Old 08-22-2011, 09:45 AM   #571
MeBeMikey's Avatar
Originally Posted by AGLE View Post
Hi MeBeMikey,
the BRCA max voltage is 8.40v, and they are quite strict on that at National events, so if you plan on doing any Nationals, then I'd advise you to back your charger off a little!
Rule 3.9 LiPo/LiFe batteries may be charged to a maximum of:-
2S Batteries may be charged to a maximum of 8.40v (LiPo) resp. 7.40v (LiFe).
1S Batteries may be charged to a maximum of 4.20v (LiPo) resp. 3.70v (LiFe).
Just had confirmation about 8.44. In offroad they are strict and 8.4 is the max but in TC 8.44 is allowed due to charger variations. I posted it on my FaceBook and two different drivers, one who races for Hotbodies and one for Schumacher both said TC is 8.44.
Phew! I was worried and we both are right in the end!
Race for RC Disco in the UK
Xray T4'16, LRP Flow/ORCA 13.5
LRP everything but motor.
I would have Tekin if it connected to IPHONE!
MeBeMikey is offline   Reply With Quote
Old 08-22-2011, 10:23 AM   #572
I've just looked on the TC rules and you are correct, they seem to run to their own rules, not to the electric board rules like most other classes, so you are free to carry on with you 8.44 setting
Rule 4.3 Maximum voltage of 2S LiPos to not exceed 8.440 volts
at any time, and maximum voltage of 1S LiPos to not exceed 4.220 volts at any time.
AGLE is offline   Reply With Quote
Old 08-22-2011, 06:25 PM   #573
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default SXX V2
Originally Posted by Benzaah View Post
Well the fastest HW with D3 and Tekin with Novak could not catch the SXX V2 and D3 combo this weekend. Looks like its time to switch back to LRP again.
Benny boy..My car was FAST..and no fade....Seems the hand built motors and matched team cells are the go....
And it was cool...for me anyway..80 deg c after 5.30mins..Might have to take a smidge of timming out for the 6min run..
Love the SXX..best brakes and heaps of balls....and NO computer..
mikecatts is offline   Reply With Quote
Old 08-22-2011, 07:15 PM   #574
artwork's Avatar
Trader Rating: 56 (100%+)
Originally Posted by Marcos.J View Post
What's a good starting point for 17.5 boosted (touring car) and fdr
Stock Spec v4.4 with a LRP X12 4dot timing and I am running about 6.7 on a large carpet track. Also I have a fan on the motor!
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 08-23-2011, 03:49 AM   #575
Default 21.5 X12 IN F1
New class in Uk is looking like 2s ,21.5 boosted in 1/10th F1
car.
Looking for rollout for settings etc. It has been suggested 3,6,8,1 4 dot insert and rollout of 66mm.
Any further info or help would be appreciated.
Cells, Esc and motor all LRP car is the 3D F109 F1 car on foams large carpet track.
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 08-23-2011, 06:39 AM   #576
MeBeMikey's Avatar
Well, I'v put the LRP fan back on and I'm now able to do boost 9 and 11 on my X12 13.5 and have improved my fastest laptimes and almost got another lap! It took me a bit to get use to the new weight distribution.
I still don't like using fans but it did allow me to go a tiny bit faster. I'm also on 6.0 FDR.
Old 08-24-2011, 03:38 AM   #577
Any chance of esc settings and gearing
kingpops is offline   Reply With Quote
Old 08-24-2011, 11:07 AM   #578
mikecatts's Avatar
Default Settings
MMM..Cost me 2 motors and hours of track time...After FEMCA....
Old 08-24-2011, 06:47 PM   #579
Understood...
No issue for that race as I am in for the pain of MOD
Just for the clubbies for the rest of the year it will be nice not to feel the need to lug a pc around to every meet....
I have it dialed for the 21.5(X12) but would like to see a good 17.5 setup on it to!
Old 08-25-2011, 07:08 AM   #580
spencehotbodies's Avatar
Default SET UP FOR GRAUPNER 13.5 MOTOR
Hello
Any body got a set up for a 13.5 graupner motor?
Cheers
spencehotbodies is offline   Reply With Quote
Old 08-25-2011, 09:06 AM   #581
wa7ash's Avatar
Trader Rating: 37 (100%+)
Originally Posted by spencehotbodies View Post
Hello
Cheers
Just go back a few pages in this thread and you will see it.
Xray | Muchmore | Sanwa | Orion | G-Force | Scorpion | Fantom
wa7ash is offline   Reply With Quote
Old 08-27-2011, 01:34 PM   #582
Default two identical setups, extremely different results
Hi all.
I know this is the "on-road" forum for the SXX stockspc V2 (and I drive a 2WD buggy) but i think you guys might know the answer to my problem.
My buddy and I have the exact same car (b4), gearing 75/25, motor (LRP X-12 17.5) and the same ESC (LRP SXX Stockspec V2). We also have our settings the same on the ESC (3/1/1/1). This should be a very mild setup. Our radios are the exact same and we did the calibration the exact same way.
When I pull the throttle on my radio, I get a pretty gradual ramp up of speed and I feel some boost kick in at the end of the throttle curve. On my friends car, it feels WAY faster almost as if as soon as you pull the trigger, the car is almost at top speed (yes our throttle expo settings are both at 0) and then when you gun it all the way, the motor rips like a 5.5 turn mod motor and it almost blows the wheels off the rims.
I have no idea why they would be so different. Both have good drivetrains. New bearings, no binding. I wonder if maybe we have different firmware versions and one of them is set for a very aggressive default profile?
Any thoughts??
thanks!
Bryan
bryan562 is offline   Reply With Quote
Old 08-27-2011, 03:31 PM   #583
MeBeMikey's Avatar
Brian, Only way to tell is by hooking them up to a computer but it can also it can be your batteries, even if you have the same batteries too. Do you charge at same amps? You can try his battery or his charger to see if that is the difference.
Old 08-27-2011, 08:49 PM   #584
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
anyone know if you can change settings with the usb link? I am not a big fan of pecking lol.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 08-27-2011, 09:26 PM   #585
Johnny Wishbone's Avatar
Nope, straight firmware upgrade and version info is all you get.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
