Old 09-07-2014, 10:22 AM   #631
Merci beaucoup...
Originally Posted by G-rem View Post
I ran this configuration last year on my Awesomatix: 35 of motor timing (never go higher or the motor could burn), ratio of 4.46 (88/41 in 64 pitch) and 2 fans blowing on motor.
I never went higer than 80C temp motor like this, even with air temp @ 28-30C
You can a little change the ratio and go to 4.2 if needed.
Cheers,
G-rem
Does anybody have other suggestions ?
toroloco is offline   Reply With Quote
Old 09-16-2014, 01:03 PM   #632
madjack's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to madjack
Post timing for 1S
timing for 1S?
I'm looking for a starting point for timing and roll out for a Z3 17.5 1/12th scale 1S, 90x45 carpet track?
madjack is offline   Reply With Quote
Old 09-16-2014, 02:14 PM   #633
Skiddins's Avatar
Originally Posted by madjack View Post
timing for 1S?
40deg Timing. Seem to recall that 17.5 were around 100mmpr at our nationals.
10.5's were 70mmpr
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-16-2014, 06:44 PM   #634
racer x 1's Avatar
Trader Rating: 27 (100%+)
timing for 1S?
For 17.5 id start at 95mm and go from there
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 09-16-2014, 08:54 PM   #635
i got a z3 17.5 & it gets hot fast reguardless of my gearing & timing..my drive train is free...so could my rotor..(green 1) or stator went bad...imma try my red rotor & see if it still gets hot
DESOTO RACING,,SERPENT S411 3.0 USGT,,S411 3.0 17.5,,MOTIV,,FRP PAINT WORKS
starrx is offline   Reply With Quote
Old 09-17-2014, 08:53 AM   #636
madjack's Avatar
Post
10.5's were 70mmpr
Skiddins, do you recall if the Red or Green rotor was preferred?
Old 09-17-2014, 11:43 AM   #637
Skiddins's Avatar
I couldn't really tell much difference, but currently run the green rotor in my 10.5
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 09-19-2014, 04:02 PM   #638
KJR
17.5 blue rotor 98mmpr 35 degree timing was what I ran at BRCA nationals. Car was definitely on pace.
KJR is offline   Reply With Quote
Old 09-22-2014, 04:14 PM   #639
hi guys!
Suggestions for FDR 10.5t Blinky?
Touring car, green rotor, fast / long track.
Tks!!!
314ck5h33p is offline   Reply With Quote
Old 09-22-2014, 04:15 PM   #640
Cool
Originally Posted by 314ck5h33p View Post
hi guys!
Tks!!!
Endbell timming too!
Old 09-23-2014, 02:41 AM   #641
G-rem's Avatar
hi guys!
Tks!!!
Thunder Power RC Z3R Motors
G-rem is offline   Reply With Quote
Old 09-23-2014, 04:01 PM   #642
Nice Man!
Perfect!
So Tks G-rem.
Old 10-04-2014, 01:32 PM   #643
Wade....'s Avatar
Looks these motors are no longer listed on Horizon Fast Serve....
is there a new Thunder Power motor coming soon???
Wade Huesman, TCORC Secretary/Pencil Pusher
Wade.... is offline   Reply With Quote
Old 10-21-2014, 02:32 PM   #644
Default Thunder power Z3R 4.5T rotor question
Hello
Im running an xray T4 touring car with esc speed passion gt2 pro and the above motor.
I was bought the gold rotor "rpm" because the stock one destroyed the balance ring of the rotor.
Do i have to adjust the gear and the esc setup???
Thanks...
mokujin is offline   Reply With Quote
Old 10-23-2014, 06:41 AM   #645
Default New rotor fitting
Guys
About to fit a new rotor whats the purpose of the O ring that sits on the shaft at the pinion end of the rotor. is it just to secure the shim washers in transit or does it need to be there all the time??
Bosscat is offline   Reply With Quote
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 09:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 01:29 AM
SEO by vBSEO 3.5.0
