Old 08-08-2011, 11:36 AM   #541
burito's Avatar
Yes, new software is OF COURSE compatible with Windows 64Bit systems too now...
Missed to mention this before.
Reto Koenig
burito is offline   Reply With Quote
Old 08-08-2011, 12:19 PM   #542
DesertRat's Avatar
For all of the non-believers out there, Stock Spec V2 when combined with the LRP X12 motor is NUTS for 13.5 1s lipo racing in pan car. Just CRAZY, with a 1/12 scale set a 50mm of rollout and a 32/80 gearing I clocked it at 45-47mph in a 90 foot long straightaway on Slow Ramp setting 9 (80% boost) with the 2-dot insert in the motor, yet runs at 120-125 degrees after 8 minutes. The troops aren't complaining (they know I'm not cheating) but they look at that thing and it just wows them at how much it pulls them on that short of a straight. Wows me to. Great investment, hope I never need to swap it out.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 08-14-2011, 10:50 PM   #543
JayBee's Avatar
Trader Rating: 31 (100%+)
Well I have a question.....
Can this speedo be used with the LRP X12 9.5turn boosted? And if so, on a large outdoor med. gripped/ mixed layout track, what would be a good starting point for speedo settings & fdr?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-15-2011, 08:56 AM   #544
DesertRat's Avatar
Put the boost and torque feel on setting ONE. If that doesn't feel fast enough, turn the boost to setting THREE, setting two (fast ramp) or any other even-number setting will probably burn the hell out of the motor.
Old 08-15-2011, 02:46 PM   #545
JayBee's Avatar
Thanks bud
Old 08-15-2011, 07:06 PM   #546
Trader Rating: 24 (100%+)
+1 stay away from the even numbers on the timing profile. There is no real performance gain and I creates super high motor temps.
Bonadona is offline   Reply With Quote
Old 08-16-2011, 03:16 AM   #547
MeBeMikey's Avatar
Originally Posted by duartev View Post
Hi,
have tried today, decrease pinion to 20T (84Tgear) and changed timing from ║║║║ to ║║║ and increased the boost to 7, but almost same times for lap, but a little bit of more speed exiting corners.
Should I increase the timing to ║║ and decrease the pinion to 18T?
New setup:
SXX StockSpec V2 (3-5-7-0)
LRP X12 13,5T (║║║) (65║Celcius) (it has a LRP fan)
chassis: T3, FDR: 7.98 (84/20t)
PS: other racer with same chassis and a GM esc and motor is 0,5s faster
Thanks for any advise
See if you can borrow a friends New Lipo, 50c or higher. Then run your car. I'v never gone higher than feel on 3, boost 7, 4 dot insert, and 5.2FDR! I'm trying 5.6 FDR. Not all lipos are the same and old ones lose punch.
To everyone:
Try slowing your car down to gain time in the infield. Hard to gain much time on the straight. Corner speed isn't always the electrics of your car. Sometimes it's the chassis. I also adjust my chassis for more corner speed.
Race for RC Disco in the UK
Xray T4'16, LRP Flow/ORCA 13.5
LRP everything but motor.
I would have Tekin if it connected to IPHONE!
MeBeMikey is offline   Reply With Quote
Old 08-16-2011, 04:49 AM   #548
AM03GT's Avatar
THANK YOU!
Associated // Reedy // Radiopost // XP Digital // Parma PSE // Integy
AM03GT is offline   Reply With Quote
Old 08-16-2011, 08:27 AM   #549
To everyone:
Hi, I will try that, but isn't 5.2 or 5.6 too mutch FDR?
Thanks for the help
duartev is offline   Reply With Quote
Old 08-16-2011, 04:27 PM   #550
MeBeMikey's Avatar
Thanks for the help
I ran 5.6 FDR and only laid down two fast laps in the A Heat and came in last out of 8...still faster than all those in the B tho. It's just too punchy. Switched to 5.1 and im right back up to 3rd in the heat. Tho the car felt sluggish it didn't show it in my lap times. It was smooth as butter and I like the ability to pull full throttle and the tyres don't lose traction. Also the ramping it does is quite cool. With this ESC you feel like you are going slow but when next to the Tekins I'm no slower.
5.2 I think might be the best. I didnt try it tonight. Oh, another rule of mine...if you have to run a fan to keep temps down you're not geared correctly. For any track with LrP x12 13.5, SSV2 and good batteries I always start at 5.0fdr and 3331 for small tracks and 3351 for large tracks. I drive quite smooth and dont crash much so when I run 3371 it could be why my temps are low. I also do lots of maintenance on my car too.
Charging at high amps helps punch ALOT too. I do 7-10amps to 8.44 (BRCA max). You would not believe the difference!
Old 08-18-2011, 03:27 AM   #551
Daniel W's Avatar
Hey Guys
LRP SXX Stock Spec V2 speed control
LRP X12 5.5t Octa Wind Motor
12th 1 Cell LiPo
My local track is very big 8th scale size 72 meter main straight
The car doesn`t have anoth topend speed.Is it possible to use boost on a modified motor(CLEARLY STATES IN MANUAL NOT TO !)as values are designed for stock spec motors.If not would changing to a LRP X12 10.5t stock spec motor + 1s rotor be competitive in a modified class when using boost geared accordingly.
5.5t-6.5t are the most commonly used motors
Hobbywing 1s ESC most commonly used speed control
Regards
Daniel W is offline   Reply With Quote
Old 08-18-2011, 07:05 AM   #552
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Daniel W View Post
Hey Guys
12th 1 Cell LiPo
Regards
Boost it.
Start with Mild boost and a lot of roll.
5.5 is fairly mild for 12th mod, unless it's a tight indoor circuit.
2 dot timing insert will help some also.
The 1s rotor will take away some punch and give more rpm.
Temp esc & motor after 4mins with any new settings.
Ideal is to have esc and motor at about the same temp after 8mins.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-18-2011, 10:14 AM   #553
DesertRat's Avatar
Hey Guys
12th 1 Cell LiPo
Regards
Yes, the first Boost setting should be fine with just a 5.5t and 1s setup, always slow-ramp and watch your temperature as you do practice laps a few at a time.
Old 08-19-2011, 04:41 AM   #554
spencehotbodies's Avatar
Default lrp with graupner 13.5 motor
Hello
Has any body run the sxx stock spec v2 with the graupner 13.5 motor?
the motor has lots of torque.
spencehotbodies is offline   Reply With Quote
Old 08-19-2011, 04:53 AM   #555
StevenOlsen's Avatar
Originally Posted by spencehotbodies View Post
Hello
boost or non boost ?
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
