Old 03-14-2011, 08:13 AM   #151
burito's Avatar
Everyone who requested PC-Software and Speed-Control Firmware has received it by email now.
I'm currently also checking Windows7 64Bit compatibility with engineers as this was a question sent to me by email!
All the files are now also available on our website finally, please following this link: http://www.lrp.cc/en/service/software-update/
Reto Koenig
burito is offline   Reply With Quote
Old 03-14-2011, 08:36 AM   #152
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thumbs up
Thanks Reto.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-14-2011, 01:39 PM   #153
Default binding problems
I have 2 SXX stock spec, one with the v4.4 and one with the v4.3
Im using the v4.4 in my WGT with Futaba 3VCS tranny but with spektrum module and receiver fitted. Going great no problem.
When trying to bind the V4.3 with same tranny set up etc.No go kept losing bind. Then tried to set up with the new sanwa gear and no problem runs good.
Is there a compatibility problem with Spektrum dms -dsm ???
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 03-14-2011, 02:02 PM   #154
Tron's Avatar
Trader Rating: 16 (100%+)
Silly question:
I would like to wire a cooling fan directly to B+ and B- leads, easiest spot looks to be on the underside (near sensor plug).
Is the solder on this the 'normal' kind or is it that silver solder which requires high temp to work with?
I also want to shorten the ESC wire and power wires. Any way those are replaceable if I want to lengthen them for use in another application in the future?
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 03-14-2011, 03:34 PM   #155
Default solder
Ive changed all the wire on my new controllers for 16gauge CRC very flexible.I resoldered with Silver solder as i find this type to be the best flows very easily and makes for a good strong join
Old 03-15-2011, 05:18 AM   #156
Default software upgrade 4.4
As a complete computer numpty, i found the down load and up grade very simple. Both my Escs now up graded so off to the track for testing the 1/12th with the x12 and 1s rotor.
Old 03-15-2011, 05:31 AM   #157
slakr's Avatar
Trader Rating: 28 (100%+)
Purchase new LRP SXX Stock Spec V2... check (got two of them)
Download LRP 4.4 update from website... check
Purchase LRP USB Speed Control Bridge Update Device... can't find one available anywhere
JQ THEeCar Black,THECar White~Mugen MBX7TR Eco~TLR 22 3.0SR,22-4 2.0~XRAY XB2C
AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 03-15-2011, 05:50 AM   #158
Default up date cable
Available from Uk no problem.
Old 03-15-2011, 03:01 PM   #159
pmc
Hello
i want to know a good basic setup for LRP SXX stock spec version 2 with a motor LRP X12 13.5 T for a track with a main straight of 50 meters ??
Thanks in advance.
Best regards:
Pedro Silva
pmc is offline   Reply With Quote
Old 03-15-2011, 09:13 PM   #160
syndr0me's Avatar
Trader Rating: 32 (100%+)
I love my v2, truly I do. But I have to be honest, the way you solder wires to this ESC is dreadful. Having done the world tour with other ESC's the past 1.5 years, I can say with certainty that solder posts are absolutely, without question the way to go.
Also, it's kind of a bummer that my 1 month old, $250 ESC already has the plastic chipping off the case. Whatever process you guys are using to coat the plastic with that metallic blue stuff, it's not great.
Sorry. Can we still be friends?
syndr0me is offline   Reply With Quote
Old 03-15-2011, 11:00 PM   #161
CraigM's Avatar
Gaa you said it I haven't run LRP since the SPX but I've just picked up an SXX. While I consider myself decent with the soldering iron I still managed to nick the case slightly under the circuit board with the tip. NOOOOO!!!
P.s. I'm referring to a TC spec V1 but it's same-same
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 03-16-2011, 01:21 AM   #162
Gav-'s Avatar
The only way I've been able to de-solder these things is with an "industrial" soldering iron.
Literally have the heat on it for 3 secs and it pulls through.
It's also the only way I've kept them clean.
Gav- is offline   Reply With Quote
Old 03-16-2011, 01:33 AM   #163
burito's Avatar
We use thick copper boards, in order to minimse losses and get maximum performance, but that indeed results in the fact that power wires are a bit harder to solder if a "weak" soldering-station/-iron is used.
Also there is a reason why we don't use solder posts, which is the fact that solderposts increase losses, direct connection to the PCB like it is realised on the SXX is best for performance.
Out of curiosity, would you trade a little bit of performance for easier solderabilty (right word?)?
Reto Koenig
Old 03-16-2011, 01:58 AM   #164
syndr0me's Avatar
I guess that depends what you mean by "performance." If it affects the overall top speed, I'd be willing to sacrifice that, 'cause I'm not so sure I'd notice on the track. If it affects how smooth the throttle of the ESC feels, then no, I'd suffer with the current solution forever.
Old 03-16-2011, 02:18 AM   #165
Trader Rating: 54 (100%+)
Really? Didnt think the little things like that were as big of a deal with lipo and brushless technology. I would like to see a back to back test. Same car, same driver- 1-sxx v2 without solder posts and a sxx v2 with solder posts. Im willing to bet that the difference is NOT noticeable.
BTW- (Burito)Your response sounded good though.
Jamison R is offline   Reply With Quote
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
TEKIN RS VS LRP SXX V2 What's your VOTE! RC-ZOMBIE Electric Off-Road 125 12-03-2011 08:16 PM
Tekin RS vs LRP SXX Stock Spec vs Mamba Max Pro Chris Gierse Electric Off-Road 30 08-10-2011 10:50 AM
Best ESC for MOD and 17.5? JayL Electric On-Road 29 08-06-2010 04:15 AM
