Old 09-10-2011, 03:27 PM   #616
Holmenkollen's Avatar
I have a new Nosram SSX2 TC-Spec and I´m using SP motors. My 4.5t wouldn´t even spin and my 4.0 would spin but sometimes it cogs and stalls. When I start to spin it by hand it comes alive. What´s happening? Had no problem whatsoever with my HW 120A speedo....
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 09-11-2011, 05:15 AM   #617
Anyone?
Old 09-11-2011, 08:49 AM   #618
Default Guideline to setting SXX VII esc...
Need some guideline from u guys. I've matching my SXX Version II ESC with 10.5 Dualsky Z5 motors. Normally i running at medium track about 150ft straight road. I tried several FDR & setting on the esc. Feels like the speed is very slow and most of other can overtake me very easy. Could anyone guide me what is the proper FDR & setting to make my car faster ??? Thanks in advance.
ckloo is offline   Reply With Quote
Old 09-12-2011, 04:33 AM   #619
spencehotbodies's Avatar
Default best 13.5 motor to run with lrp sxx v2
Hello
Best motor?
Cheers
spencehotbodies is offline   Reply With Quote
Old 09-12-2011, 05:00 AM   #620
caltek1's Avatar
Trader Rating: 36 (100%+)
Not sure if you have read the title to this thread correctly, however it is to do with the SXX V2 StockSpec ESC, not the mod versions. This ESC uses different SW to the TC Spec SXX V2.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 09-12-2011, 09:07 AM   #621
rc pete's Avatar
Something is very wrong. If it cogs on track, I'd suggest to go back to the recommended profile settings on the ESC and gearing from the manual.
But on the bench the motor should spin regardless of what settings you have.
Through a process of elimination, you should be able to determine whether it's the motor, battery, sensor wire, power wiring or if the ESC is simply not working with anything you hook up to it.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 09-12-2011, 11:46 AM   #622
DesertRat's Avatar
Originally Posted by spencehotbodies View Post
Hello
Best motor?
Cheers
Without a doubt in my mind the best motor to run with a SXX V2 speed control is the LRP X12. It has dedicated profiles for that motor, and mine works great.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 09-12-2011, 06:05 PM   #623
wa7ash's Avatar
Trader Rating: 37 (100%+)
Thumbs up
+1 Totally agree.
Xray | Muchmore | Sanwa | Orion | G-Force | Scorpion | Fantom
wa7ash is offline   Reply With Quote
Old 09-12-2011, 10:29 PM   #624
BoneCrusher's Avatar
Got this speedo back from a warranty exchange and it's been sitting in a box since. Would like to use it in my 12th scale. Anyone have a starting setup for a 17.5 boosted 12th scale class using an Orca Motor? Rollout? Just a good starting point would be great.
Thank you for your time,
Ivan
ARC R10, 12R5.1, Tamiya Mini, MTS FFv2 Pro, Exotek F1
carcar.ca
BoneCrusher is offline   Reply With Quote
Old 09-13-2011, 01:31 AM   #625
Old 09-14-2011, 05:04 PM   #626
I have had a weird occurrence with my sxx v2 speedo: after a 6 min. run in my tc the speedo would still power the motor as if I had the throttle applied at about 1/8 throttle= even when I was not touching the throttle at all, and it was in neutral. I recalibrated the speedo, and it has done this a couple of more times, but then stopped
Has anyone else had similar occurrences? If so any help would be appreciated. Happy Racin
NPETRO is offline   Reply With Quote
Old 09-14-2011, 06:30 PM   #627
Trader Rating: 25 (100%+)
Can someone please advise what the latest firmware upgrade does? I am trying to lower my speedo temp in 1/12 mod.
www.teamkellner.com
fred kellner is offline   Reply With Quote
Old 09-14-2011, 06:48 PM   #628
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I tested this esc with a 4.0 turn on a hooked up carpet track, 90x45' last weekend.
roll 29.5mm
esc temp @ 8 mins 145f
motor temp 110f
ambient temp 85f
Update v4.4
0-0-1-1
To be honest, I prefer the feel of the SXX Comp v2
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-15-2011, 03:18 AM   #629
Default Esc V2 in blinky mode
Plan to run this in my WGT at the IIC with a 13.5 in blinky mode X12 Motor with standard as it comes rotor.
Need a starting point on motor 2 dot,3 dot 4 dot. Plus rollout.
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 09-18-2011, 03:00 PM   #630
Default My problem too
I am having the same problem with the Corally Red 13.5 motor. I have tried shimming the motor, replacing the sensor wire, and trying out all the profiles.
From reading your post, I am getting the impression that this speedo only really works with the x12 motor - AKA A CLOSED LOOP
LRP have a lowsy habit of giving with one hand and taking away with another
I wish someone from LRP will have the decency in giving a decent response other than read the manual and change the motor - that's wat I usually get if I actually e-mail LRP.
thanks
Lohan is offline   Reply With Quote
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
