Old 09-05-2011, 02:13 AM   #46
12scale's Avatar
Hi just got one of these motors for 17.5 boosted, i have been useing a duo 3 and was wondering as the thunder power is set at 20 deg how that compares to a duo set on the center mark.
Thanks Stuart
Stuart McMillan
Xray T4 2015
Hobbywing/Sanwa/Pro Amps
Adelaide RC Team Mechanic
www.adelaiderc.com.au
12scale is offline   Reply With Quote
Old 09-05-2011, 08:54 AM   #47
Fred Hubbard's Avatar
Thanks Stuart
If I recall correctly at that setting our motor has 10* less timing than the D3.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 09-11-2011, 04:05 PM   #48
LOW ET's Avatar
Trader Rating: 95 (100%+)
would you use the same rotor going from 17.5 non boosted to 17.5 boosted touring? and which rotor would be best, stock (red), blue, or green?
LOW ET is offline   Reply With Quote
Old 10-17-2011, 08:43 AM   #49
anyone tried running one of these motors in 10.5 boosted World GT?
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 10-17-2011, 10:53 AM   #50
Xpress's Avatar
+1....which rotor would be best for 17.5 NR tc?
Xpress is offline   Reply With Quote
Old 10-17-2011, 11:01 AM   #51
Either the Green (TPM-R540AHT) or Blue (TPM-R540AST) will work for your application. I always suggest to drivers that they purchase both. Start with 35* static timing and around 4.0 to be safe with both rotors. I've found that the green rotor ends up being about 2 teeth taller (lower numerically) than the blue rotor. You want the temp to be around 135* - 140* after 3 mins and around 150* - 160* after 6 mins.
Old 10-17-2011, 11:16 AM   #52
Xpress's Avatar
What is the determining factor on which to use? Size of the track or do the two option rotors just need to be tested back to back?
Old 10-17-2011, 11:19 AM   #53
Both of what you mentioned and personal preference (feel) as well.
Old 10-17-2011, 12:01 PM   #54
LOW ET's Avatar
what is NR tc?
Old 10-17-2011, 12:04 PM   #55
what is NR tc?
Non-Ramping
Old 11-09-2011, 09:11 PM   #56
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
What is the length of the outer case from faceplate to the rear shoulder not including the rear bearing retainer? I'm hoping its 45mm or less. And then what is depth from the edge of the shoulder to the bearing retainer? Hoping for 5mm or more there.
Thanks,
John
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 11-10-2011, 02:51 PM   #57
Trader Rating: 213 (100%+)
Thanks,
John
I come up with 46.15 mm faceplate to shoulder and 2.25mm protruding from shoulder to end of bearing. Is this what you're looking for?
Andy Koback is offline   Reply With Quote
Old 11-11-2011, 06:18 AM   #58
Exactly! Thank you. I'm getting a 21.5 for my Sakura FGX F1, should be here next week.
Old 11-19-2011, 04:29 AM   #59
M24
M24's Avatar
Default Suggested Set Up
Any suggestions for a good safe starting point for the set up of a TP 21.5T touring car in "blinky" class.
Our club is about to change from 540 brushed to 21.5 blinky early next year, so have just purchased a TP motor and would like to set it up and give it a run in practice.
On our track 540 brushed generally run a FDR of no more than 4.46 to give good speed down the short straight and enough punch through the infield.
Need to know a good starting point for FDR and timing.
Bro-Kin Racing - Team BRG
Castle Hill Raceway
Xray T3-2011
M24 is offline   Reply With Quote
Old 11-19-2011, 04:46 AM   #60
ta04evah's Avatar
After seeing how the TP 21.5 went that night at the track I'm tempted to add it to my new stock of brushless motors.
Will be interesting to see how it'll go hooked up to a Tekin rs.
Cheers
Rob.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 08:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 12:29 AM
