Old 10-10-2012, 03:43 AM   #376
What is the Kv rating of a 13.5 Z3R?
RSCosworth is offline   Reply With Quote
Old 10-10-2012, 11:34 AM   #377
tobyzhang's Avatar
Originally Posted by Skiddins View Post
Have you tried a different pinion? Most of the noises that come from my transmission seem to be related to the type of pinion.
I'm pretty sure the noise comes from the motor internal. I've switched between sonic and thunder power and reedy is completely quiet. It's a belt drive tc by the way.
tobyzhang is offline   Reply With Quote
Old 10-10-2012, 01:06 PM   #378
Skiddins's Avatar
Only thing I can think of is to check whether it has the correct amount os shims on the rotor.
Just enough to remove all but the last little bit of slop.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-10-2012, 01:16 PM   #379
tobyzhang's Avatar
I think the shim is okay, but I'll look into it. Thanks
Old 10-10-2012, 02:23 PM   #380
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I get the same thing in my 12th with the HT rotor in my TP. The sound is definitely internal. For me I noticed it when applying the brakes with the car on the bench and the wheels stopped. It sounds like a cogging issue, but all the sensor lights on the RS work and in forward the car does not stutter or hesitate and is plenty fast. I can even see the motor trying to rotate backwards, even though reverse is disabled in the RS. I have about 38 degrees of timing on the motor and the RS is in blunky, but it looks almost like there is so much timing in the car that the esc can't find the rotor and is trying to move it but is mistimed. Weird!
Old 10-10-2012, 02:28 PM   #381
tobyzhang's Avatar
Originally Posted by andrewdoherty View Post
I get the same thing in my 12th with the HT rotor in my TP. The sound is definitely internal. For me I notices it when applying the brakes with the car on the bench and the wheels stopped. It sounds like a cogging issue, but all the lights on the RS work and in forward the car does not stutter or hesitate and is plenty fast. I can even see the motor trying to rotate backwards, even though reverse is disabled in the RS. I have about 38 degrees of timing on the motor and the RS is in blunky, but it looks almost like there is so much timing in the car that the esc can't find the rotor and is trying to move it but is mistimed. Weird!
This is exactly what I'm getting, the timing mark on the motor seems like way underrated than my reedy sonic. timing at 40 degree, the motor is absolutely ballistic when free revving with tire lifted but doesn't seem to give much when the car actually runs on the ground.... And that noise when braking.... Will it damage my esc or is it fine...?
Old 10-19-2012, 09:55 AM   #382
Green Machine!'s Avatar
Send a message via MSN to Green Machine!
Hi all.
Using the 13.5 in my WGT pan car. 1S blinkey rules. Fairly small indoor carpet track. 80 is my approx rollout. Using 80t & 38t. Installed green rotor. Motor timing around 45. Temp after 4-5 min is around 160. Still doesn't seem to have quite the "punch" and top speed combination that the rest of the field has. Close though. Any suggestions on changing anything? Am I close to peak performance? Anyone know anything crazy good about that "special" "1S" 13.5 specific motor that MurfDogg has?... Thanks everyone
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Green Machine! is offline   Reply With Quote
Old 10-19-2012, 10:55 AM   #383
Skiddins's Avatar
Originally Posted by Green Machine! View Post
Hi all.
Others running 1s have suggested that the green rotor bogs down the high rpm so it won't actually be as fast due to the lower voltage.
Try the red or blue rotor.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-19-2012, 12:02 PM   #384
j.d.roost's Avatar
Trader Rating: 28 (100%+)
For those running a rs/1s if you have not...try running a rx pack.
I had similar issues (felt like it was cogging) when using a booster +tekin rs/pro and the pack immediately fixed the problem.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 10-25-2012, 05:38 PM   #385
tobyzhang's Avatar
Does this also apply to 2 cell?
Old 10-26-2012, 01:28 AM   #386
sosidge's Avatar
I think you already know the answer... you are over-timed.
Don't trust the markings on the cans, they are not consistent from brand to brand. Make your own call based on performance.
Knock the timing back until you get a smooth and fast car again.
Old 10-30-2012, 10:28 AM   #387
tobyzhang's Avatar
Tried it but didn't work.... even with timing at zero. Rpm went down but the clicking did not go away
Old 10-30-2012, 12:36 PM   #388
Since it is a "used motor" that you got your hands on, has anyone suggested to change the bearings? If it's not timimg, or the esc, or rotor, or shimming..nothing else touches anything else to make a noise. I too have been experimenting with everything from timimg to rotors to make this thing faster and nothing has made a noise. Worst case was when I used the green rotor and gave it lots of end bell timing. It cogged and stuttered a bit in the corners but no clicking noise.
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Old 11-05-2012, 11:47 AM   #389
Can I just drop a 13.5 stator in the can of my 17.5?
I see by searching this thread that it's been done, but some of you have had problems. Trying to keep my costs down and I don't need both motors at once. Would you guys recommend this?
17.5 TC (TC7)|21.5 USGT (TC4)|TCS Euro Truck|Mudboss
RC Car World|Stella's Speedway
TU '16. Go Owls!
Flagler is offline   Reply With Quote
Old 11-05-2012, 12:25 PM   #390
Jerz616's Avatar
Trader Rating: 49 (100%+)
I believe all the Z3R stock motors use the same can. It's the mod motors that some have had issues with.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 08:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 12:29 AM
