Old 03-18-2011, 11:10 AM   #196
Can I install stock software on SXX TC v2?
B.S. is offline   Reply With Quote
Old 03-18-2011, 01:04 PM   #197
Originally Posted by Sean Cochran View Post
Are you running 2s? If so from the testing we have done you should get better performance and lower motor temps by sticking to the slow ramp profiles, odd numbers. At least with LRP motors, I cannot speak for other brands. This also is not meant to say that is the only way it works, just something to keep in mind.
Yep, running 2 cells in a t3 2011, going testing tomorrow ready for carpetwars on sunday, and will try some odd no's
thanks for your input sean.
shrek54 is offline   Reply With Quote
Old 03-18-2011, 06:15 PM   #198
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
Originally Posted by L.Fairtrace View Post
The software doesn't work on 64 bit? Thats unfortunate I only have 64 bit machines.
Also can anyone explain the effects of switching from 4.2 to 4.4?
Larry i will be down next saturday if you need it i can update it
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 03-19-2011, 01:57 AM   #199
HappyHippo's Avatar
Anyone that has a good setup for EPIC D3 13,5 motor with SS V2?
HappyHippo is offline   Reply With Quote
Old 03-21-2011, 11:18 PM   #200
Johnny Wishbone's Avatar
Default SXX SS exchange
Sean are the units supplied available for the exchange program (ss to V2) coming with 4.2 or 4.4 upgrade?
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 03-22-2011, 02:15 AM   #201
Default comes with 4.4
All units in the Uk come with 4.4 since it seems last week.
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 03-22-2011, 06:45 AM   #202
Xpress's Avatar
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 03-22-2011, 07:53 AM   #203
Originally Posted by Xpress View Post
propriertery software updates only work to specific speedo sxx stock spec ver 2 software works only with that speedo ssx ver 2 tc you can only update using software specific to that speedo and the sxx ver2
Old 03-22-2011, 08:34 AM   #204
Xpress's Avatar
So to use LRP esc's at a race where I am running mod and boosted 17.5 I'll have to build two cars?
-Espo
Old 03-22-2011, 08:37 AM   #205
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I believe the sxx stock spec is rated to be ok with down to a 4.0
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 03-22-2011, 11:58 AM   #206
bhambrent's Avatar
Just wanted to say thanks to LRP an AE for the SXX SS exchange. I ran the v2 for the 1st time this pasted weekend and am very happy with it.
I would like to know what software it has? Is there anyway to tell?
bhambrent is offline   Reply With Quote
Old 03-22-2011, 04:10 PM   #207
Default how to tell
You need to connect to the software with the correct up date cable and it will indicate what version you have.The latest Escs in the UK come with v4.4
Old 03-25-2011, 03:17 PM   #208
CHRIS CHAVEZ's Avatar
I'm interested in purchasing one of these bad boys for my 1/12 scale to run mod. I have three questions.
1) What is the lowest turn motor for 1/12 scale 1s racing? I read @ Syndrome's rcprogear.com site that Kevin Hebert was running a 4.0 but the LRP website indicates that the SS V.2 can only handle down to 4.5.
2) When will they be available in the U.S.A. again? It appears no one currently has them in stock.
3) Is this now going to be the "choice" speedo for 1/12 mod in comparison to the other LRP speedos?
Thanks, Chris
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 03-26-2011, 10:17 PM   #209
I ran mine for the first time was ok but motor temps were insane 200-230 and blew a good ion3 so i went down to 0 timing on the motor and the car was faster and motor a lot cooler 120 degrees in the main 5.26 fdr
Old 03-26-2011, 10:23 PM   #210
caltek1's Avatar
Trader Rating: 35 (100%+)
Has anyone done any comparative testing with using 4.2 against 4.4 software in TC?
I still have 4.2 installed and I am running boosted 21.5 ,(using a LRP X-11 motor), which I have found to be very good, however I think I want to try reducing my FDR from 4/50mm rollout to FDR of 5 with a change in rollout for more acceleration. I will also reduce the boost setting in the ESC.
Anyone with an opinion?
Regards,
Calvin.
caltek1 is offline   Reply With Quote
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
