Old 04-14-2011, 07:08 PM   #301
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Has anyone used this with non-lrp motor yet?
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
Dane is offline   Reply With Quote
Old 04-14-2011, 07:16 PM   #302
bhambrent's Avatar
bhambrent is offline   Reply With Quote
Old 04-15-2011, 08:48 AM   #303
Trader Rating: 45 (100%+)
Originally Posted by RedBullFiXX View Post
Did you re-calibrate after the update ?
Yes, re-calibrated after the update.
Apex is offline   Reply With Quote
Old 04-15-2011, 09:52 AM   #304
wtcc's Avatar
Has someone experience with this esc in combination with the X11 (blue color) motors. I want to use it in my TC5 with a X11 7.5t. My idea is to go with 8.0:1 gearing on a big outdoor track for 1/8 cars. Is that too slow?
wtcc is offline   Reply With Quote
Old 04-16-2011, 07:46 AM   #305
Tron's Avatar
Trader Rating: 16 (100%+)
I use this with a Thunder Power and a Ballistic motor, both work flawlessly.
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 04-16-2011, 11:11 AM   #306
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
yes fantom ion 3 17.5 5.0 fdr o timing on motor with 0-10-12-4 140 degrees after 5 minutes very fast
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 04-16-2011, 11:49 PM   #307
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Default Update Error
Why I was updating my LRP from 4.2 too 4.4, it seemed to fail and asked me to restart
Now whenever I connect to the ESC it just tells me to check cables and turn off esc and now all the lights are flashing...
Can anyone tell me how to get round this??
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 04-17-2011, 01:08 AM   #308
Daniel W's Avatar
Hi Guys
I have just received my LRP SXX SS V2 ESC and the USB Bridge Firmware Update.
I`ve previously been using a LRP SXX TC Spec V1 with great success never had any issues always run with flawless performance.Also using the LRP X12
So I recieved the SXX SS V2 this week. I have been reading through this forum about how great they are. I downloaded the Software off the LRP website no issues there.
Being very excited when I recieved the speedo I couldn`t wait to check things out. I didn`t install it in the car straight away instead I tried to update the firmware from 4.2-4.4 connected speedo to computer went through the
steps
(Connect to Speed Control Yes gave me the serial number etc)
(Open Firmware File Yes opened no issues)
(Update Firmware on Speed Control Yes Started update progress about half way through it stopped Speed Control Error)
I thought maybe I needed to go through the setup programming. All connected up in the car I did this today switched on transmitter connect battery to speed control switched on ESC and the RED-YELLOW&BLUE lights flicker madly and the motor cogs really badly.Then they stop flickering they stay illuminated and the motor runs on. I can`t enter the programming of the esc either. The ESC & WIRES get quite hot (45deg Celsius)
If anyone has any idea what is happening here please let me know. My next step is to send it back to LRP for Repair.
Regards Daniel
Daniel W is offline   Reply With Quote
Old 04-17-2011, 03:07 AM   #309
Originally Posted by Daniel W View Post
Hi Guys
steps
Regards Daniel
Disconnect everything and start all over. Make sure you get asuccessful update before you start using the esc.
Old 04-17-2011, 04:37 AM   #310
Daniel W's Avatar
Hi Guys
Ok i`ve done as Apex suggested. No Difference
Unistall LRP Firmware Software from Computer.
Downloaded successfully again.
Bring the Software page up on my screen.
Connect ESC through hall-sensor port.
Press OK
USB Firmware Bridge blue LED on
Press Connect to Speed Control Then the orange LED comes on(USB Bridge)
ESC Red LCD constant glow
ESC Yellow Flicking LED
ESC Blue Flicking LED
Then this pops up with a error ding
Communication Error
Speed Control is not responding!
Old 04-17-2011, 06:56 AM   #311
Hi Guys
Press OK
Communication Error
Are you using a laptop or a desktop? If laptop make sure you are using ac power and not battery when doing the upgrade.
Old 04-17-2011, 08:03 AM   #312
Vicko's Avatar
Trader Rating: 14 (100%+)
I was updating my speedo when my comp lock up now the speedo dose not work at all and when I hook it up to the comp it says it dose not see the speedo.. anyone had this issue before??
Vicko is offline   Reply With Quote
Old 04-17-2011, 12:33 PM   #313
Hi wondering if anyone is using this speedo for 17.5 no-timing (blinky-mode).
Any reviews on how it performs compared to the Tekin RS in blinky mode?
I'd also like to try running it with the X12-17.5. Any idea on gearing and timing dot to run? Most guys at my track are running an RS with D3 and are fast. Wondering if the LRP can hang.
Electro-MAX RC is offline   Reply With Quote
Old 04-17-2011, 02:38 PM   #314
Daniel W's Avatar
Hi Apex
I`m just using a desktop i will try another computer today to see if this helps
Old 04-17-2011, 03:09 PM   #315
Me_MrTyson's Avatar
Hi Guys
steps
Regards Daniel
Thinking we all have the same problem, if you fail in the update process the ESC is broken..
Have a feeling the only way forward is to send it back to factory AGAIN to fix the situation.
Unless someone has an idea how to factory reset the SXX? the software will not connect to the ESC any more it just flashes
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
