Old 02-02-2012, 04:45 PM   #76
Skiddins's Avatar
Originally Posted by Marek Gadomski View Post
Have those motors a temperature chceck for esc in sensor ?
U no like LRP or GM Motors
It seems like only motors from the same manufacturer as the ESC have that feature.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-02-2012, 11:00 PM   #77
Has anyone got a speedo and motor setup for a z3r 13.5 using a sp/hw speedo in the open timing class? It's an indoor track measuring 36mx22m not looking for anything definitive just a starting point
Bony85 is offline   Reply With Quote
Old 02-03-2012, 03:15 AM   #78
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
DRRS Punch : 7
Brake Force : 87.5%
REverse Force :100%
Initial Brake : 0%
Neutral Range: 6%
Boost Timing : 36
Turbo Slope : 18
Turbo Timing : 24
Start RPM : 6000
Turbo Delay : 0.2 s
Timing ACC : 500
frd 6.6 to 7.4
motor timing set at 25
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 02-03-2012, 04:43 AM   #79
Ariel Reds's Avatar
is this motor suitable for 10.5t boosted class? the temperature around my track is about 36 celcius, and compare to the x12, which one run cooler and smoother?
Ariel Reds is offline   Reply With Quote
Old 02-03-2012, 05:40 AM   #80
Craig W's Avatar
The motor is good in 10.5t boosted turn timing down on motor to 15 and try again and do not run high turbo
Old 02-03-2012, 06:08 AM   #81
Craig W's Avatar
is there anybody running tekin as we are looking for boosted setting for 13.5 and 10.5t 30x20m track in touring car
Old 02-03-2012, 06:14 AM   #82
Marek Gadomski's Avatar
That's funny because gm speedos v2 read temp. from LRP X11 X12, GM/Graupner, Novac, ETC
Without Speed passion and HW
____________________________________________________
Tamiya TRF 417X-Speed Passion-Thunder Power-KoPropo
marcgadomski@gmail.com
http://www.facebook.com/marc.gad
Marek Gadomski is offline   Reply With Quote
Old 02-03-2012, 09:57 AM   #83
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Hi All,
I swapped a 13.5 stator from my 17.5 to test for TCS and it was cogging bad. Sure enough no sensor signals (confirmed with a checker). Switch to a different motor and all is well.
Any particular precautions one should take when doing stator swaps in these motors? Have done many sensor board swaps / rotor swaps in other motors without any issues.
Thanks,
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 02-03-2012, 10:29 AM   #84
Craig W's Avatar
Originally Posted by g12314 View Post
Hi All,
Thanks,
Jimmy
try turning down the timing on the motor as we had same problem
Old 02-03-2012, 11:20 AM   #85
g12314's Avatar
Thanks for the tip. Did try that (swept from 0 to 30 degrees), but it is clear that the hall sensors are not reporting to the ESC. Sensor cable and ESC are verified good via another motor.
Jimmy
Old 02-03-2012, 06:11 PM   #86
Skiddins's Avatar
Everything runs cooler than LRP's!
The Reedy's & TP's seem to run very cool compared with others. just don't let that make you think you can just ramp everything up to max!
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 02-03-2012, 07:54 PM   #87
I agree with you. I use TP 4.5T boosted, the temp was 65deg the max and it was smooth and fast
minez is offline   Reply With Quote
Old 02-03-2012, 10:35 PM   #88
Originally Posted by sidecarphil1 View Post
I am looking for a set up for a 17.5 TP motor in a WGT car with 2S and Speed passion GT2.0 speedo, indoor carpet track about a 20m straight
Thanks Phil
anyone ???
sidecarphil1 is offline   Reply With Quote
Old 02-04-2012, 02:05 AM   #89
Craig W's Avatar
anyone ???
DRRS Punch : 7
Brake Force : 87.5%
REverse Force :100%
Initial Brake : 0%
Neutral Range: 6%
Boost Timing : 41
Turbo Slope : 18
Turbo Timing : 16
Start RPM : 3000
Turbo Delay : 0.1 s
Timing ACC : 500
you could try this is what i run on my tc with 17.5t
Old 02-04-2012, 01:44 PM   #90
DRRS Punch : 7
Brake Force : 87.5%
REverse Force :100%
Initial Brake : 0%
Neutral Range: 6%
Boost Timing : 41
Turbo Slope : 18
Turbo Timing : 16
Start RPM : 3000
Turbo Delay : 0.1 s
Timing ACC : 500
WOW thanks now it sounds a bit more lively hahaha
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 08:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 12:29 AM
