Old 03-17-2011, 01:45 AM   #181
Originally Posted by terryh View Post
Geoff
Totally agree with Sean in that I would run the 0000 insert. It's early days yet with setup, I was looking to start with an FDR of 7 because the X12's like to rev, agree with you on mode 2 @ 4 but was looking to start mode 3 @ 8 or 9, check temps after 2 mins (very important). Depending on how it felt and temps, would consider going up from a FDR of 7 to 7.5 and compare, then work from there.
I might not make it tomorrow because its the last 1/12th National this weekend and leaving Friday to go oop north. Good luck with it, like to hear how you get on.
Terry
Thanks Terry for the advice, will speek to you soon
shrek54 is offline   Reply With Quote
Old 03-17-2011, 03:09 AM   #182
terryh's Avatar
Originally Posted by Sean Cochran View Post
The oooo timiing insert is what you should start with, if no problems then try ooo later. Not sure if/when you should attempt using the oo insert.
Sean, I would run oo in blinky mode, or when your not running any boost
terryh is offline   Reply With Quote
Old 03-17-2011, 05:44 AM   #183
Originally Posted by OVA View Post
how about the Non boost 17.5 timming ..12th scale?
Please see post #120 on this thread. I want to clarifiy that the part where fast lap was equal to the fastest lap of the boosted class, it is obvious that the boosted car was possibly a little off in handling. The feat of running equal fast lap is, however, still an important accomplishment. Tried the same with a Black Diamond V1 last night and it was a little off. Motor temperature was a lot lower. I also want to say that I liked the 0000 timing in the motor better. The rollout was increased to obtain speed. The rip through the infield was outstanding. I have run more motor timing in the past and lost some infield rip. Laptimes then suffered as the small increase in straight line speed didn't make up for it.
davidl is offline   Reply With Quote
Old 03-17-2011, 08:20 PM   #184
Default X12 17.5T in TC?
Has anyone run the SXX V2 v4.4 speedo with x12 in 17.5 no-timing? How does it compare when running the speedo with a D3 or D2?
Electro-MAX RC is offline   Reply With Quote
Old 03-17-2011, 08:47 PM   #185
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by hacker View Post
well I have had 4 stock specs v1 to v3. Three of them cogged excessively, 2 of them stopped working, last one drag brakes didnt work. So yes, you can say I am a little bitter after spending over $1000 on lrp speed controls and that they are not working properly. To add to this insult, after exchanged my last stock spec as warranty for an LRP sxx TC, and you know what, it cogs, not as bad as the stock specs, but bad enough. And then to understand that there are some people having problems with your latest stock specs...........why?
Did you use the sensor wire that comes with them?
I've been told that LRP calibrate the sensor to the resistance in their wire, so using an aftermarket or different length sensor can cog.
For what it's worth my SXX V1 hasn't cogged once. I love it, except when I have to solder it, but personally I wouldn't sacrifice ANY performance for it to be easier to solder.
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 03-18-2011, 02:10 AM   #186
Originally Posted by shrek54 View Post
I'm going to run my sxx stockspec v2 (up dated to 4.4) and lrp13.5 x12 tomorrow at maritime, I'v set gearing to 6 overall, set mode 2 at 4, and mode 3 at 5. The motor out of the box had the 4 dot timing block fitted for some reason, so fitted the 2 dot block. Lets see how it go's
As suggested by sean and terry I reset the motor to 4 dots and fdr to 7 overall
mode 2 @4 mode 3 @8, ran rearly well, just a little on the hot side, reset fdr to 7.5 lots better and real quick, (and loads more feel than the gm 13.5 set up that i have been running) recomend this set upto be a great starting point for anyone with this combo.
Old 03-18-2011, 02:50 AM   #187
hacker's Avatar
Trader Rating: 140 (100%+)
that's interesting, didn't know that!
Although I'm quite happy with my HW now, I don't think I will go lrp, until I get smoked by em. Cant see that happening tbh
hacker is offline   Reply With Quote
Old 03-18-2011, 06:14 AM   #188
Kail's Avatar
Hi Burito,
Is it possible to get us the 64bit USB bridge driver file? Thanks
Kail is offline   Reply With Quote
Old 03-18-2011, 06:33 AM   #189
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
The software doesn't work on 64 bit? Thats unfortunate I only have 64 bit machines.
Also can anyone explain the effects of switching from 4.2 to 4.4?
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 03-18-2011, 09:07 AM   #190
burito's Avatar
We know the software works flawless on 32Bit computers, 64Bit is a bit strange and we currently test different approaches to make it work on 64Bit as well. I know of a few people who have succesfully installed it on 64Bit machines as well, but it doesn't work everywhere and we need to understand why.
Reto Koenig
burito is offline   Reply With Quote
Old 03-18-2011, 09:29 AM   #191
bhambrent's Avatar
Here you go L.fairtrace.
Originally Posted by burito View Post
Sent files to further guys which requested them by email.
Btw, don't there is no must to update! Original release v4.2 works absolutely flawless as well, the difference on v4.4 are the ramp profiles under Mode3 which make motors run a lot cooler. All the rest is identical in regards of performance & reliability.
bhambrent is offline   Reply With Quote
Old 03-18-2011, 09:52 AM   #192
Default 4.2,4.3 and 4.4
The Esc comes with 4.2 installed at the moment, i ran it in 1s 10.5 with 4 dot insert rollout was 48mm in a 1/12th. settings 0,4,5,0. Car was very harsh and aggressive.
Up graded to 4.4 and car is now very linear settings have changed dramatically 3 dot insert. 0,5,11,0 and rollout of 41.5mm Car is not as fast top speed but laps times are better as the car is now easier to drive.Hottest the motor has got over 8mins is 57c.
HTH
Im looking for some settings and rollout for using a 13.5 bl in a 1/12th plan to do the iiic AND THAT IS THE 1/12TH CLASS.
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 03-18-2011, 10:49 AM   #193
AE-Reedy
If you are running zero boost mode there should be no performance difference as the changes were made in the boost mode.
Sean Cochran is offline   Reply With Quote
Old 03-18-2011, 10:50 AM   #194
Just find out about new software for SXX V2.
Does it software for stock or modified ?
B.S. is offline   Reply With Quote
Old 03-18-2011, 10:53 AM   #195
AE-Reedy
Are you running 2s? If so from the testing we have done you should get better performance and lower motor temps by sticking to the slow ramp profiles, odd numbers. At least with LRP motors, I cannot speak for other brands. This also is not meant to say that is the only way it works, just something to keep in mind.
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
