Old 05-15-2011, 05:33 PM   #361
B4james's Avatar
Yeah I tried the D3 with some timing but it was getting fade towards the end of the run in that configuration. I didn't end up running the thunder power as I hadn't had enough track time with it and it was a little doughy out of corners which I am sure can be rectified with some more testing
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 05-15-2011, 05:38 PM   #362
B4james's Avatar
I am also testing the speed passion 17.5 V3 motors this weekend so will hopefully have some base settings I can post up from that
Old 05-15-2011, 08:00 PM   #363
JimmyMac's Avatar
A little doughy huh, is it the red stock rotor in the ThunderPower? I might have forgotten to mention that I'm running the Green Rotor. I may have to try the D3 then. Oh one other thought, is Zero timing in the D3 zero timing? Or is it 30? I'm not sure on the ThunderPower either. Do a quick bench test. Put the timing on zero on the ThunderPower and see if the boost kicks in. Then add timing and check it then. Then toss in the D3 and do the same. See what happens. Thats how I found out about the ThunderPower.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 05-21-2011, 05:14 PM   #364
JimmyMac's Avatar
Got to run today again. Did a little more testing.
Air temp was 84 F. Track temp was 116 F.
Track size, 17.5 boosted ran lap times of high 19 and low 20 second.
Motor was the ThunderPower 17.5 with Green Rotor and 15 endbell timing.
My starting profile was 0/10/12/3 with 5.5 final. I switched to 0/10/7/3. But forgot that Mode 3 profile 7 was for the LRP motor. It was dog slow on the straight. So I switched to 0/10/11/3. It was still slow on the straight because the boost kicked in too late. Motor temps were hovering around 160's to 170's degree F after a 6 minute run. I ended up back to profile 12. I ran 0/10/12/4. But this time I change my gearing. I went with 6.5 final. Motor temp was about 170s to 180s. So keep an eye on motor temp if you run that profile with that final. The gearing change definitely helped out. It let the motor rev up and boost to kick in sooner. I think I may try 0/10/10/4 but with more motor timing and see what that does. Or dropping the teeth on the pinion even more. We'll see. The LRP seems to have more bottom end than the Tekins, but less top end. Still working on that.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 05-21-2011, 06:57 PM   #365
Trader Rating: 5 (86%+)
Default stock settings for lrp ss v2
I am running stock tc...what are the settings for the speedo..meaning how high can i go on mode 2 and 3 to keep it legal blinky mode.
obi wun is offline   Reply With Quote
Old 05-22-2011, 01:42 AM   #366
Mode's 2 & 3 must be on 0 for blinky mode.
S.A.W is offline   Reply With Quote
Old 05-22-2011, 08:13 PM   #367
Trader Rating: 19 (100%+)
hi guys, i just got a tc spec sxx speedo for mod touring car and was wandering if anybody could post the profiles that it has and what features they all have? and in anybodies opinion which one is the best for mod with a 4.5t motor. Thanks
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 05-22-2011, 09:36 PM   #368
Scott B's Avatar
Trader Rating: 43 (100%+)
Google, its your friend!!!
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 05-24-2011, 08:49 PM   #369
JimmyMac's Avatar
I didn't do too much testing this past weekend. I kept the 6.5 gearing. But I changed my profile from 0/10/12/4 to 0/10/10/1. The air temp was high 80s to low 90s F. Track temp was around 120~130 F. My TP 17.5 with Green rotor had a temp of 160~170 F after a 6 minute qualifier on a 15~16 second lap technical parking lot track. For the main I went with 0/10/12/1 with same gearing and ended up with temps of 170~180 F. Motor timing stayed at 15. When doing this setup, always practice and check temps at the 2 and 4 minute marks so that you don't fry anything. Oh, I wasn't running a heat sink or motor fan either.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 05-24-2011, 11:31 PM   #370
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by burito View Post
We use thick copper boards, in order to minimse losses and get maximum performance, but that indeed results in the fact that power wires are a bit harder to solder if a "weak" soldering-station/-iron is used.
Also there is a reason why we don't use solder posts, which is the fact that solderposts increase losses, direct connection to the PCB like it is realised on the SXX is best for performance.
Out of curiosity, would you trade a little bit of performance for easier solderabilty (right word?)?
Sorry to dig this up again but I was rewiring my sxx last night and I had this thought.
Reto,
Would it be possible/sensible to have the PCB holes open on one side in a U shape like the X12 motors instead of having closed holes? It would be a lot easier to solder that way and I'm guessing there would not be any significant loss
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 05-25-2011, 02:25 AM   #371
Trader Rating: 15 (100%+)
Reto,
good thought like the way you think
jay m is offline   Reply With Quote
Old 05-25-2011, 04:29 PM   #372
andrew-01's Avatar
Trader Rating: 22 (100%+)
Anyone have some good base settings(esc and roll out) for boosted 17.5(LRPx12) 1/12th pan car on carpet(under 100ft)?
ANDRXW.com
andrew-01 is offline   Reply With Quote
Old 05-25-2011, 06:10 PM   #373
JimmyMac's Avatar
Look in the SXX V2 setup thread.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 05-25-2011, 06:14 PM   #374
andrew-01's Avatar
Edit....Never mind.
Didn't see people were making more threads vs posting in this one.
ANDRXW.com
Old 05-26-2011, 07:02 AM   #375
Edit....Never mind.
I posted on the other thread for you.
davidl is offline   Reply With Quote
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
