Old 04-07-2011, 01:22 PM   #256
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
I also noticed going to 5.0 fdr in 17.5 actually lowered temps from 5.9fdr,seems gearing this speedo is like the spx i love it so smooth but the power is there when you want it
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 04-07-2011, 01:26 PM   #257
I definatley wouln't be able to run 5.0fdr (13.5t) at my local indoor track with 30m straight and the rest is tight and technical it would overheat especially with boost on 7 !
I've settled with around 6.5fdr 3,2,5,0 fast enough for me and has good punch infield, although I'd like it too boost sooner on the straight, it sounds like it's coming on to late on the straight ?
S.A.W is offline   Reply With Quote
Old 04-07-2011, 01:35 PM   #258
I am running 6fdr on a much smaller indoor track with tech. infield
I will get the chance to run it on a larger track Sunday so will keep you posted
I had it on 3,2,6,0 but after reading a few posts I might try 7 and drop the gearing a little to mid 5's!!
One thing I learnt with the GM75 was that bigger pinions really reduced motor temps!!!
008-Racer is offline   Reply With Quote
Old 04-07-2011, 01:42 PM   #259
I might have to try gearing up then. I'll drop the boost back to 3 and try 5.0fdr, check temps if ok I'll add more boost.
I'm runing 4.7fdr with a GM75 outdoors on a large track, so what will the SS V2 need gearing at outdoors 3.5fdr
Old 04-07-2011, 03:04 PM   #260
Wacker1's Avatar
S.A.W,
I've Connected my Motor Cooling Fan/Heatsink, by Plugging it directly into my Reciever, using the Factory Plug it came with!
By the way, what Ver Software are you on?...i.e 4.2 or 4.4??
I've run mine on Settings 3,3,9,1 on quite a few Indoor Carpet Tracks now.......some of them have been very Tight & Technical, yet after a 5minute run,the Hottest my Motor has come off is 84 Degrees!
Due to the amount of Torque the SS V2 Generates, you can afford to take the Gearing down as low as 5.0(for 13.5 in a TC).......which seems to make it Quicker & run loads Cooler!
The Recommended Speedo Settings & Gearing on the SS V2 Instruction Sheets is'nt Valid if you've Upgraded to the 4.4 Software!
Wacker1 is offline   Reply With Quote
Old 04-07-2011, 03:31 PM   #261
double
thilo-alexander is offline   Reply With Quote
Old 04-07-2011, 03:52 PM   #262
Old 04-07-2011, 11:18 PM   #263
syndr0me's Avatar
Trader Rating: 32 (100%+)
I tried the X12 17.5 at 5.0 on 0,3,7,0 and it was awful. The motor sounded like it was dying, and the car was slower. It didn't get hot, though.
syndr0me is offline   Reply With Quote
Old 04-07-2011, 11:57 PM   #264
Originally Posted by terryh View Post
Originally Posted by Wacker1 View Post
Its since allowed me to drop my Gearing down to around 5.0 & Increase my 'Feel' & 'Boost' Speedo Settings from 2 & 5 to 3 & 9!........with NO Overheating issues or Fade! Its got Amazing Punch & Top Speed, yet still really Smooth! The way the Temperature is on my Motor, I could probably afford to go even Higher on the Boost Setting!QUOTE]
Running the SXX Stockspec V2 in a 1/12th with a X12 10.5t and 1s rotor, and as previously quoted by Tellan, we found the optimum settings to be 5 on mode 2 and 11 on mode 3 with a 41.5mm rollout. The team recommendation is a rollout of 48mm. Just in case you dont know about rollouts, to get 41.5mm, you need a smaller pinion, whereas for 13.5t TC, the recommended FDR is 6, you found the performance and temps better at 5, which is a bigger pinion.
Please dont think this is a critism, as its not, I'm just trying to understand how we found the total opposite in 1/12th with 1s Lipo to what you found in TC with 2s Lipo!
Hopefully someone can shed some light on this.
1s rotor in the 12th ?
CPD Racing
chris_dono is offline   Reply With Quote
Old 04-08-2011, 12:20 AM   #265
S.A.W,
I'm running 4.4, never tried the 4.2. I'm going to try gearing around 5.0fdr tonight.
Old 04-08-2011, 05:09 AM   #266
I am assuming you are running a touring car on 2S lipo batteries. The speed control manual suggests Mode #2 to be from 3 through 5 and Mode #3 to be from 3 through 6. I think you need to increase Mode #2 and lower Mode #3 into the suggested range. The reason the motor didn't get hot is that it didn't reach a high enough RPM to get into the boosted timing. In effect you were running without boost and undergeared. Increasing Mode #2 should help it get into the boost.
davidl is offline   Reply With Quote
Old 04-08-2011, 05:22 AM   #267
I notice that some are running Mode#1 in the 0 setting in a 1/12 scale single cell lipo powered car. Why would you not want to run setting 1 to have the lipo cutoff in place?
Old 04-08-2011, 09:01 AM   #268
syndr0me's Avatar
I'm not sure how relevant LRP's suggestions about X12 motors are in their manual now that they changed the timing maps for 4.4.
Old 04-08-2011, 10:39 AM   #269
I believe the recommendations for Mode #2 when running 1S with a 1S rotor. Mode #3 needs more work as additional possibilities exist. Neat that my settings were very fast and competitive. I can only imagine what the more aggressive settings will lead to.
Old 04-08-2011, 01:36 PM   #270
terryh's Avatar
Yes Chris. As far as I'm aware, everyone running the SSX was using a 1s rotor, I could of course be wrong. Why do you ask?
terryh is offline   Reply With Quote
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
