Old 07-15-2013, 07:22 AM   #496
Why does thunder power not list kv ratings or suggested voltages? Looking for a spec on the Z3R 550 4 turn. Has anyone done some independent research?
E85S4 is offline   Reply With Quote
Old 07-15-2013, 06:13 PM   #497
ThunderPowerRC's Avatar
Because Kv numbers for slotted sensor motors are subjective. Stator design, rotor type and strength, motor timing all effect Kv. Most numbers are made up. This is why we donít publish numbers. However if you must.
Thunder Power Z3R 550 Motors
4.0 4.5 5.0 5.5
Part Number TPM-550A040 TPM-550A045 TPM-550A050 TPM55A055
Voltage 7.4 7.4 7.4-11.1 7.4-11.1
RPM/7.4V 37814 33596 30340 27602
kV 5110 4540 4100 3730
Power (W) 950 900 850 800
Max Current (A) 133 126 120 110
Efficiency (%) 92 92 94 94
Diameter (mm) 35.8 35.8 35.8 35.8
Length (mm) 65.3 65.3 65.3 65.3
Shaft Diameter (mm) 5.0 5.0 5.0 5.0
Weight (g) 248 248 248 248
ThunderPowerRC is offline   Reply With Quote
Old 07-15-2013, 06:29 PM   #498
defcone's Avatar
Trader Rating: 15 (100%+)
Will a 4.5t stator fit in a 13.5t can?
defcone is offline   Reply With Quote
Old 07-15-2013, 07:28 PM   #499
Jerz616's Avatar
Trader Rating: 49 (100%+)
I don't think so. 13.5 is still considered stock spec. The 4.5 being a mod. You can interchange stock stators with other stock cans, but not with mod cans.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 07-15-2013, 07:36 PM   #500
All the stators are interchangeable.
Team Serpent
Steve S is offline   Reply With Quote
Old 07-15-2013, 08:27 PM   #501
Jerz616's Avatar
I think you might want to check that out. Stock stators are interchangeable with other stock stators. Mod stators are interchangeable with other mod stators. But you can't mix the 2.
This from page 17 post #249
Let me try to explain, winds 7.5t to 21.5t have a shorter stator than the modified 3.5 to 6.6t motors. There are two different cans for the motors. One for stock and one for mod. So the short answer is a mod stator will not fit in a stock can. We only offer the stock can as a replacement at this time. There willbe new mod cans coming soon
Ryan Gracey
XRAY XB8'14
Old 07-15-2013, 11:29 PM   #502
Wat rotor comes with the 17.5 motor? Is it the red or the green one?
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 07-15-2013, 11:47 PM   #503
defcone's Avatar
Red
Old 07-16-2013, 04:37 AM   #504
Red
Thanks ill try the green one soon .
Old 07-16-2013, 10:15 AM   #505
Ok, that makes sense. So really the compatibility is not with 'mod' and 'stock', but with specific winds. The info I got from ThunderPower by email was that my 10.5 (stock) stator would work in an 8.5 (mod) can, so I assumed that mod and stock stators were interchangeable.
Team Serpent
Old 07-16-2013, 09:46 PM   #506
defcone's Avatar
Maybe 10.5 is mod?
Old 07-17-2013, 01:37 AM   #507
NOFX's Avatar
Trader Rating: 23 (100%+)
Does that make 8.5 = stock?
Castle Hill - The Home of Vintage Racing in NSW
2017 Vintage Festival 11th & 12th of November 2017
2018 Vintage Enduro (Return of the Dukes) - start planning!!
@cassovintage www.hillsoffroadrc.com
Look out for the St Ives vintage event coming up soon!
NOFX is offline   Reply With Quote
Old 07-17-2013, 07:58 AM   #508
I was going by their own designation:
http://thunderpowerrc.com/Z3RBrushlessMotors.htm
Team Serpent
Old 07-18-2013, 11:34 AM   #509
Does anyone have a guide or video of how to disassemble / assemble the motors.
Should you aim to remove all play from the shaft?
Nathan Wilson is offline   Reply With Quote
Old 07-18-2013, 12:10 PM   #510
Jerz616's Avatar
Just remove the 3 screws and pull the red and silver can halves apart. The stator will be left with the rotor inside. Pull the rotor out. I would just shim it so thst it floats freely. You don't want it to bind. Just enough side to side play. Usually a couple mm of play is good.
Ryan Gracey
XRAY XB8'14
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 08:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 12:29 AM
