Old 03-27-2011, 01:22 AM   #211
Default 4.2 vs 4.4
I have mine fitted in to a 1/12th pan car but there is a very big difference.
using 4.2 settings were 0,4,5,0 and rollout of 48mm car was fast but very aggressive and motor was hot 88c
loaded 4.4 and settings changed dramatically 0,5,11,0 and rollout of 41.5 car was smoother and punchier and motor temps under 60c.
changing the punch setting to 4 and car was even smoother to drive but just felt it wasnt so fast. HTH.
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 03-27-2011, 10:08 AM   #212
Johnn27's Avatar
Trader Rating: 69 (100%+)
Smile 17.5 settings
Originally Posted by Warren Weaver View Post
I ran mine for the first time was ok but motor temps were insane 200-230 and blew a good ion3 so i went down to 0 timing on the motor and the car was faster and motor a lot cooler 120 degrees in the main 5.26 fdr
Hi,
I am running a 17.5 Ion2 in my touring car on asphalt and I just got this esc back on the exchange program. where is a good place to start as for settings on this esc and motor timing?.Also is the sxx v2 from the exchange program coming with 4.2 or 4.4 ?
Thanks!
Johnn27 is offline   Reply With Quote
Old 03-27-2011, 02:04 PM   #213
caltek1's Avatar
Trader Rating: 35 (100%+)
Johnn27,
I can not tell you what software you have, unless you hook it up to the PC interface cable.
For 17.5 ION motor I would use the recommended on road settings in the instructions and start with the middle recommended FDR and adjust from there. I would run for a minute temp and do this until you are happy.
That is what I did with my car.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 03-27-2011, 03:16 PM   #214
bhambrent's Avatar
bhambrent is offline   Reply With Quote
Old 03-27-2011, 03:34 PM   #215
Johnn27's Avatar
Originally Posted by caltek1 View Post
Johnn27,
Regards,
Calvin.
Thank You for the advice!
Old 03-27-2011, 03:49 PM   #216
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
Originally Posted by Johnn27 View Post
Hi,
Thanks!
i actually switch to 4.4 then back to 4.2 but realized i blew a motor due to high motor timing run that motor at zero and temp after a minute it only took 4 to blow mine up a lot different from tekin not as much rip but totaly smooth if they figure out how to get power down the straight this speedo would be awesome i will test 4.4 this weekend
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 03-27-2011, 11:52 PM   #217
JayBee's Avatar
Trader Rating: 31 (100%+)
Why the f*#% isn't this esc available in the STATES; I can't find one any where?! What gives!!?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 03-28-2011, 12:16 AM   #218
CHRIS CHAVEZ's Avatar
Originally Posted by CHRIS CHAVEZ View Post
I'm interested in purchasing one of these bad boys for my 1/12 scale to run mod. I have three questions.
1) What is the lowest turn motor for 1/12 scale 1s racing? I read @ Syndrome's rcprogear.com site that Kevin Hebert was running a 4.0 but the LRP website indicates that the SS V.2 can only handle down to 4.5.
2) When will they be available in the U.S.A. again? It appears no one currently has them in stock.
3) Is this now going to be the "choice" speedo for 1/12 mod in comparison to the other LRP speedos?
Thanks, Chris
bump
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 03-28-2011, 01:32 AM   #219
Default availability
Widely available in the Uk, think its too fast for you guys over the pond , but associated are given out all these free ones so none left to sell. I wonder how many they have exchanged.
Old 03-28-2011, 10:10 AM   #220
corallyman's Avatar
Trader Rating: 99 (100%+)
As previously stated, the most recent batch was used for the LRP Exchange program here in the US. I believe when the next batch arrives, there will be some for sale. I think that was a pretty cool deal by LRP and Associated and worth the wait. If I am wrong about any of this then somebody from associated can correct me but this is what I read and seems logical.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 03-28-2011, 10:19 AM   #221
what do you mean to fast my tekin is way faster but the lrp is smoother in the infield?
Old 03-28-2011, 10:23 AM   #222
JayBee's Avatar
Thanks Capt. Obvious Maybe a larger batch should've been the play. I'm just sayin'; you know how impatient I am
Yours truly-
Chairboy
Old 03-28-2011, 10:33 AM   #223
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Yours truly-
Chairboy
Hi JB
I might sell you mine ..it got the new latest version software 4.4 and it new out of the box....
OVA is offline   Reply With Quote
Old 03-28-2011, 11:02 AM   #224
corallyman's Avatar
Yours truly-
Chairboy
I thought you knew all that JB, you're on here reading more than me. I saw all those flaming heads and I figured i'd post something before you blew up.
How is the chair, btw? Comfy?
Old 03-28-2011, 01:20 PM   #225
syndr0me's Avatar
Trader Rating: 32 (100%+)
I love mine so much, I've got another (and the USB cable) on backorder. I think the Tekin still might have the edge on bigger tracks, but I'm not positive. Plus, if you gain .1 in speed, and lose .2 in drivability, plus you add a 50% greater risk of blowing out when you boost weird in the infield, the choice is easy.
syndr0me is offline   Reply With Quote
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
