting down after 39% on the transmitter. I fact I can't Get it to program it in Blinky mode. Anyone have a thought on whats going on...
Btw, I am trying to use it in a 1 cell wgt car.
Thanks, Tom
Tommy mac is offline   Reply With Quote
Old 10-10-2011, 08:29 PM   #683
Thanks, Tom
I believe the Tc is not a 1s esc. Its hitting voltage cut off.
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 10-10-2011, 08:47 PM   #684
Tommy mac's Avatar
Old 10-11-2011, 12:28 AM   #685
DesertRat's Avatar
I've got a problem here, I took my Stock Spec which has performed great with no faults since I bought it and swapped a X12 7.5 turn motor onto it just for kicks, turned all of the settings back to blinky and was testing it for the first time with a fresh battery and it putted around just fine while I set the steering trim but when I gave it the first real rip of throttle and suddenly it just turned off. Didn't give a thermal warning or anything just off, darkness. I tried turning it off and back on, and nothing. No smoke, the speed control was cold, and I am very confused. I unpluged it and stuck a receiver pack in it to see if it twitched, and a red light came on, then nothing. Is there an email I can contact LRP at and get some answers? Its out of warranty and I wanted to use it in an upcoming race this next week.
I race toy cars for fun. If I need to explain, you'll never understand.
If everything is under control... go faster.
WTB: Carpet racing in Arizona.
It is obvious and intuitive to the most casual of observers that RC racing is better than golf.
DesertRat is offline   Reply With Quote
Old 10-11-2011, 09:22 AM   #686
mike ivy's Avatar
Trader Rating: 50 (100%+)
Any one have a 1c 1/12th setup for a D3 13.5 and a Revtech 13.5 running indoor carpet 84 spur 1.70" rear tire 100'x40'ish track
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 10-11-2011, 10:42 AM   #687
Here in the USA, you deal with Team Associated, not LRP.
They have been awesome to deal with on my end.
Old 10-11-2011, 10:45 AM   #688
Trader Rating: 125 (100%+)
Had mine do the shut off. Sent it in and got a brand new one a week later. AEs support is top notch.
LRH Raceway, Cal Raceway, TQ Raceway, Futaba, Schurr Speed, Orion.
jpcopeland1 is offline   Reply With Quote
Old 10-12-2011, 12:14 AM   #689
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
I need some help guys. I've been going back and forth on what speed control to buy. Tekin RS PRO or a LRP SXX V2 is there any perks with the LRP vs the Tekin?
Thanks once again.
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 10-12-2011, 12:24 AM   #690
Thanks, Tom
The Version 2 TC speedo does have a built in booster, so it should be fine with 1 cell, but just make sure you have the voltage cut off set right. You want to have the first setting, set to either 0 (no cut off) or 1 (3 volts cut off). If this is set any other number, then the speedo will shut down as the 1 cell will not be giving it enough voltage to stop the speed thinking it has reached it's minium voltage
AGLE is offline   Reply With Quote
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 09:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 09:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 11:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 05:15 AM
SEO by vBSEO 3.5.0
