Old 07-28-2013, 01:56 PM   #526
Barry_Hughes's Avatar
Originally Posted by Bill K View Post
Recently purchased one of these motors for 17.5 boosted state titles approaching.
Currently I am running a 6.25 FDR, with somewhat 40 degrees of boost and 30 degrees turbo on the new HW v3.1 ESC. I have 20 degrees of motor timing on the endbell using the red rotor, and from my experience this thing rocks!
Although, after every run it has a very strong smell to the motor, it performs very well, but I still want some more performance out of it to keep up with some of the faster racers. After a 6 minute run the motor comes off at about 70C with a heat sink and fan, and only once after a 15m run did it come of at 95C (Absolute borderline!!).
For about a 50m straight, this is the only area lacking competitive racing, as a few (not all) racers are alot faster. Can anyone suggest some HW settings that would maybe increase the performance? Or should I be going down on settings and changing timing or FDR?
Max number of points (timing) is 64 on the HW so running turbo 30 is actually only 24 as the 40 points of boost will be used first leaving 24 points of turbo doesn't matter what you set it at over 24 that's all you'll get.
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 07-28-2013, 04:39 PM   #527
ThunderPowerRC's Avatar
Originally Posted by 415tam View Post
Hi ThunderPowerRC, thanks for getting back about my gearing question.
Can I just confirm that the TP 17.5 (as comes out of the box) should be geared from my current gearing of 3.2 - 3.3 to say 2.9 or lower.
Is this the right way to gear the motor as per your suggestion.
I just want to make sure I am gearing the right way before I run the TP 17.5 motor again.
Many thanks.
No you want to be somewhere around 3.5-3.6 FDR with the red rotor @ 35* timing. If you go with the blue rotor then you can go 3.3 - 3.4.
ThunderPowerRC is offline   Reply With Quote
Old 07-28-2013, 04:51 PM   #528
Try this with a blue rotor:
Boost Timing: 40
BT Start RPM: 6000
BT End RPM: 19500
BT Slope: Linear
BT by TH: NO
Turbo Timing: 24 Degrees
Turbo Activation: FULL THROTTLE
Full Throttle Delay: 0.1s
Turbo Start RPM: 20,000 (Not needed)
TT Eng Slope: 24 Degree/0.1
TT Disengage: 6 Degree/0.1
Motor End bell timing = 20 degrees
FDR = 5.90
Old 07-28-2013, 11:56 PM   #529
Bill K's Avatar
Boost Timing: 40
BT Start RPM: 6000
BT End RPM: 19500
BT Slope: Linear
BT by TH: NO
FDR = 5.90
Alright, thankyou!
Also, what about for say, a 20m straight and really technical inside?
Bill K is offline   Reply With Quote
Old 07-29-2013, 01:24 AM   #530
Trying to get my head round this, red rotor is the std rotor (RPM/torque) I thought blue was rpm rotor & green was a torque rotor.
Surely if you run a blue rotor (RPM) the fdr should go the other way to say 3.7 to 3.8 as you will loose the pull out of the corners & 3.3 - 3.4 would suit the green (torque) rotor as that will have more grunt to run a higher ratio?
Or is my thinking totally wrong?
Built it !
Raced it !
Wrecked it !
Old 07-29-2013, 01:34 AM   #531
Skiddins's Avatar
Blue is labled as 'Torque' (and is the same diameter as the red, but the magnetic material is about 1mm longer), the Green is 'Hi-Torque' (same length as the Blue but 0.2mm larger diameter.)
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-29-2013, 05:40 AM   #532
Hi ThunderPowerRC.
Fantastic, thanks for letting me know the correct gearing to start of with + the timing for the 17.5 TP motor with std. red rotor.
I will run it again as per your suggestions.
Many thanks
415tam is offline   Reply With Quote
Old 07-29-2013, 11:09 AM   #533
Cheers Damien, that does make sense then, I was told blue was an rpm rotor that was wrong then!
Built it !
Raced it !
Wrecked it !
Old 08-02-2013, 03:04 PM   #534
peter.'s Avatar
I have a thunder power z3r n4.5t but now the Purple Ring has come from the rotor is a problem what should outsite temperature of the out site of de motor
peter. is offline   Reply With Quote
Old 08-14-2013, 03:14 PM   #535
Send a message via ICQ to MattW
Part number P1007 outer can - does this fit the mod range of motors? I'm sure I remember reading that the mod and stock cans weren't exactly the same.
MattW is offline   Reply With Quote
Old 08-14-2013, 07:42 PM   #536
elee32's Avatar
Trader Rating: 18 (100%+)
Can't say for certain from the part number but, you are correct that the mod and stock cans are different
Eric Lee, sponsored by shipping and handling..
elee32 is offline   Reply With Quote
Old 08-15-2013, 06:12 AM   #537
MikeXray's Avatar
Trader Rating: 72 (100%+)
Interesting, from here:
http://thunderpowerrc.com/Z3RBrushlessMotors.htm
they only show the one part, with S-M after it stock/mod? but we do know that the stock and mod stators are different lengths, so I would have expected 2 different parts..
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-15-2013, 11:52 AM   #538
Yeah that's kind of why I asked the question tbh.
Old 08-15-2013, 12:31 PM   #539
Magnet Top's Avatar
It only fits the stock winds. Basically, if you need a replacement can for a mod stator the can cannot be purchased separately.
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 08-21-2013, 11:16 AM   #540
bertottius's Avatar
Trader Rating: 17 (100%+)
So, is it pretty much understood that running 17.5 TC blinky with a green rotor timing should be around 30-35 degrees?
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is online now   Reply With Quote
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 08:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 12:29 AM
