Old 08-23-2013, 06:05 AM   #541
Hello,
I will run TC 10.5 blinky with a Z3R, what is the best rotor choice?
thanks
Rally-game proto Clo-products - Toro 150a - HW 2250kv - Turnigy a-spec - Futaba 3PKS
Tamiya M03S mini cooper - Novak 410M1C - Orion Core 27x1
Kyosho Mini-Z MR03 and MA015
Xray T4-2014 - Hobbywing V3.1 - LRP X20 spec 10.5 - Turnigy ultimate
Xray X12-2014 - Reedy Mach2 6.0
christophed83 is offline   Reply With Quote
Old 08-26-2013, 09:53 AM   #542
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Want to thank Jim for helping me the last 5 years while I ran for TP and listening to my endless bitching.
Now I have to pick new motors and sticks to run...
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 08-27-2013, 03:51 PM   #543
b-man777's Avatar
Hey Larry: Just curious why your leaving thunder power is your contract up or just want to try something else? Thanks
b-man777 is offline   Reply With Quote
Old 10-15-2013, 12:39 PM   #544
peter.'s Avatar
I have a reedy sonic Mach2 4.5t is comparable with the thunder power 4.5t with power and speed
peter. is offline   Reply With Quote
Old 10-22-2013, 04:30 PM   #545
Suspended
Looking at the 550 motors. Trying to decide if I should get thunder power or reedy. Is the power band different? What are the differences?
latentspeed is offline   Reply With Quote
Old 10-24-2013, 11:43 AM   #546
dMITIj's Avatar
im in on that one also, its for my DEX410 but can't decide TP ore Reedy any one?
Best Regards.
TLR 22-4.
ORION VORTEX R10.1 Pro ESC.
ORION VORTEX VST2 PRO 7.5T.
ORION CARBON PRO 4500 100C 7.4V SHORTY PACK x3.
Sanwa MT4S Radio/RX-481 receiver & Xpert RC PI-3402 Brushless Servo.
dMITIj is offline   Reply With Quote
Old 11-26-2013, 04:22 AM   #547
RC10B4_Mafco's Avatar
Trader Rating: 15 (100%+)
Send a message via MSN to RC10B4_Mafco
Does anybody have solid numbers on the kv rating of the mod motors (specifically the 7.5)? I can't find any kv ratings anywhere.
Thanks in advance,
Mark
RC10B4_Mafco is offline   Reply With Quote
Old 12-04-2013, 09:25 AM   #548
Hi
Going to be running a tp 5.5 in my 12th like to know if the stock rotor is the one to use or one of the optional ones is best..
Quietman is offline   Reply With Quote
Old 12-04-2013, 11:33 AM   #549
Skiddins's Avatar
Originally Posted by Quietman View Post
Hi
The Mod motors use a different rotor from the stock versions.
Stick with the original, it will be far more powerful (plus I think it won't fit )
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-04-2013, 11:50 AM   #550
oeoeo327's Avatar
Trader Rating: 70 (100%+)
Spec rotors fit inside the mod cans - it'll smooth out the powerband at the expense of efficiency... I tried this as an experiment while learning to drive a Mod TC on asphalt. Upside, car was significantly easier to drive; downside, my batteries took a beating...
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 12-29-2013, 04:53 PM   #551
looking for a little help with a 21.5 motor. i bought the green high torque rotor but cant find any instructions on how to replace the stock rotor with the green one. i cant even find anything on you tube about replacing it. thunder powers web site instruction link doesn't work.
thanks for any help and info
TTS
ttsquirrel is offline   Reply With Quote
Old 12-30-2013, 10:20 AM   #552
i ended up finding something on you tube and changed out the rotor, but the kit came with a couple different spacers and one o-ring. i just used the same spacer as the stock rotor. is there a reason why there are extra spacers for the rotors?
also noticed that stock rotor has four holes drilled into it. check the picture out. is that a mod that people do or is that from the factory like that? the green rotor does not have any holes in it. BTW, I bought the motor used.
TTS
Old 12-30-2013, 10:28 AM   #553
oeoeo327's Avatar
TTS
The extra spacers are included to allow you to adjust the rotor's location relative to the sensors on the sensor board. In most cases, using the shims supplied with the original rotor will suffice, but there are cases where shims are added or subtracted to locate the rotor in the can correctly.
The drilled holes in the rotor are used for balancing purposes. Special machinery is required to make sure that the rotor balances properly, so very few people would be performing this modification on their own. I wouldn't worry about the lack of balance holes on the new rotor - it simply means that the rotor was within the factory tolerances for being balanced without requiring additional material to be removed.
Old 12-30-2013, 11:00 PM   #554
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
Originally Posted by ThunderPowerRC View Post
No you want to be somewhere around 3.5-3.6 FDR with the red rotor @ 35* timing. If you go with the blue rotor then you can go 3.3 - 3.4.
Trying to wrap my head around this because i'm getting back into electric racing. I have 1 motor with blue rotor and another with stock red rotor. the blue I can gear to 3.3-3.4 with 35 timing? the red I can gear to 3.5-3.6 with 35 degree timing?
It sounds like I would fair better with the green rotor, but what gearing and timing?
This is all on the Xray T4'14.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 12-31-2013, 05:22 AM   #555
oeoeo327's Avatar
How large is your track, and how open are the typical layouts? Once we have an idea of how tight the track is, we can give you a better idea how to gear the motor. If you're thinking of running the TP 17.5 in TC, the green rotor w/35 degrees of timing is the way to go.
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 08:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 12:29 AM
