Old 07-27-2011, 12:08 PM   #511
JayBee's Avatar
Trader Rating: 31 (100%+)
Anyone running the TeamPowers 17.5 with this esc? How does the FDR compare to the D3?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-27-2011, 04:31 PM   #512
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
Teampower motor gear smaller than D3
OVA is offline   Reply With Quote
Old 07-27-2011, 04:42 PM   #513
JayBee's Avatar
What does that mean Franko.....lower FDR or smaller pinion?
Old 07-27-2011, 05:24 PM   #514
OVA
OVA's Avatar
smaller teeth pinion gear
ps depending on what timming is set end bell
Old 07-28-2011, 03:39 PM   #515
Questions?? few questions
Just ordered my LRP SXX spec V2 from RC MART and am awaiting delivery.
1. Would a new one include the 4.4 firware, or do I need a USB link to get the latest 4.4 firware.
2. for a large sweeping track with a 45M straight, what setting should I use with an x12 13.5 motor
thanks
Lohan is offline   Reply With Quote
Old 07-30-2011, 01:35 AM   #516
MeBeMikey's Avatar
thanks
The best starting point for the X12 13.5 is 5.0fdr, Feel 3 and boost 1, 3 or 5, 4 dot insert and GOOD batteries. Try 3 first on boost and then go up or down to 1 or 5 depending on how it feels and temps. I do this and do very very well no matter where I go. It's even on LRP's website. I think the reason people say this doesn't work for them is because of their batteries lacking the punch needed, car maintenance or they are running settings too high. I loaned my new LRP 65c to a fellow friend, who is also on this message board, and he noticed more punch and less fade and he even did a faster lap than me! I use MooreSpeed 50c Lipos and charge to 8.44v (brca max) which also makes you a tad faster at the start. Also charging at a higher rate, say 10 amps (only on cells that can take it) will make you faster. Run slightly warm cells.
The only thing I adjust is the boost and feel from track to track. I might try a higher FDR to see what it feels like. Only because my friend could catch up to me on a few straights but on the infield i could pull it back in some areas. It's all swings and round abouts. Going to fast for me slows me down, driving smooth speeds me up.
Race for RC Disco in the UK
Xray T4'16, LRP Flow/ORCA 13.5
LRP everything but motor.
I would have Tekin if it connected to IPHONE!
MeBeMikey is offline   Reply With Quote
Old 07-30-2011, 01:50 AM   #517
MeBeMikey's Avatar
Originally Posted by Mikkel_R View Post
Hi Mike,
Yeah theyve changed the track more technical and tight, Ive geared up to 5.5 and raised the boost to level 5. Car pulls really well and max motor temp was 70'c. Best times for me is 21 laps in 304 with fastest lap at 13.68.
I might try that FDR w/13.5 x12. When you were using my LRP battery you could nose up on my tail! I have to say that was some of the 'funnest' racing I have done in a long time. All three of us in 21 laps 310.03 (you) 310.29 (10.5) 310.98(me) ...one of them being a 10.5 but that means nothing these days.
I also never laughed so much while racing with our scraps on the track. That only made the guy in front of us pull away for the win! LoL...also us saying 'sorry'...'whoops sorry' all the time cause we were driving door to door throughout.
Track was brill! My best was 21 302 w/ 3 minor scraps and I can see a 22 coming in qualifying. Not sure in a final Tho as the first lap is quite long. My fastest is 13.76...yah got me there!
Old 08-02-2011, 08:15 AM   #518
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Any good settings with a d3 13.5 tc sedan ?
Old 08-02-2011, 09:15 AM   #519
mutley001's Avatar
I've been running 3,7,11,0 with 8 degrees timing on the motor on a medium size carpet track in my mi4cx
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 08-02-2011, 10:20 AM   #520
Super Moderator
Marcos.J's Avatar
What Fdr?
Old 08-02-2011, 11:18 AM   #521
mutley001's Avatar
What Fdr?
Usually between 6.8 and 7.3 - the layout of our track changes every 6 weeks so changes depending on the layout
ARC R11 2017
ARC R10 2013
Team EAM
Old 08-02-2011, 03:31 PM   #522
corallyman's Avatar
Trader Rating: 99 (100%+)
Originally Posted by Sean Cochran View Post
There is no method to update SXX-SS from a Touch charger that I know of. You can update the firmware on your Touch though.
Thank You Sean Cochran and Team AE/LRP for helping with my recent equipment needs that I had. Outstanding customer service is alive and well.
Steve C.
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is online now   Reply With Quote
Old 08-03-2011, 09:47 PM   #523
Trader Rating: 24 (100%+)
I am testing this speedo vs. my tekin and am looking for a good starting point. I run on a 75'x40' carpet track and will be using the LRP 17.5 boosted. Any help on gearing, endbell timing (if any), and speedo settings will be a big help. I'm not looking for conservative, I'm looking for speed. I'm not too concerned with motor temps. around 200 deg. if performs for 6 minutes. Thanks in advance guys.
Bonadona is offline   Reply With Quote
Old 08-03-2011, 09:59 PM   #524
artwork's Avatar
Trader Rating: 60 (100%+)
I am running my Stock Spec V2 with the 4.4 software and my settings are as follows:
3-5-11-1
I am running a 31/105 with a 2.0 gear ratio which is about a 6.7 FDR. Four dot on the motor for timing seems to feel the best in the boosted classes. My motor comes off at about 160 with a really good fan for inside racing on a carpet track. Based on the size of the track this should get you close. I would run for about 2-3 minutes and temp the motor.
You will find that the LRP V2 SS speedo and the LRP motor are a really good combination. The power rips so hard on the bottom and has great pull down the straight. I find that the LRP will actually make your car easier to drive because of the smooth power delivery.
Hope this helps!
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 08-03-2011, 10:29 PM   #525
3-5-11-1
Hope this helps!
Artwork, thanks for the speedy reply. From what I have been reading on this thread that is right in line with what I thought. I am looking forward to testing the speedo mainly for the smooth feel and drivability of the LRP. I have run the sxx TC in mod and I already know how smooth it puts the power down, just looking for the same feel in stock. Thanks again and any other suggestions are greatly appreciated.
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
