Old 05-01-2011, 10:54 AM   #346
Hi guys, anyone can test this speedo with a lrp x12 10.5 turns?
I need setups with a short and long tracks.
Thanks, Alex.
alejandrospeed is offline   Reply With Quote
Old 05-02-2011, 06:37 AM   #347
what is the difference from the ssx ss and the sss sx mk3? is the mk3 have the update? And thats it?
http://www.speedtechrc.com/store/ebp...id=918&id=9174
http://www.speedtechrc.com/store/ebp...d=918&id=11202
WEEZY is offline   Reply With Quote
Old 05-02-2011, 06:45 AM   #348
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
SXXSS v2 is what you want.
The mkIII was an update to the older v1 hardware which has been discontinued.
And yes, in most cases the LRP can run with any of the boosted esc's, when setup, and geared properly.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 05-05-2011, 10:01 AM   #349
Hi,
I'm running this speedo with a X12 (13.5t) and not sure if I need to gear down alot ? Today I tried,
3,3,3,0 5.98 Temp 59C
3,3,4,0 5.98 Temp 80C
3,3,4,0 6.37 Temp 79C
3,3,4,0 6.21 Temp 82C
3,3,4,0 6.61 Temp 81C
So I'm not sure what to do, gear down even more ? no point in putting boost to 5 as it will just add more heat.
Thanks.
S.A.W is offline   Reply With Quote
Old 05-05-2011, 10:11 AM   #350
All those temps are fine with that motor!
So what was fastest?
Originally Posted by S.A.W View Post
Hi,
Thanks.
008-Racer is offline   Reply With Quote
Old 05-05-2011, 10:46 AM   #351
AE-Reedy
Hi,
Thanks.
I'm going to assume this was on an out door track?
Which firmware, 4.2 or 4.4? 4.4 will lower motor temps significantly.
My thought is you are not running enough boost or you are under geared for what you used. Running 2s I do not recommend using even boost numbers. Fast ramps create more heat and generally are not faster on the track, plus they are harder to drive.
I ran TC 13.5 but on indoor carpet, went back and forth between boost 5 and 7, gearing was 6.2. Had more power than the track could hold and motor temps were usually 70-75c
Sean Cochran is offline   Reply With Quote
Old 05-05-2011, 11:55 AM   #352
No idea, I was on my own
4.4 and yes an outdoor track with a 45m straight. Shall I try gearing back upto 5.98 and more boost then ?
Old 05-10-2011, 07:49 AM   #353
B4james's Avatar
Has anyone tried a Thunder power 17.5 with this speedy yet in Boosted TC, and if so what did you find as a good starting point?
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 05-10-2011, 03:09 PM   #354
terryh's Avatar
Hi,
Thanks.
Running on an indoor carpet track with 4.4 (30mx14m) i tried 3-5-7-1 with the 2 dot insert and geared at an FDR of 8.0! Temp after a 5 minute run was 64c using a fan on the motor.
The car was very fast but did start to lose speed to early on the straight, I think somewhere between 7 - 7.5fdr would have been better, I will also try turning the boost setting up to 9.
I have tried the even numbered boost settings, and as Sean has already said, it dosn't make the car any faster, it just makes the car more difficult to drive and creates heat.
terryh is offline   Reply With Quote
Old 05-10-2011, 06:06 PM   #355
JimmyMac's Avatar
I'm running this combo right now. Just got it, so I'm learning it. One thing is, you must run endbell timing. If you do not, the esc boost will not kick in. So it will be like you are in blinky mode. My current setup is 0/10/12/3. Endbell timing is 15 with my gearing at 5.56. After a 6 minute run on a track with 16-17 sec lap times and air temp of 80 F, no motor fan... Motor temp was 180 F. I'm still learning what Mode 3 does, but that might be a start for you. If you are scared of the motor temp, try a fan or try 0/10/10/3. Hope this helps. Like I said, I'm still learning this esc. I just got it a week or so ago.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 05-10-2011, 06:36 PM   #356
B4james's Avatar
Thanks Jimmy, Have you had the opportunity to compare speed and lap times against othe combos and if so how did it compare ?
Old 05-15-2011, 03:33 PM   #357
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default Esc
mikecatts is offline   Reply With Quote
Old 05-15-2011, 04:21 PM   #358
syndr0me's Avatar
Trader Rating: 32 (100%+)
So you ran max settings while overgeared for far too long without checking temperature, and you're mad at LRP for your cooked motor?
If you'd gone to profile 10 instead of 12, you would have cooked a motor too. The even profiles for mode 3 are fast ramp, and are entirely different than the odd profiles that are slow ramp. Stick to odd profiles for 2S applications. Or, better yet, stop trying new ESC's if you can't be bothered to learn about them, or follow common sense when testing new settings.
syndr0me is offline   Reply With Quote
Old 05-15-2011, 04:35 PM   #359
B4james's Avatar
I ran the Nosram version with 4.4 and a D3 on the weekend at the Muchmore masters event in Sydney Australia. All the competitors agreed that this was probably one of the closest stock events for some time and the speedy and motor combo was fantastic.
I qualified 2nd overall with some fastest laps in certain rounds and the speedy was so smooth and drivable that it made it feel slow but the times were saying it wasn't.
I ran 0-9-12-0 and ran the D3 with zero timing and an FDR of 5:3 in a T3-11, also ran the new Nosram 6200 65C. Air temps were around 19-20c and the pace of the event meant everyone was pushing extremely hard. I felt I did not lack anything against Tekin, HW, Speed Passion, Kinetics and ORCA which were all in use in the A Main
Old 05-15-2011, 05:27 PM   #360
JimmyMac's Avatar
B4james, I haven't had a chance to run this ESC with other motors. Running against Tekins has not been a problem once I got the boost to kick in. Good to hear you got it working with the D3. I have yet to try one. Interesting to hear that it worked with zero timing. Running the ThunderPower with zero timing didn't work too good. No boost. The Tekin guys would zip by me like I was standing still on the straight. I didn't get to race this past weekend (damn customs held on to my shipment to fix my car!). But I'll do some more testing this coming weekend.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
