Old 09-05-2012, 08:51 AM   #346
When you don t use the screw it isnt enought tight.
On my t3 2012 i can t use this fixation, so near to the solder plates
Manson is offline   Reply With Quote
Old 09-05-2012, 08:58 AM   #347
bertottius's Avatar
Trader Rating: 17 (100%+)
Default Oval Racing
Does anyone have any info on which rotor to use for a medium sized carpet oval in 1/10 17.5 class?
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 09-05-2012, 09:02 AM   #348
Skiddins's Avatar
It was designed for brushed motors.
You need to hacksaw part of it off.;
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-09-2012, 05:25 PM   #349
Default bought used 17.5
I bought a used 17.5 and I am not sure if it's the motor gearing or what but just been a dog for me.
small track (about 80' straight - TQ RC Racway if you need to know). Running Tekin RS, Top Photon Sedan, 25deg timing on the motor 4.1 fdr, running fan on motor comes off at 145 (F). Just seems slugish and people are passing me on the straight like I was running a 21.5. Not sure if the stator is crap, or what I need to do . . .
tried running it in 1/12th and seemed like a dog there too . . .
mupchu is offline   Reply With Quote
Old 09-09-2012, 06:52 PM   #350
Jerz616's Avatar
Trader Rating: 49 (100%+)
What rotor are you running? I run mine with the green rotor and about 30* of timing and it comes off at abot 150-160 geared at about a 3.95. Give it a little more timing and see. They are good to about 35* and still run pretty cool.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 09-09-2012, 07:05 PM   #351
running the stock red rotor . . . not really wanting to dump more into this motor if something with the stator is messed up.
Old 09-09-2012, 07:31 PM   #352
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Try 30 degrees of timing and a 3.7 FDR.
Run 2 minutes and check temps the first time. I repeat run 2 minutes and check temps. If they are over 140 ish stop and try something else.
I don't run a ton of 17.5 but when I do I'm always below 4.0 no matter what track and 30 degrees timing is usually optimum.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 09-09-2012, 09:06 PM   #353
bkspeedo's Avatar
I agree with Larry.
I've been running this motor for about 10 months 3 times a week on the same size track. I've been gearing around a 3.8-3.9 with 30-35 deg of timing in blinky mode, motors been coming off around 155-160.
I've recently started upping the gearing and found the motor to run a little cooler with a higher FDR like 3.6 with same timing.
For the first few practice runs make sure you temp often to make sure it's not over heating. Of course if your setup is not efficient and your driving is all over, this gearing will not be optimal.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 09-10-2012, 05:08 AM   #354
Bishop's Avatar
On my blinky 17.5 I was 3.77 FDR, 40 timing, and coming off after 6mins barely warm at 40-45C max, it was a cool night though, and it's a fairly tight track.
I would have geared up, but someone 'borrowed' my 36T pinion, so I likely would have had to go up two, hence me cranking the timing to 40.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 09-14-2012, 03:00 AM   #355
Skiddins's Avatar
If any of you want to cool the motors a bit more easily;
I have found that by using computer heatsink compound between the stator and the can it transfers the heat more effectively.
I also use some between the outside of the can and the heatsink pictured above in post #348
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 09-17-2012, 06:32 AM   #356
Bishop's Avatar
In the category of "don't try this at home", pinions I thought I'd never use, by end of this weekend, I was 66/40 tooth, on a Photon with 2.0 trans, so 3.30 FDR, nearly a 61mm rollout, and at one point in the cooler afternoon of Saturday, I was timed near 40 degrees cause I was out of pinions, and still coming off at 55-60C.
Err, yeah I think I like my Thunder Power, drove like a newbie, but never lacked power, never came close to overheating, and did not seem down on speed to anyone in the heats I ran in.
QRCCRA
www.qrccra.org.au
Old 09-17-2012, 07:06 AM   #357
racer x 1's Avatar
Trader Rating: 27 (100%+)
up your timing to 35 and gear to about 3.8 or 3.9 with high torque rotor. and you will see the power. the red rotor was very sluggish for me in sedan but excellent in pan car. currently my Tek 6 is geared this way and has gobbs of punch and great top end at tq.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 09-17-2012, 07:23 AM   #358
Car Breaker's Avatar
What is the stock timing of a Z3R 5.5t ? a friend of mine borrow the motor and change the timing by mistake.
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 09-18-2012, 08:41 AM   #359
Bishop's Avatar
I think all the TP motors come timed at 20, I know that is true for the higher turns, fairly sure it's what I have seen on the lower turns as well.
QRCCRA
www.qrccra.org.au
Old 09-18-2012, 11:48 AM   #360
does anyone know if the stated 20 degs that the motor comes set as standard is actually 20 degs?
matt prigmore is offline   Reply With Quote
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 08:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 12:29 AM
