Old 08-27-2012, 01:58 PM   #331
Green rotor just installed, i have to replace a 0.5 mm shim by a 0.2 mm to have a good clearance.
Not a big difference when i m turning the rotor with my hand.
Manson is offline   Reply With Quote
Old 09-02-2012, 12:36 AM   #332
Bishop's Avatar
How careful do you have to be gearing and timing up with a fan blowing back onto the motor?
I was surprised how much cooler my TP was running first time out running with a cooling fan, it seemed to keep temps a lot lower, though if you unplug the fan and recheck temp after the run, it instantly seems to rise as much as 10C.
This had me a little concerned you could cook or be overheating and not realize cause the fan is cooling it back down so fast by the time you get to temp it?
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 09-02-2012, 03:15 PM   #333
Skiddins's Avatar
This had me a little concerned you could cook be overheating and not realize cause the fan is cooling it back down so fast by the time you temp it?
The temp rising is where the heat soaks through the can. To help dissapate it I would wire a fan into the receiver or main power wires so it stays on.
I would keep the motor timing below 30deg and don't max out your ESC, take it up in stages.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-02-2012, 05:10 PM   #334
i run 17.5..love it..now i want the 21.5 for usgt..good starting point...track 120 x 50 with a sweeper..blinky mode..mamba max pro.....i was thinking 4.0....30* timing...what y'all think
starrx is offline   Reply With Quote
Old 09-02-2012, 11:24 PM   #335
Bishop's Avatar
Yeah, I wired up the fan right from the start directly off the battery source, but I put a plug on it for testing purpose, but as long as the battery stays plugged in the fan can always stay on.
I only unplugged it to see just how much heat soak the fan was preventing, and it turned out to be more than I expected, to the point I worry about thermal load the motor will see internally without me ever seeing or feeling it.
All this was zero ESC timing, pretesting on my 10.5 before I fit my new 17.5 and start dialing that in for a big event (never run 17.5 before), with the 10.5 though at one point I had it up to 40deg timing on the can, still running cool with the fan being on it, though also a cold night.
QRCCRA
www.qrccra.org.au
Old 09-02-2012, 11:40 PM   #336
Trader Rating: 36 (100%+)
Default TP 17.5
Does anyone know the spec (ie KV and RPM) for this motor? I looked at their web site but it doesn't say.
80'sracer is offline   Reply With Quote
Old 09-03-2012, 01:57 AM   #337
Skiddins's Avatar
The blinky I've seen to seem to run the timing around 35deg, and said the green rotor made a big difference in blinky.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 09-03-2012, 02:01 AM   #338
Skiddins's Avatar
I've seen a few guys run the motor repeatedly in the 80degC range, but I get nervous if mine get's into the 70's.
They don't seem to get as hot as a lot of others, especially the LRP's etc.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 09-03-2012, 06:57 AM   #339
thanks!..i dont think your allow to change the rotor in usgt..but if so i my try the green rotor in both 17.5 & 21.5 motor
Old 09-05-2012, 05:48 AM   #340
Bishop's Avatar
Can anyone say if I may need to gear any lower than a 3.47 FDR with 17.5 zero boost?, having zero experience with 17.5 I have no clue if I'll need to buy anything bigger than the 38 tooth pinion my current selection goes up to?.
QRCCRA
www.qrccra.org.au
Old 09-05-2012, 07:03 AM   #341
Skiddins's Avatar
Possibly, the guys at an indoor club I go to run 13.5 blinky (30m*16m) and are geared around 4.5fdr
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 09-05-2012, 07:19 AM   #342
I m seeking a good heatsink for this motor. The lrp heatsink don t fit well on it
Old 09-05-2012, 07:43 AM   #343
Skiddins's Avatar
Originally Posted by Manson View Post
I m seeking a good heatsink for this motor. The lrp heatsink don t feet well on it
Which LRP heatsink do you mean?
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 09-05-2012, 08:07 AM   #344
The heatsink who is sell with the 40x40 fan.
Old 09-05-2012, 08:46 AM   #345
Skiddins's Avatar
Like this one;
If so, it fits perfectly.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 08:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 12:29 AM
