Old 08-18-2012, 08:50 AM   #316
Skiddins's Avatar
Originally Posted by plummers View Post
yep can confirm what skiddins said, big improvement with the green rotor in, hall was ambient at 25 degrees, motor timing at 35 and geared to 4.5 in blinky. consistent through the whole run and motor came off at 70. usually struggle to keep motor temps down but the green rotor helped alot. plummers
Originally Posted by Juan Aveytia View Post
Thanks, I only have the green rotors and heading to the Tamiya Nationals next week. So, it sounds like your power and top speed were on pace with everyone else. That's good to know. Thanks for the reply.
Plummers was car#1 here;
+ YouTube Video
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-18-2012, 01:35 PM   #317
Default PT 13.5T Lrp Stock Spec V2
Does anyone have a good setup for a Lrp Stock Spec V2 and a TP 13.5T i boosted class?
Any good advice will be apreciated.
Viking73 is offline   Reply With Quote
Old 08-21-2012, 01:36 AM   #318
Bishop's Avatar
Well in 10.5T I think I'm finding what a few people have found?, the Thunder Power seems to really like about 35 degrees timing, geared to suit, only issue I found was some fade mid race that may have been my packs.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 08-21-2012, 03:07 AM   #319
Skiddins's Avatar
What rotor, ESC and timing settings?
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 08-21-2012, 03:35 AM   #320
Bishop's Avatar
Zero/Blinky ESC, stock rotor, around 5.0 FDR, and the motor just seems to come alive a bit at around the 35 degree end bell timing mark.
I'm not running a cooling fan though, maybe come summer, but it's generally cool on track right now.
QRCCRA
www.qrccra.org.au
Old 08-21-2012, 04:33 AM   #321
BrodieMan's Avatar
I misaligned the stator in the motor can and can't get the stator back out or turned slightly to align the screws I can't get the stator to move at all and can't figure out how to extract it without destroying the plastic.
Any suggestions would be appreciated.
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 08-21-2012, 05:43 AM   #322
Skiddins's Avatar
Have you tried unscrewing the timing screws, might allow a bit of movement as the rear bearing etc will no longer be a snug fit.
I don't eally understand how you've managed to do that as there isn't much room for mis-alignment.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 08-21-2012, 05:54 AM   #323
BrodieMan's Avatar
Skiddins
Timing sensor and rotor are removed. The stator is just a bit off skew to align the screws and I can't turn it at all without completely destroying the plastic.
Mark Richardson
Old 08-21-2012, 06:22 AM   #324
MikeXray's Avatar
Trader Rating: 73 (100%+)
I have used a 3mm wrench to push the stator out from the front side of the motor, sometimes they do get jammed.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-21-2012, 08:59 AM   #325
BrodieMan's Avatar
Thank you for your responses and tips.
Unfortunately for me the stator is stuck in the can something serious Hopefully I can salvage the can, the stator is not going to survive the extraction
Lesson learned: Take more time rebuilding my motors.
Mark Richardson
Old 08-26-2012, 02:37 AM   #326
My 10.5 smell bad after running, is it normal ?
The temperature didn't excess 70 celcius
Manson is offline   Reply With Quote
Old 08-26-2012, 02:49 AM   #327
defcone's Avatar
Trader Rating: 15 (100%+)
Apparently there's a gasket inside which melts, which causes the bad smell.
defcone is offline   Reply With Quote
Old 08-26-2012, 03:15 AM   #328
Bishop's Avatar
My 10.5 smelt a little odd after it's first few runs, then the smell went away, no idea what it was, figured maybe some oil or coating somewhere that burns off after a while.
QRCCRA
www.qrccra.org.au
Old 08-26-2012, 03:32 AM   #329
ByteStream's Avatar
I believe what your smelling is the epoxy (when heated). Is should go away after a while or at least not be so potent.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 08-26-2012, 09:01 AM   #330
Skiddins's Avatar
Have been running boosted 13.5 and have been experimenting with the Green 'Hi-Torque' rotor.
It appears to pull well with taller gearing.
Anyone tried the green rotor yet?
I notice that a lot of people say to gear for rev's, but everytime I have done that (with all three rotors) it's a dog.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 08:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 12:29 AM
