Old 03-16-2011, 02:32 AM   #166
hacker's Avatar
Trader Rating: 140 (100%+)
Originally Posted by burito View Post
We use thick copper boards, in order to minimse losses and get maximum performance, but that indeed results in the fact that power wires are a bit harder to solder if a "weak" soldering-station/-iron is used.
Also there is a reason why we don't use solder posts, which is the fact that solderposts increase losses, direct connection to the PCB like it is realised on the SXX is best for performance.
Out of curiosity, would you trade a little bit of performance for easier solderabilty (right word?)?
are you kidding me?
like what loss are we talking about?
1 millionth of an ohm?
PS, yeah your response sounded good, but we are not all idiots.
This BS that LRP seems to churn out, make me not want an LRP again.
hacker is offline   Reply With Quote
Old 03-16-2011, 02:55 AM   #167
burito's Avatar
Mr.hacker: I don't understand why you are so aggressive in most of your posts, there really is no reason for that in my opinion.
Believe me, I know what I'm saying and I don't try to fool anyone here!
We have done testing/measurements with/without solder posts of course and the difference is easily noticable on the bench and dyno. It may not be noticable on the track for certain low power classes, but at the end every little thing can matter and usually you guys are also looking for every little 0.1% advantage...
The difference of with/without solderpost is about as big as the difference of one less fet per phase.
Reto Koenig
burito is offline   Reply With Quote
Old 03-16-2011, 03:08 AM   #168
hacker's Avatar
well I have had 4 stock specs v1 to v3. Three of them cogged excessively, 2 of them stopped working, last one drag brakes didnt work. So yes, you can say I am a little bitter after spending over $1000 on lrp speed controls and that they are not working properly. To add to this insult, after exchanged my last stock spec as warranty for an LRP sxx TC, and you know what, it cogs, not as bad as the stock specs, but bad enough. And then to understand that there are some people having problems with your latest stock specs...........why?
so whats the resistance of a gold plated solder post?
if it makes 1mm of a difference in performance, it wouldnt matter anyway as my GM/tekin/HW will already be 2 metres ahead of it to begin with......
Old 03-16-2011, 03:42 AM   #169
syndr0me's Avatar
Trader Rating: 32 (100%+)
Thanks for the info, Reto. That does seem like a pretty big difference, at least on paper. I think you guys are the last manufacturer to use this style of soldering, so perhaps the others have decided the difference isn't worth the inconvenience? Either way, I appreciate you taking suggestions into consideration.
syndr0me is offline   Reply With Quote
Old 03-16-2011, 07:41 AM   #170
vctr1's Avatar
Trader Rating: 14 (100%+)
Question...
I ran my V2 speedo for three packs and yesterdai it ran for a out 2 laps, the speed control stop working and the yellow/red light were on? try to re-set it but didn't responded, any ideas why this happen?
thanks in advance,
Victor
VSpeed Racing / FG SUPPLY
www.vspeedracing.com
www.fgsupply.com
www.vsmodelsport.com
vctr1 is offline   Reply With Quote
Old 03-16-2011, 07:47 AM   #171
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I ran this speedo this weekend. It was intereting. I would really like to get an update connector so I can try 4.4
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 03-16-2011, 07:53 AM   #172
Tron's Avatar
Trader Rating: 16 (100%+)
Originally Posted by vctr1 View Post
Question...
thanks in advance,
Victor
Victor was Bob Stefflue there last night? Did he update it to v4.4 for you by any chance?
Time to make a trip down to Lake Forest...
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 03-16-2011, 01:38 PM   #173
I'm going to run my sxx stockspec v2 (up dated to 4.4) and lrp13.5 x12 tomorrow at maritime, I'v set gearing to 6 overall, set mode 2 at 4, and mode 3 at 5. The motor out of the box had the 4 dot timing block fitted for some reason, so fitted the 2 dot block. Lets see how it go's
shrek54 is offline   Reply With Quote
Old 03-16-2011, 02:40 PM   #174
syndr0me's Avatar
Any suggestions for an X12 17.5 in a 1/12 with the SXX-SSv2? Looking for gearing/profile ideas. What insert/rotor are you guys using for the X12 in 1S?
Old 03-16-2011, 02:44 PM   #175
AE-Reedy
The oooo timiing insert is what you should start with, if no problems then try ooo later. Not sure if/when you should attempt using the oo insert.
Sean Cochran is offline   Reply With Quote
Old 03-16-2011, 05:13 PM   #176
terryh's Avatar
Geoff
Totally agree with Sean in that I would run the 0000 insert. It's early days yet with setup, I was looking to start with an FDR of 7 because the X12's like to rev, agree with you on mode 2 @ 4 but was looking to start mode 3 @ 8 or 9, check temps after 2 mins (very important). Depending on how it felt and temps, would consider going up from a FDR of 7 to 7.5 and compare, then work from there.
I might not make it tomorrow because its the last 1/12th National this weekend and leaving Friday to go oop north. Good luck with it, like to hear how you get on.
Terry
terryh is offline   Reply With Quote
Old 03-16-2011, 05:44 PM   #177
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
Larry i got one i will have it monday i can bring it with me
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 03-16-2011, 09:02 PM   #178
See post #84 of this thread. Good luck.
davidl is offline   Reply With Quote
Old 03-16-2011, 09:13 PM   #179
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
how about the Non boost 17.5 timming ..12th scale?
OVA is offline   Reply With Quote
Old 03-17-2011, 01:44 AM   #180
Thanks for the advice Sean, will change that before tonight and let you know
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
