Old 09-23-2011, 06:44 AM   #646
Originally Posted by Lohan View Post
How do I know if my speedo has 4.4 or 4.2 firmware?
I bought it at the beginning of august from RC market.
Secondly, is the lowdown that when using the x12 13.5 motor, one has to use a fan indoors?
You will need to connect your speedo to the computer with a usb bridge to tell what version of software it has on it
Smartypants is offline   Reply With Quote
Old 09-23-2011, 07:16 AM   #647
spencehotbodies's Avatar
Hello
Tarmac.
spencehotbodies is offline   Reply With Quote
Old 09-23-2011, 12:04 PM   #648
Weazsel's Avatar
Trader Rating: 57 (100%+)
Originally Posted by nitrobeast View Post
I've seen the competition one labeled for 12th scale racing. Is this because of it's size?
+1 Anybody know?
I was under the impression that the TC had much better suited boost profiles for on-road.
I hope I can use the comp being that I already have one!
Michael Garramone
Serpent America l Pro-Line l Protoform l TQ Wire
Weazsel is offline   Reply With Quote
Old 09-23-2011, 12:37 PM   #649
rc pete's Avatar
Originally Posted by Weazsel View Post
+1 Anybody know?
The TC and Comp profiles are the same (they run the same firmware).
The main difference is that the TC can handle lower wind motors and is intended for higher current applications, like TC Mod and 4WD Short Course mod.
The Comp is fine for 1/10 off-road mod and works for 1/12 mod too.
Some guys use the Stock Spec in 1/12 mod for a little more grunt.
If you're running anything 10.5 turn and higher with boost, you want the Stock Spec.
For non-boosted stock racing either version is fine, since they all have blinky mode.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 09-25-2011, 06:43 AM   #650
bigz's Avatar
how is this esc compared to the rs pro? are the temps the same? will there be issues saying i use 40c batts instead of the 60c's?
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 09-25-2011, 08:06 PM   #651
Trader Rating: 16 (94%+)
hey guys i need help i just got an ssx ss v2 and i put it in my b4 and did everyhting the manual said to do and after probably around one lap at the track the car will not let give it throttle but steering still works and the yellow and blue lights on the sc flash and i tried the things on the manual but no luck does anyone know whats happening?
perez62682 is offline   Reply With Quote
Old 09-26-2011, 08:15 AM   #652
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Anyone have the 17.5 boost profiles set up for 12th scale 1C lipo ?
med size track like the IIC...Thanks
OVA is offline   Reply With Quote
Old 09-26-2011, 02:09 PM   #653
Default that's about as useful as a motorcycle ashtray
No offence, but I would not have posted onto the forum, if that was the answer I would get.
I wanted to know if you could find out by reference to manufacturing date or serial number if it comes with 4.4 or 4.2 without shelling out on the USB bridge
can someone tell me the answer?
Lohan is offline   Reply With Quote
Old 09-26-2011, 03:19 PM   #654
Trader Rating: 213 (100%+)
I believe all SXX SS ESC's sold after April of this year has the new 4.4 firmware. The people in the UK were getting them back in March according to some of the past threads I found. Hope this helps! You could send a message to Sean Cochran @ assoc. and he'll tell you for sure.
Andy Koback is offline   Reply With Quote
Old 09-27-2011, 01:09 AM   #655
Default setting for x12 13.5
Hello
Am running torque-7 boost-3 and geared at 6, good stating point or is torque to high?
Cheers
Old 09-27-2011, 02:40 AM   #656
hi,
I am running 3-5-7-0 and 6,16FDR X12 13.5 on a big track
motor temp 80ēCelcius
esc temp 45ēCelcius
duartev is offline   Reply With Quote
Old 09-27-2011, 02:45 AM   #657
Default thnx
Thanks Andy - much appreciated
- much better than the previous answer
Old 09-27-2011, 03:47 AM   #658
Send a message via MSN to Emil
I do not know if this is correct but be advised that hobby shops may carry older stock. I bought two last month while in the US and they were both version 4.2.
Br. Emil
Emil is offline   Reply With Quote
Old 09-27-2011, 12:07 PM   #659
DesertRat's Avatar
What size are the two bearings in the X-12 motor? I want to order some new ones but I really don't know what to buy. I checked the manual but if it was listed it managed to evade me.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 09-27-2011, 02:41 PM   #660
Br. Emil
That's very true. There may be some old stock sitting on the shelves. Now with the USB Bridge, that can be updated at home without shipping it back.
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
