Old 01-25-2014, 12:46 AM   #571
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
Originally Posted by ToysRUsKid View Post
Just replaced my 17.5 red rotor with the green rotor for my 12th scale. The track is 83x40, which starting gearing should I use with 42.5mm tire?? 35 degrees timing, correct?
For TC i used the blue rotor that and it worked out well but I'm curious what I'll get from the green in 12th.
Nobody is running 12th with the green rotor?
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 01-25-2014, 04:47 AM   #572
elee32's Avatar
Trader Rating: 18 (100%+)
I liked the blue rotor better in 12th. 30 degrees timing, start in the 95 to 100 mm rollout range. I used the green rotor for a bit but found it dropped off more at the end of a run than the blue. This is one you'll have to mess around with a bunch to find the sweet spot. For me, higher rollouts like less timing, while a lower rollout was better with more timing....this is all dpendant on how good your battery is too
Eric Lee, sponsored by shipping and handling..
elee32 is offline   Reply With Quote
Old 01-25-2014, 09:28 AM   #573
ToysRUsKid's Avatar
Thanks. I did some searching on this thread last night and figured i should be between 98-101 rollout. I have the blue rotor in my TC but I guess I can try switching them between runs to see what i like.
Old 02-04-2014, 05:41 AM   #574
howardcano's Avatar
Trader Rating: 35 (100%+)
Does anyone have recommendations for timing for both the 17.5 and 21.5 motors on 2s LiPo? I run on medium-to large-sized carpet tracks with good traction, and medium-sized outdoor with low-to medium traction.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 02-04-2014, 06:02 AM   #575
oeoeo327's Avatar
Trader Rating: 70 (100%+)
I'd use 35 degrees of timing in both cases... If you're using the motors in TC/USGT applications, I'd also recommend using the 12.5 mm green rotors.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 02-04-2014, 06:31 AM   #576
Ciao to all,
my 13.5 T just arrived, i'll place it on my tc blinky racing. I'll race in medium size track.
Can you suggest me a good starting point? I should leave it stock with 40/50 of end bell timing, or i must change the rotor?
Tnks to all
Max
Touring: WRC STX
F1: WRC F-ONE 200 and 180 mm
ESC:Viper VTX10R; Motor: too many; Radio: Sanwa MT4
Don't follow me.... at the end of the straight there is the hairpin and my wall.....
mtaddei is offline   Reply With Quote
Old 02-04-2014, 07:31 AM   #577
+1 I run 21.5 with the green rotor and 35degree timing and it's great throughout the power band.
Indyonroad is offline   Reply With Quote
Old 02-04-2014, 02:40 PM   #578
jasons56's Avatar
Interesting. I have been doing lots of testing for 13.5 12th with another brand lately and it LIKES a Torque rotor with less drop off at the end. With the TP and green rotor setup I've been seeing relatively more drop off. However, I have been running roll outs the same with both motors. I guess the TP design likes a little more timing/revs and less roll out?
I'll try the blue! Thanks!
http://www.youtube.com/user/ZenRacing
jasons56 is offline   Reply With Quote
Old 02-04-2014, 04:03 PM   #579
ToysRUsKid's Avatar
I switch to blue in 12th and green in TC. The TC is up to speed for sure with green rotor, but I haven't figured out a good rollout for the 12th with blue rotor yet.
Old 02-04-2014, 11:37 PM   #580
Originally Posted by mtaddei View Post
Ciao to all,
Tnks to all
Max
nobody can help me?
Touring: WRC STX
Old 02-05-2014, 02:20 AM   #581
Skiddins's Avatar
nobody can help me?
In blinky 1/12, the guys don't use any more than 35-40deg of end bell timing otherwise the motor generates too much heat.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-05-2014, 07:15 AM   #582
oeoeo327's Avatar
nobody can help me?
Use 35 degrees of timing. any more than that, and the motor will generate too much heat.
Old 02-05-2014, 11:30 PM   #583
Ok tnks to all,
i'll try with max 35 of endbell timing, then what about green rotor?
Touring: WRC STX
Old 02-12-2014, 09:13 AM   #584
Wade....'s Avatar
Just read man! Everyone has been saying go Green rotor in Touring car.
Wade Huesman, TCORC Secretary/Pencil Pusher
Wade.... is offline   Reply With Quote
Old 02-12-2014, 10:04 AM   #585
ToysRUsKid's Avatar
Yup, green rotor works well in TC. i'm still experimenting with 30 or 35 degrees timing.
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 08:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 12:29 AM
