Old 06-26-2011, 02:42 AM   #451
Gav-'s Avatar
Brand new V2 with 4.4 software.
X12 17.5 motor, 4 dot timing.
Std sensor wire that came with it.
LRP 5000 batteries, and ThunderPower 5200.
Re-flashed speedie multiple times. Any gearing.... whether it's coming off at 50C, or 90C. Low settings high settings, odd's or evens...
And as for run time, it was battery.... It would spike the battery below the cutoff on the speedie, and just stop.
Over it... moved on to a diff brand.
Gav- is offline   Reply With Quote
Old 06-26-2011, 03:18 AM   #452
MeBeMikey's Avatar
Totally know where you are coming from. It took a lot for me to come back to LRP. Another faulter by LRP would upset me quite a bit. I must have spent 1500-1700 pounds on their products over the past 5 years. Every car I have run during that time Has run an LRP ESC. Only one to die on me and the SS v1 is good for using zero timing. 200 pounds in UK i paid for the SS v1! That's 320 dollars! Yes, I'm an American in the UK.
Race for RC Disco in the UK
Xray T4'16, LRP Flow/ORCA 13.5
LRP everything but motor.
I would have Tekin if it connected to IPHONE!
MeBeMikey is offline   Reply With Quote
Old 06-26-2011, 04:16 PM   #453
Trader Rating: 213 (100%+)
Where can the Bridge Link be gotten from?
Andy Koback is offline   Reply With Quote
Old 06-26-2011, 04:20 PM   #454
MeBeMikey's Avatar
Best thing is to do a search for the item number on the web. I got mine the moment I saw it in stock here in the UK. They are out of stock there now.
Old 06-26-2011, 04:34 PM   #455
Thanks! Will keep looking.
Old 06-26-2011, 04:46 PM   #456
MeBeMikey's Avatar
Or post on your clubs website or other clubs websites or even FBook to see if you can borrow one. I was going to borrow one but I could never meet up on the same day as the guy who had the USB adapter.
The power of FBook is very good to find someone.
Old 06-26-2011, 05:19 PM   #457
Stormer Hobbies has them!
Old 06-29-2011, 10:06 AM   #458
MeBeMikey's Avatar
Goin racing on a large track tonight which is very technical and medium grip. I am going to start on 3131. Should be perfect. Or I will do 3111.
Old 06-29-2011, 01:40 PM   #459
JayBee's Avatar
Trader Rating: 31 (100%+)
Has anyone teamed up an X-12 17.5 w/a SXX StockSpec Version2 in BLINKY MODE running TC's? Whats the best motor/rotor/endbell timing combo w/that speedo? Or is the D3 a better combo? Large track w/med. grip.....
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-29-2011, 03:10 PM   #460
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Jb I did combo SS V2 with LRP17.5 at the reedy races..it is as fast as the D3....The lrp motor get alittle warmer than D3.( came off the tracl at 230 deg.) yike .seem to me the LRP got bottm end torque than D3
OVA is offline   Reply With Quote
Old 06-29-2011, 03:23 PM   #461
MeBeMikey's Avatar
3131 was perfect! I needed more control on the infield and less speed on the long straight. It was nice and smooth and very easy to control.
Old 06-29-2011, 03:29 PM   #462
JayBee's Avatar
Any other details.....like motor timing (3 dot for example), size of rotor, gearing?
Anyone else have some experience with this that they would like to share?
Old 06-29-2011, 03:35 PM   #463
OVA
OVA's Avatar
I did the full timing and it was too much...work better on 4 dot timing stock rotor..gearing no sure
Old 06-29-2011, 04:03 PM   #464
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Just got my replacement V2 (Thanks to Sean
How can you guys tell if you have the latest software (4.4)?
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 06-29-2011, 05:44 PM   #465
I believe once you hook it up with the bridge to your pc, it'll tell you what firmware is in there.
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
