Old 12-13-2011, 07:39 AM   #61
RedDevil13's Avatar
Trader Rating: 19 (95%+)
I would like to know if you can change a Z3R-S to a Z3R-M and vice versa. I know the stators can be interchanged to change the wind of the motor, but I wasn’t sure if I buy a 10.5 and decide later I want a 9.5 or 8.5 etc, will I be able to do that? Why are they labeled different with the -S and the -M
(Obviously I know the -S is stock and the -M is modified, but that doesn’t really tell me if they are different)
Thanks, hoping for a quick reply, plan on buying one in the next 2 days or so.
http://www.thehiddenraceway.com/
http://www.staubbrothers.com/
Hyperdrive Havoc 3.0 - 17.5 Stock EDM -- Hyperdrive Havoc 3.0 - Mod EDM
Hyperdrive Hustler - 17.5 Spec Sprint -- Hyperdrive Hustler - Mod Sprint
Lizzard Werks RC LLC Horsepower!
RedDevil13 is offline   Reply With Quote
Old 12-20-2011, 01:19 PM   #62
Mate_Nemeth's Avatar
Hy!
I would like to know what kind of gearing is the best for Z3R 6.5T motor? I'd like to use in modifield class in carpet but we run for 7minutes. I use SP v2.1 ESC with 3.0 Modifield software. (If someone's got a good ESC setup thats would be very great)
Thanks,
Máté
.:Team Tamiya Hungary:.
Mate_Nemeth is offline   Reply With Quote
Old 12-20-2011, 01:42 PM   #63
Fred Hubbard's Avatar
Originally Posted by Mate_Nemeth View Post
Hy!
Thanks,
Máté
Using 205 I would suggest starting with a 7.5 final leaving the mechanical timing set at 20*.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 12-21-2011, 06:39 AM   #64
And what programs i use to 6.5T? (boost..and others)
Thanks,
Old 12-21-2011, 06:46 AM   #65
Thanks,
You will need to look at the Speed Passion site to find setups using Boost.
Old 01-09-2012, 10:43 AM   #66
Looking for a good starting point for 17.5 blinky 12th scale on a med/large carpet track...timing, std/option rotor, rollout
Thanks, Denney
Denney is offline   Reply With Quote
Old 01-09-2012, 12:57 PM   #67
303slowdown's Avatar
Trader Rating: 21 (100%+)
Thanks, Denney
35 deg timing on motor
56 pinion
76 spur
1.70 rear tire size
Std rotor
is what I run and the car is fast
96x44 track size
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 01-31-2012, 08:33 AM   #68
Skiddins's Avatar
Is the timing on the endbell of these motors 'True' timing or manufacturer BS
... Also, does anyone have a picture of the endbell with it's timing marks etc?
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-31-2012, 11:08 AM   #69
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Hi
I'm running the 17.5 blinky Stock TC ,I just installed the High Torque green rotor..How many pinion teeth are different between red and the green rotor ?
OVA is offline   Reply With Quote
Old 01-31-2012, 11:30 AM   #70
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Skiddins
there should be some pic on the thunderpower website
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 01-31-2012, 11:30 AM   #71
Originally Posted by OVA View Post
Hi
Maybe one tooth. A safe starting point is 4.0 and I personally like 3.7-3.8 timed at 40* With a fan temps after 3min should be around 135* and 145* - 150* after 6min.
Old 02-02-2012, 11:47 AM   #72
Skiddins's Avatar
Just the inform anyone who saw my early posts, here's a photo with the timing set to 20deg (and by the way the rotor measures 1300 gauss);
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 02-02-2012, 12:38 PM   #73
OVA
OVA's Avatar
Thanks fred
Old 02-02-2012, 01:12 PM   #74
I am looking for a set up for a 17.5 TP motor in a WGT car with 2S and Speed passion GT2.0 speedo, indoor carpet track about a 20m straight
Thanks Phil
sidecarphil1 is offline   Reply With Quote
Old 02-02-2012, 01:13 PM   #75
Marek Gadomski's Avatar
Have those motors a temperature chceck for esc in sensor ?
U no like LRP or GM Motors
____________________________________________________
Tamiya TRF 417X-Speed Passion-Thunder Power-KoPropo
marcgadomski@gmail.com
http://www.facebook.com/marc.gad
Marek Gadomski is offline   Reply With Quote
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 08:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 12:29 AM
