Old 07-17-2011, 11:54 PM   #481
There seems to be a lot of problems with the lipo cutoff...with the answer just being,run a lower cutoff setting....so is there a fundamental problem with this or not????....anyone from LRP??
sunktothenutz is offline   Reply With Quote
Old 07-18-2011, 02:09 AM   #482
7.4v sounds right.
Do not forget that under load the battery voltage drops significantly, 6.6V under load may be 7.4V when you are not drawing any current.
7.4V rest load means that you have used around 80% of your 2S battery.
It is best that you do not go above that number on a frequent basis if you want your batteries to last.
taz00 is offline   Reply With Quote
Old 07-18-2011, 08:57 AM   #483
tazfam2's Avatar
Trader Rating: 39 (100%+)
has anyone ever run this esc in a sc10 shortcourse with good results running 17.5
tazfam2 is offline   Reply With Quote
Old 07-18-2011, 09:56 AM   #484
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
I'm sure it would work great. Super smooth and as much power as you want.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
Dane is offline   Reply With Quote
Old 07-18-2011, 03:13 PM   #485
Trader Rating: 213 (100%+)
Originally Posted by Andy Koback View Post
At least yours is working somewhat. I tried powering mine up for the first time today and when I turned the switch on to calibrate the radio, all I heard was a SNAP and nothing. No blue light, no sneeze etc...looks like back to the factory. And yes...battery was hooked up right!!! (1 cell Lipo) I thought all the issues were solved with the blue!
Things may not be as bleak as first expected. Seems the On/Off switch decided to take a dump. Hooked up a receiver pack and it came to life. Hope to get a new switch to fix the problem.
Andy Koback is offline   Reply With Quote
Old 07-19-2011, 05:16 PM   #486
Chris08527's Avatar
Trader Rating: 16 (100%+)
sure this has been asked before, but can't find it in the 30 plus pages . . .
has anyone done back to back comparison with the tekin rs in 17.5 blinky and what are your thoughts???
thanks
chris
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 07-19-2011, 06:34 PM   #487
After further testing recommended by S.C. @ Asc., The switch tested okay. The BEC is what took a dump! Gonna have to send it in afterall!!!
Old 07-20-2011, 02:24 PM   #488
mikecatts's Avatar
Trader Rating: 18 (95%+)
thanks
chris
Having run both..I like the LRP....Easy and it does keep up with the Tekins...
Takes a bit to get right, at least you do not need a computer...
Nice and smooth to drive, were as the Tekin seems to be very aggressive..
And.
Brilliant consistant braking with the LRP..
I run on a large, out door gas track, against Tekins, Hobby Wings, Novak's...Alls good....
Last race day..
In a final race..The top 4 cars were 1 second behind each other..
ESC positions were..
Hobby wing
Tekin
Hobby Wing
Lrp.(me). very close, tight racing.
On another note..Used the X12-17.5, 3 dot insert...at FDR of 4.7..3.4.11.1.
Used a D3...after much trying, took it slowly..ended up at roughly the same as the X12, which is 4.8 fdr, 8deg + timing on can (2 notches),will increas slowly if I need to..
3.8.10.1, when I went to 11 in mode 3..it was very, I mean patheticaly slow
Checked the "blinks" just to make sure.....Put back to 10...and soooo much better, 9 in mode 3 no good, no top end........and roughly the same temps and runs/feels pretty well the same as the X12????? Will have a better idea come race day.
Dumps at 4.30, same as X12. using the New "LRP FAT COBRAS" and the New REVTECH'S.....
The FAT COBRAS are better than the revtech's..way more initial punch...
mikecatts is offline   Reply With Quote
Old 07-21-2011, 06:04 AM   #489
GFT
Default Help on updating firmware
Dear All,
I need help! I heard from a driver in Bangkok. Thailand that you can actually update the LRP SXX Stock Spec V2 firmware via the LRP Pulsar Touch. I do not know how to do it. Can anyone help please. I do not have the LRP USB bridge. Thank you in advance.
leon
GFT is offline   Reply With Quote
Old 07-21-2011, 06:35 AM   #490
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
what is the commont settings for the ver.2 12th 13.5 1cell, i have been using 0,9,6,0 and it ok just wondering if anyone has a better one
Old 07-21-2011, 08:41 AM   #491
1,5,6,0
Steve Dunn
Indianapolis, IN USA
sdunnmcp is offline   Reply With Quote
Old 07-21-2011, 08:41 AM   #492
1,5,6,0 with lrp 13.5
Steve Dunn
Old 07-21-2011, 09:45 AM   #493
AE-Reedy
Originally Posted by GFT View Post
Dear All,
leon
There is no method to update SXX-SS from a Touch charger that I know of. You can update the firmware on your Touch though.
Sean Cochran is offline   Reply With Quote
Old 07-21-2011, 10:38 AM   #494
Company Representative
Trader Rating: 15 (100%+)
thanks
chris
When I switched back in Feb from a Tekin RS to a LRP SS I saw a big difference in performance, Im a pretty consistent driver and the time I was putting into my racing at the track made for a very stable program to test new stuff. ( twice a week, 8 hours each day) I knew the track like the back of my hand and had turned 1000's of laps.
Overall top speed is on par with the Tekin in Blinky mode, the advantage I see is in the braking and acceleration. both are so smooth. We have 4 braking points on the track, with the Tekin you could get it right sometimes but not always. With the LRP it really made me confident in my braking. The other place I noticed improvement was in acceleration. There is a tight "kink" section of the track. With the Tekin you would try to apply power but it just was not there. ( mid throttle) with the LRP you could see the car accelerate in that section of the track.
Overall my consistently improved due to the above and my fastest lap dropped a 10Th.. That might not seem like much, but over a 6 minute race it makes a huge difference.
Hope this helps
WCICS- Competition Director
Korgae is offline   Reply With Quote
Old 07-23-2011, 08:51 AM   #495
MeBeMikey's Avatar
Originally Posted by Mikkel_R View Post
Hi Mikey,
Have you been to Ardent today? If so what were your TQ times on the new track?
I Havnt been for a while. Have they changed the track again? If it's the track that was used for the 24 hour race I think I was doing constant 24's in the 310 area.
If they made a new track I'm quite excited to run there again soon as I have just made some changes to my car that gives it very good on power steering that pulls hard and fast in corners.
The track I raced at was Rugby. Very small track.
Race for RC Disco in the UK
Xray T4'16, LRP Flow/ORCA 13.5
LRP everything but motor.
I would have Tekin if it connected to IPHONE!
MeBeMikey is offline   Reply With Quote
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
